Test 5, same again please guys if you get a chance:
https://github.com/Fourdee/DietPi/issue ... -267820697
Thanks!
XU4 CloudShell Stopped Working
Re: XU4 CloudShell Stopped Working
Here's output
After test 4, cloudshell crashed and after test 5 is still not working. No error message is provided. Cloudshell monitor is showing a zoomed bash. I've tried to reboot and start it again via dietpi-cloudshell but didn't worked.
root@DietPi:~# cat << _EOF_ > /etc/systemd/system/dietpi-cloudshell.service
> [Unit]
> Description=dietpi-cloudshell on main screen
> [Service]
> Type=forking
> StandardOutput=tty
> ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave off --cursor off
> ExecStart=/bin/bash -c '/DietPi/dietpi/dietpi-cloudshell 1 &'
> ExecStop=/usr/bin/setterm --reset
> ExecStop=/bin/bash -c '/DietPi/dietpi/func/dietpi-notify 0 DietPi-Cloudshell t erminated, have a nice day!'
> [Install]
> WantedBy=multi-user.target
> _EOF_
root@DietPi:~# systemctl daemon-reload
root@DietPi:~# #Grab updated cloudshell
root@DietPi:~# wget https://raw.githubusercontent.com/Fourdee/DietPi/testing/die tpi/dietpi-cloudshell -O /DietPi/dietpi/dietpi-cloudshell
--2016-12-18 18:57:57-- https://raw.githubusercontent.com/Fourdee/DietPi/testin g/dietpi/dietpi-cloudshell
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.192.1 33, 151.101.128.133, 151.101.64.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.192. 133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 48981 (48K) [text/plain]
Saving to: ‘/DietPi/dietpi/dietpi-cloudshell’
/DietPi/dietpi/diet 100%[===================>] 47.83K 106KB/s in 0.5s
2016-12-18 18:57:58 (106 KB/s) - ‘/DietPi/dietpi/dietpi-cloudshell’ saved [48981 /48981]
root@DietPi:~# systemctl stop dietpi-cloudshell
root@DietPi:~# systemctl start dietpi-cloudshell
root@DietPi:~# systemctl status dietpi-cloudshell -l
● dietpi-cloudshell.service - dietpi-cloudshell on main screen
Loaded: loaded (/etc/systemd/system/dietpi-cloudshell.service; disabled; vend
Active: active (running) since Sun 2016-12-18 18:57:58 CET; 1s ago
Process: 19276 ExecStart=/bin/bash -c /DietPi/dietpi/dietpi-cloudshell 1 & (co
Process: 19273 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersav
Main PID: 19277 (dietpi-cloudshe)
CGroup: /system.slice/dietpi-cloudshell.service
├─19277 /bin/bash /DietPi/dietpi/dietpi-cloudshell 1
└─19339 sleep 0.2
Dec 18 18:57:58 DietPi systemd[1]: Starting dietpi-cloudshell on main screen...
Dec 18 18:57:58 DietPi systemd[1]: Started dietpi-cloudshell on main screen.
lines 1-12/12 (END)...skipping...
Loaded: loaded (/etc/systemd/system/dietpi-cloudshell.service; disabled; vendor preset: enabled)
Process: 19276 ExecStart=/bin/bash -c /DietPi/dietpi/dietpi-cloudshell 1 & (code=exited, status=0/SUCCES
Process: 19273 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave off --cursor off (code=e
└─19339 sleep 0.2
Thanks for results.Fabian0587 wrote:Cloudshell monitor is showing a zoomed bash. I've tried to reboot and start it again via dietpi-cloudshell but didn't worked.
It appears attempting to set cursor "off" on your devices are causing the issue. Regardless of tput or setterm. I'll need to take a deeper look into this, ideally find out why tput and setterm are failing to set cursor.
Just wish I could replicate on my XU4, so expect further tests to come
Unfortunately I won't be able to do further tests until thursday...i'll post all next tests results asap. Hope that others can help you meanwhile!
EDIT: Rooted has confirmed test 10 works, if others could confirm, i'd be grateful
10 https://github.com/Fourdee/DietPi/issue ... -267981389
Sorry for my late reply.
I can confirm that test 10 worked...and update too!
Thank you Fourdee!
Thank you Fourdee!
