Bug in new Dietpi release ? Bug in drive mount ? Topic is solved
Re: Bug in new Dietpi release ? Bug in drive mount ?
well if you would create such a cron job, it would basically mean to deactivate Synology hibernate function.
Isn't it possible to disable hibernate in Synology directly? E.g. for local drives one could simply disable idle timeout via dietpi-drive_manager (hdparm / /etc/hdparm.conf), instead of having an idle timeout enabled but then making it ineffective via cronjob/systemd timer or such...
Yes you can disable hibernate function in DSM directly. But @echable would like to keep the hibernate option active to same power as the NAS is not used all the time.
Question is, what happen if the Synology is going into Hibernate mode. Will DietPi loose the connection? Will the connection be reestablished once used?
I will do a test over night and mount my Synology CIFS(SMB) Share to my RPi3B+. Let's see how it looks like tomorrow.
So my RPi was running whole night with a mounted share from my Synology. I have seen that my Synology disk was going to hibernate without issues. The share was still mounted on the RPi. It did not get lost. Access was still possible this morning. I did not find any issues in journalctl regarding the mount.
Bottome line. A mounted Synology Share is not preventing the Hibernate Mode as well as it stays connected/accessible on DietPi.
