8
114014
2 March 2025
Home Assistant causing dietpi to hung
32
150
5 July 2025
Rock5a Fan control
5
32
5 July 2025
Losing Global IPv6 on OPI5+ using Docker Peertube
0
4
5 July 2025
Is Diet Pi available for the Odroid C5?
2
18
5 July 2025
Can't change fuguhub webdav folder
2
8
4 July 2025
(Beelink) AMD AI9HX370 wrong temperature with cpu command (htop is OK)
6
31
3 July 2025
Linux-image-amd64 - The following packages have been kept back
11
44
3 July 2025
MEGAcmd on DietPi
4
37
3 July 2025
No static Mac address since v9.7.1
40
412
2 July 2025
Home Assistant Launch Error [cannot import name OrPattern]
4
34
2 July 2025
DietPi on BananaPi M5 bootdelay when headless
12
127
2 July 2025
Auto setup for headless installation fails to start
7
32
2 July 2025
ROCK(Pro)64 won't boot with Linux 6.12
41
527
1 July 2025
Laptop installer not detecting HDD
1
21
1 July 2025
UPMPDCLI instllation
2
28
1 July 2025
Randomly can't SSH into my DietPi install but can ping
3
36
1 July 2025
ACPI - What would be the best way to install it?
11
51
30 June 2025
Sd card to SSD migration on Raspberrypi4. (rpi-clone or..?)
1
23
30 June 2025
Raspberry PI 4 Argon One M.2 case, M.2 SSD inaccessible after a random amount of time
11
68
30 June 2025
Moonlight removed from Software list?
8
65
29 June 2025
No autostart to Desktop as user
17
98
29 June 2025
RPI Zero v1 Fails boot with over_voltage=-2 -200mV energy savings setting in dietpi-config
0
12
27 June 2025
How to Connect to a Samba Server
8
100
27 June 2025
No sound card detected for Opi zero 2w
127
2376
27 June 2025
Debian 12 ARM64 on Apple Silicon with UTM converted to DietPi - Fails
6
224
27 June 2025
Unbound dietpi.conf - do we need module-config line?
2
32
27 June 2025
How to backup an entire SD Card over a network
3
59
27 June 2025
Help with Chromium autostart
4
36
27 June 2025
AdguardHome + Unbound unstable connections and cannot load websites sometimes
59
352
25 June 2025
