DietPi version information Topic is solved
cpcnw
Re: DietPi version information
Post by cpcnw »
Looks like the number of updated packages available that apt finds is written out to;
/run/dietpi/.apt_updates
Very useful :)
yes the sym linc is still in place on older images to ensure compatibility to the new DietPi script code. On newer images, it did not exist at all. Therefore it's recommended to use /boot/dietpi
cpcnw
Post by cpcnw »
What is the best / most reliable way to check for a new version being released?
You could try to read following files
/run/dietpi/.update_available
If they are not present, no update or apt package update are available 8)
cpcnw
Post by cpcnw »
Works great thanks!
function GetAptUpdates(){
                        $aptud=exec("cat /run/dietpi/.apt_updates");
                        if(empty($aptud)){echo '0';}
                        else{echo $aptud;}}
In html
There are <?php GetAptUpdates();?> updated packages available
