I use PiVPN with Wireguard on my Raspberry Pi Zero 2 W. Until the day before yesterday everything works like a charm but now if I connect to my VPN outside from the LAN I can’t navigate even if I try to visit 1.1.1.1.
I also use Pi-hole with Unbound that acts like DHCP and DNS server.
Installed Dietpi version 8.2.2, what’s happened?
are you sure your DDNS is up-to-date, pointing to your external IP address correctly?`
Do you see an actual handshake for your client? If I’m not mistaken, PiVPN is offer a command to view this.
I’ve static public IP address and I can connect correctly to VPN, but I can’t surf the web when connected or I can’t ping devices in LAN (the Pi too).
I don’t know how to check this…
pivpn -d could show some helpful info
Pay attention before posting:
:::: WARNING: This script should have automatically masked sensitive ::::
:::: information, however, still make sure that PrivateKey, PublicKey ::::
:::: and PresharedKey are masked before reporting an issue. An example key ::::
:::: that you should NOT see in this log looks like this: ::::
:::: YIAoJVsdIeyvXfGGDDadHh6AxsMRymZTnnzZoAb9cxRe ::::
And you can also check the log of your VPN client, maybe there is some hint in there.
At https://docs.pivpn.io/faq/ are also some useful tips for troubleshooting connection issues, but this can be a bit overwhelming for unexperienced users.
Unfortunately the WireGuard Client app will always show connected, even if it isn’t correct. Best is to have a look into your Client app. At least on my Android mobile phone, I could open/save the application loge file. Usually there you should be able to see if the VPN tunnel could be established or not. Unfortunately the WireGuard server did not offer such logs.
This is the output of pivpn -d:
::: Generating Debug Output
:::: PiVPN debug ::::
:::: Latest commit ::::
Branch: master
Commit: f80b0a7962d91862132c0a4abd65c1e67bd37bd7
Author: 4s3ti
Date: Fri Dec 3 21:41:13 2021 +0100
Summary: Update Changelog
:::: Installation settings ::::
PLAT=Debian
OSCN=bullseye
USING_UFW=0
IPv4dev=wlan0
install_user=dietpi
install_home=/home/dietpi
VPN=wireguard
pivpnPORT=51xxx
pivpnDNS1=10.6.0.1
pivpnDNS2=
pivpnHOST=REDACTED
INPUT_CHAIN_EDITED=0
FORWARD_CHAIN_EDITED=0
pivpnPROTO=udp
pivpnMTU=1420
pivpnDEV=wg0
pivpnNET=10.6.0.0
subnetClass=24
ALLOWED_IPS="0.0.0.0/0, ::0/0"
UNATTUPG=0
INSTALLED_PACKAGES=(wireguard-tools qrencode)
:::: Server configuration shown below ::::
[Interface]
PrivateKey = server_priv
Address = 10.6.0.1/24
MTU = 1420
ListenPort = 51xxx
### begin Find-X2-Pro-di-Ivan ###
[Peer]
PublicKey = Find-X2-Pro-di-Ivan_pub
PresharedKey = Find-X2-Pro-di-Ivan_psk
AllowedIPs = 10.6.0.2/32
### end Find-X2-Pro-di-Ivan ###
### begin MBA-di-Ivan ###
[Peer]
PublicKey = MBA-di-Ivan_pub
PresharedKey = MBA-di-Ivan_psk
AllowedIPs = 10.6.0.3/32
### end MBA-di-Ivan ###
### begin iMac-di-Ivan ###
[Peer]
PublicKey = iMac-di-Ivan_pub
PresharedKey = iMac-di-Ivan_psk
AllowedIPs = 10.6.0.4/32
### end iMac-di-Ivan ###
### begin xps-9570 ###
[Peer]
PublicKey = xps-9570_pub
PresharedKey = xps-9570_psk
AllowedIPs = 10.6.0.6/32
### end xps-9570 ###
### begin black-bite ###
[Peer]
PublicKey = black-bite_pub
PresharedKey = black-bite_psk
AllowedIPs = 10.6.0.5/32
### end black-bite ###
:::: Client configuration shown below ::::
[Interface]
PrivateKey = Find-X2-Pro-di-Ivan_priv
Address = 10.6.0.2/24
DNS = 10.6.0.1
[Peer]
PublicKey = server_pub
Endpoint = REDACTED:51xxx
AllowedIPs = 0.0.0.0/0, ::0/0
