Pivpn
Re: Pivpn
if it is working, probably.
DPINoob786
Re: Pivpn
Post by DPINoob786 »
i am going to try this and i will let you know what happens i will be able to do so later on tonight. :)
DPINoob786
Re: Pivpn
i have tried this it works on the command line interface but my clients still cannot connect to the vpn any idea as to why ? or what i can use to fix it ?
Re: Pivpn
what is the status of OpenVPN right after reboot
systemctl status openvpn.service
DPINoob786
Re: Pivpn
it says it is active when i have checked
Re: Pivpn
this is the case right after reboot?
DPINoob786
Re: Pivpn
also would you be able to let me know how to increase the download and upload speed over the vpn cause when my clients are downloading files or uploading it is extremely slow
Re: Pivpn
I'm not a OpenVPN expert. Might be better to check on a VPN specialized board. As well WireGuard has way better performance compare to OpenVPN
