Cockpit configuration problems
I installed “cockpit”, A systemd web based user interface for Linux servers.
Only one service doesn’t work: “nvmf-autoconnect.service”: Connect NVMe-oF subsystems automatically during boot. This is the error reported:
/lib/systemd/system/nvmf-autoconnect.service
ConditionPathExists=/etc/nvme/discovery.conf not satisfied
/etc/nvme/discovery.conf:
# Used for extracting default parameters for discovery
# Example:
# --transport=<trtype> --traddr=<traddr> --trsvcid=<trsvcid> --host-traddr=<host-traddr> --host-iface=<host-iface>``
I should configure these parameters, but I have no idea what I should enter or where to get the info about the entries in the file.
Thanks for the help
I don’t think we are able to answer your question. Better to as developers of this software.
is a good idea. i will try to contact the developer and if successful i will post the solution so that it can be helpful to others.