:::: Recursive list of files in ::::
::::[4m/etc/wireguard shown below ::::
/etc/wireguard:
configs
keys
wg0.conf
/etc/wireguard/configs:
black-bite.conf
clients.txt
Find-X2-Pro-di-Ivan.conf
iMac-di-Ivan.conf
MBA-di-Ivan.conf
xps-9570.conf
/etc/wireguard/keys:
black-bite_priv
black-bite_psk
black-bite_pub
iMac-di-Ivan_priv
iMac-di-Ivan_psk
iMac-di-Ivan_pub
MBA-di-Ivan_priv
MBA-di-Ivan_psk
MBA-di-Ivan_pub
server_priv
server_pub
xps-9570_priv
xps-9570_psk
xps-9570_pub
:::: Self check ::::
:: [OK] IP forwarding is enabled
:: [OK] Iptables MASQUERADE rule set
:: [OK] WireGuard is running
:: [OK] WireGuard is enabled (it will automatically start on reboot)
:: [OK] WireGuard is listening on port 51xxx/udp
:::: Having trouble connecting? Take a look at the FAQ:
:::: https://docs.pivpn.io/faq
:::: Debug complete ::::
::: Debug output completed above.
::: Copy saved to /tmp/debug.log
If I connect to VPN from inside my LAN everything works.
This is log file of Android app:
--------- beginning of events
03-17 16:37:41.007 5161 5161 I wm_on_create_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,performCreate]
03-17 16:37:41.014 5161 5161 I wm_on_start_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,handleStartActivity]
03-17 16:37:41.024 5161 5161 I wm_on_resume_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,RESUME_ACTIVITY]
03-17 16:37:41.038 5161 5161 I wm_on_top_resumed_gained_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,topStateChangedWhenResumed]
03-17 16:37:41.038 5161 5161 I wm_on_restart_called: [140809424,com.wireguard.android.activity.MainActivity,performRestartActivity]
03-17 16:37:41.039 5161 5161 I wm_on_start_called: [140809424,com.wireguard.android.activity.MainActivity,handleStartActivity]
03-17 16:37:41.249 5161 5161 I wm_on_top_resumed_lost_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,topStateChangedWhenResumed]
03-17 16:37:41.253 5161 5161 I wm_on_paused_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,performPause]
03-17 16:37:41.262 5161 5161 I wm_on_resume_called: [140809424,com.wireguard.android.activity.MainActivity,LIFECYCLER_RESUME_ACTIVITY]
03-17 16:37:41.263 5161 5161 I wm_on_paused_called: [140809424,com.wireguard.android.activity.MainActivity,performPause]
03-17 16:37:41.263 5161 5161 I wm_on_stop_called: [140809424,com.wireguard.android.activity.MainActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:37:41.265 5161 5161 I wm_on_destroy_called: [140809424,com.wireguard.android.activity.MainActivity,performDestroy]
03-17 16:37:41.327 5161 5161 I wm_on_stop_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:37:41.327 5161 5161 I wm_on_destroy_called: [218546682,com.wireguard.android.activity.TunnelToggleActivity,performDestroy]
03-17 16:37:51.273 5161 5161 I wm_on_create_called: [240327579,com.wireguard.android.activity.MainActivity,performCreate]
03-17 16:37:51.278 5161 5161 I wm_on_start_called: [240327579,com.wireguard.android.activity.MainActivity,handleStartActivity]
03-17 16:37:51.279 5161 5161 I wm_on_resume_called: [240327579,com.wireguard.android.activity.MainActivity,RESUME_ACTIVITY]
03-17 16:37:51.286 5161 5161 I wm_on_top_resumed_gained_called: [240327579,com.wireguard.android.activity.MainActivity,topStateChangedWhenResumed]
03-17 16:37:54.828 5161 5161 I menu_item_selected: [0,Impostazioni]
03-17 16:37:54.848 5161 5161 I wm_on_top_resumed_lost_called: [240327579,com.wireguard.android.activity.MainActivity,topStateChangedWhenResumed]
