4
112314
29 October 2023
Best way to install or replace LXDE with FVWM?
0
9
13 May 2024
DietPi: Headless install on Raspberry Pi 5 NVME drive?
2
38
13 May 2024
Sysfs to control GPIO depracted -> Alternatives?
19
63
13 May 2024
App nextcloud iOS: browser is not supported
23
153
13 May 2024
Kodi screen resolution bug after update
0
29
13 May 2024
RPI zero 2 boot looping after "apt install ...", ARMv6-Bookworm (downloaded 20240512)
0
25
13 May 2024
NanoPi R2S Plus
29
640
13 May 2024
RPI5 - QBittorrent portforward on reboot
0
23
13 May 2024
Open Beta v9.4 | Please help testing and hardening our upcoming release
3
85
12 May 2024
Zigbee2MQTT and Home Assistant
4
141
12 May 2024
50
470
12 May 2024
NanoPC-T6 Image (Single Partition) Kernel Upgrade
26
115
12 May 2024
How to set custom library location for navidrome
12
34
12 May 2024
NordVPN Update Breaks Local Network Access
0
25
12 May 2024
DietPi, Autolaunching SH program on boot
0
21
12 May 2024
Maintain date modified over SMB share
0
23
12 May 2024
Odroid XU4 | Cloudshell 2 not working after Upgrade
72
1876
12 May 2024
[SOLVED] How to install vlc? no DE, just console.
4
2807
11 May 2024
Network state filling up terminal
8
1652
11 May 2024
Create a hotspot when no Access Point available
4
383
11 May 2024
Certbot error on renewal "Unsupported RSA key length: 1024"
4
72
11 May 2024
Latest update broke boot
4
55
11 May 2024
Iam unable to make navidrome scan my external ssd
10
620
11 May 2024
View and Change Upstream DNS Servers when you have Pi-Hole and Unbound installed
7
82
11 May 2024
Allo USBridge Signature No sound through HDMI
11
95
11 May 2024
Dynamic over_voltage
17
235
10 May 2024
[SOLVED] wireguard server not reachable with active nftables
4
972
10 May 2024
DietPi img for Amlogic S905x-s905x3 TVBOX
7
3639
10 May 2024
Nginx reverse proxy... how?
2
67
10 May 2024
