Firmware rtl8761bu is missing from armbian-firmware package
$ cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=7
G_DIETPI_VERSION_RC=1
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
$ echo $G_DISTRO_NAME $G_RASPBIAN
bookworm
$ uname --all
Linux bar.home 6.1.75-vendor-rk35xx #1 SMP Thu Jul 25 14:36:35 UTC 2024 aarch64 GNU/Linux
$ dpkg --print-architecture
arm64
$ echo $G_HW_MODEL_NAME
NanoPi 6 series (aarch64)
  1. Install armbian-firmware
  • Error loading bluetooth drivers for my usb dongle, the following is visible with dmesg: Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8761bu_fw.bin not found
  • I expect to see the drivers at Making sure you're not a bot!
  • rtl8761bu_config.bin and rtl8761bu_fw.bin are missing
  • The bluetooth adapter had been working with earlier kernel versions, I don’t know which specific update caused it to stop working.
  • If I download them directly from the kernel source tree into /usr/lib/firmware/rtl_bt then I’m able to use my usb bluetooth adapter.
  • The specific bluetooth adapter is this Edimax BY-8500 from Amazon.
something @MichaIng would need to have a look into
Jep, known issue. Not yet sure how to solve best. Easiest is certainly to add a little hack to our Armbian fork, which just downloads these particular missing Realtek Bluetooth firmware blobs form Linux sources, instead of forking their firmware repository as well.
Thanks for the reply! Is there a tracking issue I could follow to know when you have something in place that is expected to work? In the meantime I’ll just keep downloading the couple of firmware files as needed.