03-17 16:37:54.848 5161 5161 I wm_on_paused_called: [240327579,com.wireguard.android.activity.MainActivity,performPause]
03-17 16:37:54.862 5161 5161 I wm_on_create_called: [227398048,com.wireguard.android.activity.SettingsActivity,performCreate]
03-17 16:37:54.875 5161 5161 I wm_on_start_called: [227398048,com.wireguard.android.activity.SettingsActivity,handleStartActivity]
03-17 16:37:54.876 5161 5161 I wm_on_resume_called: [227398048,com.wireguard.android.activity.SettingsActivity,RESUME_ACTIVITY]
03-17 16:37:54.882 5161 5161 I wm_on_top_resumed_gained_called: [227398048,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:37:55.210 5161 5161 I wm_on_stop_called: [240327579,com.wireguard.android.activity.MainActivity,STOP_ACTIVITY_ITEM]
03-17 16:37:56.735 5161 5161 I wm_on_top_resumed_lost_called: [227398048,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:37:56.737 5161 5161 I wm_on_paused_called: [227398048,com.wireguard.android.activity.SettingsActivity,performPause]
03-17 16:37:56.752 5161 5161 I wm_on_create_called: [46008624,com.wireguard.android.activity.LogViewerActivity,performCreate]
03-17 16:37:56.753 5161 5161 I wm_on_start_called: [46008624,com.wireguard.android.activity.LogViewerActivity,handleStartActivity]
03-17 16:37:56.753 5161 5161 I wm_on_resume_called: [46008624,com.wireguard.android.activity.LogViewerActivity,RESUME_ACTIVITY]
03-17 16:37:56.757 5161 5161 I wm_on_top_resumed_gained_called: [46008624,com.wireguard.android.activity.LogViewerActivity,topStateChangedWhenResumed]
03-17 16:37:57.089 5161 5161 I wm_on_stop_called: [227398048,com.wireguard.android.activity.SettingsActivity,STOP_ACTIVITY_ITEM]
03-17 16:38:21.536 5161 5161 I wm_on_top_resumed_lost_called: [46008624,com.wireguard.android.activity.LogViewerActivity,topStateChangedWhenResumed]
03-17 16:38:21.538 5161 5161 I wm_on_paused_called: [46008624,com.wireguard.android.activity.LogViewerActivity,performPause]
03-17 16:38:21.591 5161 5161 I wm_on_restart_called: [227398048,com.wireguard.android.activity.SettingsActivity,performRestartActivity]
03-17 16:38:21.591 5161 5161 I wm_on_start_called: [227398048,com.wireguard.android.activity.SettingsActivity,handleStartActivity]
03-17 16:38:21.592 5161 5161 I wm_on_resume_called: [227398048,com.wireguard.android.activity.SettingsActivity,RESUME_ACTIVITY]
03-17 16:38:21.592 5161 5161 I wm_on_top_resumed_gained_called: [227398048,com.wireguard.android.activity.SettingsActivity,topWhenResuming]
03-17 16:38:21.855 5161 5161 I wm_on_stop_called: [46008624,com.wireguard.android.activity.LogViewerActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:38:21.856 5161 5161 I wm_on_destroy_called: [46008624,com.wireguard.android.activity.LogViewerActivity,performDestroy]
03-17 16:38:23.412 5161 5161 I wm_on_top_resumed_lost_called: [227398048,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:38:23.413 5161 5161 I wm_on_paused_called: [227398048,com.wireguard.android.activity.SettingsActivity,performPause]
03-17 16:38:23.440 5161 5161 I wm_on_restart_called: [240327579,com.wireguard.android.activity.MainActivity,performRestartActivity]
03-17 16:38:23.440 5161 5161 I wm_on_start_called: [240327579,com.wireguard.android.activity.MainActivity,handleStartActivity]
03-17 16:38:23.441 5161 5161 I wm_on_resume_called: [240327579,com.wireguard.android.activity.MainActivity,RESUME_ACTIVITY]
03-17 16:38:23.442 5161 5161 I wm_on_top_resumed_gained_called: [240327579,com.wireguard.android.activity.MainActivity,topWhenResuming]
