Nextcloud Update & my current Webserver (Lighttpd)
Re: Nextcloud Update & my current Webserver (Lighttpd)
no need to remove everything. Just go into /etc/letsencrypt/ and there you see a couple of sub directories. Just go into each of them one by one and clear the content not needed.
SSH connection has no relation to any SSL/ Letsencrypt config and should stay untouched.
rubinski
Post by rubinski »
I have no clue, what is needed there and what is not. For example inside /etc/letsencrypt/csr I can see a lot of very similar Files like this:
A comparable structure I can find in the Subfolder "Keys".
ok I did a little bit of testing. Let's do following
rm -Rf /etc/letsencrypt/*
dietpi-letsencrypt 1
rubinski
Post by rubinski »
Thank you for your Effort. In fact there has been no negative Effect, when erasing the whole Folder as you suggested.
The Certificate also was successfully generated through
On the other Hand all is still the same, when I uncomment those two Redirect-Rules Lines in
/etc/lighttpd/conf-available/99-dietpi-nextcloud.conf
so that it again results in a non-reachable Webinterface.
viewtopic.php?p=39346#p39346
I then get the same error Messages before, when I do systemctl restart lighttpd.service
dietpi@DietPi:~$ sudo systemctl restart lighttpd.service
Job for lighttpd.service failed because the control process exited with error code.
See "systemctl status lighttpd.service" and "journalctl -xe" for details.
dietpi@DietPi:~$ sudo systemctl status lighttpd.service
● lighttpd.service - Lighttpd Daemon
   Loaded: loaded (/lib/systemd/system/lighttpd.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2021-11-04 22:36:37 CET; 32s ago
  Process: 9788 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255/EXCEPTION)
Just share following again
rubinski
Post by rubinski »
dietpi@DietPi:~$ /usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
2021-11-07 10:14:45: (mod_openssl.c.445) SSL: BIO_read_filename('/etc/letsencrypt/live/MYDOMAIN/combined.pem') failed
2021-11-07 10:14:45: (server.c.1183) Initialization of plugins failed. Going down.
dietpi@DietPi:~$
hm strange. Let's try to disable SSL config for time being. Could you share activated config files
ls -la /etc/lighttpd/conf-enabled/
rubinski
Post by rubinski »
dietpi@DietPi:~$ ls -la /etc/lighttpd/conf-enabled/
total 8
drwxr-xr-x 2 root root 4096 Jul 27 08:59 .
drwxr-xr-x 4 root root 4096 Oct  4  2020 ..
lrwxrwxrwx 1 root root   33 Sep 16  2020 10-fastcgi.conf -> ../conf-available/10-fastcgi.conf
lrwxrwxrwx 1 root root   33 Sep 16  2020 10-rewrite.conf -> ../conf-available/10-rewrite.conf
lrwxrwxrwx 1 root root   37 Sep 16  2020 15-fastcgi-php.conf -> ../conf-available/15-fastcgi-php.conf
lrwxrwxrwx 1 root root   38 Sep 21  2020 50-dietpi-https.conf -> ../conf-available/50-dietpi-https.conf
lrwxrwxrwx 1 root root   37 Sep 21  2020 98-dietpi-hsts.conf -> ../conf-available/98-dietpi-hsts.conf
lrwxrwxrwx 1 root root   47 Sep 21  2020 98-dietpi-https_redirect.conf -> ../conf-available/98-dietpi-https_redirect.conf
lrwxrwxrwx 1 root root   45 Sep 16  2020 99-dietpi-dav_redirect.conf -> ../conf-available/99-dietpi-dav_redirect.conf
lrwxrwxrwx 1 root root   42 Sep 16  2020 99-dietpi-nextcloud.conf -> ../conf-available/99-dietpi-nextcloud.conf
lrwxrwxrwx 1 root root   58 Jul 27 08:59 99-dietpi-pihole-block_public_admin.conf -> ../conf-available/99-dietpi-pihole-block_public_admin.conf
lrwxrwxrwx 1 root root   39 Jul 27 08:59 99-dietpi-pihole.conf -> ../conf-available/99-dietpi-pihole.conf
lrwxrwxrwx 1 root root   38 Sep 16  2020 99-unconfigured.conf -> ../conf-available/99-unconfigured.conf
dietpi@DietPi:~$
lighttpd-disable-mod dietpi-https dietpi-hsts dietpi-https_redirect
if there are still error, let's check configuration again
rubinski
Post by rubinski »
the System did it without any comments, but:
2021-11-07 17:17:41: (mod_openssl.c.445) SSL: BIO_read_filename('/etc/letsencrypt/live/MYDOMAIN/combined.pem') failed
2021-11-07 17:17:41: (server.c.1183) Initialization of plugins failed. Going down.
This is, what sudo journalctl -xe gives me:
dietpi@DietPi:~$ sudo journalctl -xe
-- Logs begin at Sun 2021-11-07 14:18:59 CET, end at Sun 2021-11-07 17:27:46 CET. --
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[INFO ] Using default X.509 key file: /etc/xrdp/key.pem
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[DEBUG] TLSv1.3 enabled
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[DEBUG] TLSv1.2 enabled
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[DEBUG] Security layer: requested 3, selected 0
Nov 07 17:18:52 DietPi xrdp[5827]: (5827)(1995405568)[DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.178.111 port 3389)
Nov 07 17:18:52 DietPi systemd[1]: Started Lighttpd Daemon.
-- Subject: A start job for unit lighttpd.service has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit lighttpd.service has finished successfully.
-- The job identifier is 2673.
