Transmission settings? Topic is solved
kannz
Re: Transmission settings?
Post by kannz »
Thank you very much I can now use transmission again. it must of been due to a new version? I think it updated from version 2.94 to version 3. oh also im on DietPi v7.8.2. remember if anyone else is having a problem with this. make sure to change the username/password its in the same config file when you go to add the ip to the whitelist or turn it off.
looks like using v3 our adjustments we do on install are not taken into account. Will need to have a look what changed on the new version.
EDIT:
PR up: https://github.com/MichaIng/DietPi/pull/4972
