Failed to upgrade from Debian Buster to Bullseye
Re: Failed to upgrade from Debian Buster to Bullseye
does FroFTP completed now? Because you stated there are some issues with?
could you run apt update && apt upgrade and poste the output
alleyu2
Post by alleyu2 »
I uninstalled Proftpd before upgrading to Bullseye. So didn't face that issue.
alleyu2
Post by alleyu2 »
This did the trick and solved the issue.
apt install gcc-8-base
Doing a full upgrade now. Will update you if I come across any issues. Fingers crossed :P
yes there is a setting in ProFTP config file that would need to be changes before. Basically not a big deal :)
sed -i '/IdentLookups/c\<IfModule mod_ident.c>\nIdentLookups off\n</IfModule>' /etc/proftpd/proftpd.conf
On new installations we already have that implemented with DietPi 7.5. I guess the blog would need to be extended by this as well.
alleyu2
Post by alleyu2 »
Successfully migrated to Bullyseye. Facing issue with lighttpd
/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
2021-09-16 17:12:52: plugin.c.195) dlopen() failed for: /usr/lib/lighttpd/mod_openssl.so /usr/lib/lighttpd/mod_openssl.so: cannot open shared object file: No such file or directory
2021-09-16 17:12:52: server.c.1238) loading plugins finally failed
It has to do with SSL configured. I don't seem to have this module "mod_openssl.so". Has something changed in Bullseye?
alleyu2
Post by alleyu2 »
this worked
 apt install lighttpd-mod-openssl
Yes this is required now
