4
112182
29 October 2023
Filesystem stuck on Read-Only
5
21
3 May 2024
USB Wifi Scan issues AR9271
7
27
3 May 2024
DietPi fresh install WiFi issues on Raspberry Pi Zero 2 W
16
710
3 May 2024
How to manually install Amiberry 5.70 on Dietpi 9.30 thanks
3
36
3 May 2024
Switch from lighttpd to nginx wihout reinstalling nextcloud
1
29
3 May 2024
Umm, Parallels arm64 images for download
1
28
3 May 2024
Raspberry PI 5 pci boot with nvme, error with 'rpi-eeprom'
9
57
3 May 2024
[Raspberry Pi 5] Banding/Dithering on Images in Chromium Kiosk
1
27
3 May 2024
Ffmpeg libary problem
3
26
3 May 2024
Raspberry Pi 5: Xorg issues - Chromium Autostart (Cannot run in framebuffer mode)
14
218
3 May 2024
38
216
3 May 2024
Orange pi 3b NVME problem
36
248
3 May 2024
Question on Media Server
4
32
3 May 2024
Support for Radxa Zero 3W
4
121
3 May 2024
Share of Unofficial DietPi - Radxa Zero 3W
46
947
3 May 2024
AdGuard Home, static IP
2
31
3 May 2024
DietPi on RK3328 Rk3318 TVBOX
9
3467
2 May 2024
Deluge downloads through Wireguard but uploads outside the tunnel?
2
30
3 May 2024
NanoPi NEO running unstable since latest update
6
84
2 May 2024
Error with balena etcher and dietpi image
2
31
2 May 2024
11
176
2 May 2024
Alsa Mixer MAX98357
1
59
2 May 2024
App nextcloud iOS: browser is not supported
14
92
2 May 2024
Allo USBridge Signature No sound through HDMI
3
35
2 May 2024
Unable to connect to IPVanish: End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive
1
146
1 May 2024
Where to add kernel command line options on Odroid C2 running Dietpi latest
1
49
1 May 2024
Backup location not being used by dietpi-update
3
36
1 May 2024
Wordpress install; Unsupported special character in password causing SQL error
3
66
30 April 2024
Whilst Plex is working shutdown all other services
8
77
30 April 2024
