4
113312
29 2023
Cockpit configuration problems
0
2
28 2024
I can see AdGuard Home correctly processing queries, but every website ends with DNS_PROBE_FINISHED_BAD_CONFIG
6
16
28 2024
Kodi not working on RPi5
6
72
28 2024
No Wi-Fi adapter detected on built in Orange Pi Zero3 first boot
4
18
28 2024
Missing firmware
1
4
28 2024
Rock5B Not Functioning Properly After DietPi-Update
1
13
28 2024
Restore backup on intial boot - should I user automatic software install or not?
2
8
27 2024
Odroid C2, boot from SD, root from SSD
6
79
27 2024
Orange Pi 5 | Boot from SATA M.2 SSD
45
4490
27 2024
OpenMediaVault in dietpi Rp4
4
28
27 2024
Kodi upgrade to version 20 yet?
9
1591
27 2024
Nanopi R5S does not boot Dietpi from SD after kernel update
2
21
26 2024
Php8.2-fpm php-fpm8.2: error while loading shared libraries: /lib/aarch64-linux-gnu/libssl.so.3
4
30
25 2024
Como Crear Indexador de Archivos en Dietpi Con H5ai y Nginx
23
68
26 2024
6.6.37 current meson64, verliert alle usb geräte
0
11
26 2024
Declarative and immutable DietPi
1
24
26 2024
OrangePi Zero 2W Allwinner H618 will not boot current DietPi new install from SD card
2
39
26 2024
Support for NanoPi R2C?
28
12173
26 2024
New user with openSSH
7
43
25 2024
Issue downloading container image - kernel architecture vs. userspace architecture - switch back to 32bit?
3
10
25 2024
Firmware rtl8761bu is missing from armbian-firmware package
3
33
25 2024
Nano pi r5c not booting from EMmc anymore
7
51
24 2024
Ethernet not working in the new version of Orange Pi 3B
16
574
24 2024
Access dietpi via Thunar?
2
17
23 2024
Can't access nextcloud from LAN
29
1592
23 2024
Odd Boards and Dodgy Images
1
22
22 2024
Updating DietPi kernel to 6.5.0
14
486
22 2024
TigerVNC Server crashes regularly
4
41
21 2024
When I install sonarr via Dietpi-software: is v3 or v4 installed?
5
37
21 2024
