przemko
Posts: 170 Joined: Sun Mar 15, 2020 5:40 pm
Post
by przemko » Wed Dec 02, 2020 7:30 am
Hi, today after connection lost I try to restart my Raspberry and it wont run
Is it possible to rescue my Dietpi installation?
Regards.
Posts: 4205 Joined: Sat Nov 16, 2019 12:49 am
Post
by Joulinar » Wed Dec 02, 2020 12:18 pm
best would be to use a USB connector and plug your SD card into another Linux box to be able to run some file system checks
przemko
Post
by przemko » Wed Dec 02, 2020 6:53 pm
I put my sc-card and start `badblocks -n -v`.
Boot partition went fast:
sudo badblocks -n -v /dev/mmcblk0p1
Poszukiwanie wadliwych bloków w trybie z niedestruktywnym zapisem
Od bloku 0 do 262143
Testowanie wzorcem losowym: 0
Przebieg zakończony, znaleziono 0 wadliwych bloków (błędów: 0/0/0)
0 Errors.
Rootfs going very slow:
sudo badblocks -n -v /dev/mmcblk0p2
Od bloku 0 do 30900735
12339828
12339829
12339830
12339831
It is OK, or stop that test and start another? Do You recommend something different?
Regards.
Post
by Joulinar » Wed Dec 02, 2020 7:14 pm
hi,
I guess you placed the SD card into another system via USB port? If yes, you would need to check
/dev/sda1 and
/dev/sda2 .
/dev/mmcblk0 is the SD card you are booting from
To show all devices connected
przemko
Post
by przemko » Wed Dec 02, 2020 8:16 pm
I connect sd-card to card reader in my laptop.
When test ends I have 4 corrupted blocks.
12339828
12339829
12339830
12339831
Przebieg zakończony, znaleziono 4 wadliwych bloków (błędów: 4/0/0).
I also burn Dietpi image on new sd-card and put it to my Rpi4. I will try to restore my config from HDD. Can I rub Dietpi-Backup and restore?
Regards.
Post
by Joulinar » Wed Dec 02, 2020 9:11 pm
well you could give it a try. Where is the backup stored? On SD Card or HDD?
przemko
Post
by przemko » Wed Dec 02, 2020 9:19 pm
I store backup on HDD, also move `dietpi_userdata` to HDD.
Post
by Joulinar » Wed Dec 02, 2020 9:24 pm
ok that might work. But I need to say I never tested this procedure. You would need to verify that user data is linked correctly afterwards.
przemko
Post
by przemko » Wed Dec 02, 2020 9:59 pm
Can You tell me what to do first: link userddata to HDD and then restore backup, and when to install apps? Or dietpi_backup will restore my apps?
Edit. So I just select location `/mint/Toshiba/dietpi_backup` search for backup and restore. Then after all I reboot. System stop at:
przemko on Wed Dec 02, 2020 11:14 pm, edited 1 time in total.
Post
by Joulinar » Wed Dec 02, 2020 11:14 pm
usually it should be enough to mount the HDD and perform a restore. Everything should be restored as it was saved before. This should include the link of DietPi User data directory. If possible try to do a backup of your HDD to avoid issues if thinks will go wrong. Better to be on safe side.
