4
112175
29 October 2023
NanoPi NEO running unstable since latest update
5
73
2 May 2024
11
163
2 May 2024
[Raspberry Pi 5] Banding/Dithering on Images in Chromium Kiosk
0
14
2 May 2024
Question on Media Server
0
9
2 May 2024
Share of Unofficial DietPi - Radxa Zero 3W
44
925
2 May 2024
Alsa Mixer MAX98357
1
54
2 May 2024
App nextcloud iOS: browser is not supported
14
89
2 May 2024
Raspberry PI 5 pci boot with nvme, error with 'rpi-eeprom'
7
44
2 May 2024
Allo USBridge Signature No sound through HDMI
3
29
2 May 2024
Umm, Parallels arm64 images for download
0
20
2 May 2024
Error with balena etcher and dietpi image
1
20
1 May 2024
Unable to connect to IPVanish: End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive
1
82
1 May 2024
Switch from lighttpd to nginx wihout reinstalling nextcloud
0
18
1 May 2024
25
186
1 May 2024
Where to add kernel command line options on Odroid C2 running Dietpi latest
1
30
1 May 2024
How to manually install Amiberry 5.70 on Dietpi 9.30 thanks
2
29
1 May 2024
Backup location not being used by dietpi-update
3
32
1 May 2024
Raspberry Pi 5: Xorg issues - Chromium Autostart (Cannot run in framebuffer mode)
11
203
30 April 2024
Wordpress install; Unsupported special character in password causing SQL error
3
65
30 April 2024
Whilst Plex is working shutdown all other services
8
77
30 April 2024
DietPi fresh install WiFi issues on Raspberry Pi Zero 2 W
14
699
30 April 2024
Weird error on startup with caja
9
565
30 April 2024
Kindly review my custom user script for pre/post DietPi install automation!
2
82
30 April 2024
Dietpi-VPN GATEWAY with Pivpn server and Pihole
33
1108
30 April 2024
Dietpi x64 Migrate dietpi_userdata to a newer larger drive
1
49
29 April 2024
SSH issue using key - root works, second user don't
2
44
29 April 2024
Problems with the .htaccess file after updating nextcloud on an orangepi5
3
53
29 April 2024
NanoPi R5S - Boot from NVMe
24
1266
29 April 2024
DietPi on RK3328 Rk3318 TVBOX
8
3448
28 April 2024