03-17 16:38:23.686 5161 5161 I wm_on_stop_called: [227398048,com.wireguard.android.activity.SettingsActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:38:23.688 5161 5161 I wm_on_destroy_called: [227398048,com.wireguard.android.activity.SettingsActivity,performDestroy]
03-17 16:38:30.185 5161 5161 I menu_item_selected: [0,Impostazioni]
03-17 16:38:30.209 5161 5161 I wm_on_top_resumed_lost_called: [240327579,com.wireguard.android.activity.MainActivity,topStateChangedWhenResumed]
03-17 16:38:30.210 5161 5161 I wm_on_paused_called: [240327579,com.wireguard.android.activity.MainActivity,performPause]
03-17 16:38:30.218 5161 5161 I wm_on_create_called: [172343366,com.wireguard.android.activity.SettingsActivity,performCreate]
03-17 16:38:30.225 5161 5161 I wm_on_start_called: [172343366,com.wireguard.android.activity.SettingsActivity,handleStartActivity]
03-17 16:38:30.226 5161 5161 I wm_on_resume_called: [172343366,com.wireguard.android.activity.SettingsActivity,RESUME_ACTIVITY]
03-17 16:38:30.232 5161 5161 I wm_on_top_resumed_gained_called: [172343366,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:38:30.537 5161 5161 I wm_on_stop_called: [240327579,com.wireguard.android.activity.MainActivity,STOP_ACTIVITY_ITEM]
03-17 16:38:31.614 5161 5161 I wm_on_top_resumed_lost_called: [172343366,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:38:31.615 5161 5161 I wm_on_paused_called: [172343366,com.wireguard.android.activity.SettingsActivity,performPause]
03-17 16:38:31.633 5161 5161 I wm_on_create_called: [179371109,com.wireguard.android.activity.LogViewerActivity,performCreate]
03-17 16:38:31.633 5161 5161 I wm_on_start_called: [179371109,com.wireguard.android.activity.LogViewerActivity,handleStartActivity]
03-17 16:38:31.633 5161 5161 I wm_on_resume_called: [179371109,com.wireguard.android.activity.LogViewerActivity,RESUME_ACTIVITY]
03-17 16:38:31.638 5161 5161 I wm_on_top_resumed_gained_called: [179371109,com.wireguard.android.activity.LogViewerActivity,topStateChangedWhenResumed]
03-17 16:38:31.989 5161 5161 I wm_on_stop_called: [172343366,com.wireguard.android.activity.SettingsActivity,STOP_ACTIVITY_ITEM]
03-17 16:38:34.744 5161 5161 I menu_item_selected: [0,Esporta file di log]
03-17 16:38:46.822 5161 5161 I wm_on_top_resumed_lost_called: [179371109,com.wireguard.android.activity.LogViewerActivity,topStateChangedWhenResumed]
03-17 16:38:46.823 5161 5161 I wm_on_paused_called: [179371109,com.wireguard.android.activity.LogViewerActivity,performPause]
03-17 16:38:46.839 5161 5161 I wm_on_restart_called: [172343366,com.wireguard.android.activity.SettingsActivity,performRestartActivity]
03-17 16:38:46.839 5161 5161 I wm_on_start_called: [172343366,com.wireguard.android.activity.SettingsActivity,handleStartActivity]
03-17 16:38:46.840 5161 5161 I wm_on_resume_called: [172343366,com.wireguard.android.activity.SettingsActivity,RESUME_ACTIVITY]
03-17 16:38:46.840 5161 5161 I wm_on_top_resumed_gained_called: [172343366,com.wireguard.android.activity.SettingsActivity,topWhenResuming]
03-17 16:38:47.099 5161 5161 I wm_on_stop_called: [179371109,com.wireguard.android.activity.LogViewerActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:38:47.100 5161 5161 I wm_on_destroy_called: [179371109,com.wireguard.android.activity.LogViewerActivity,performDestroy]
03-17 16:38:48.113 5161 5161 I wm_on_top_resumed_lost_called: [172343366,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:38:48.114 5161 5161 I wm_on_paused_called: [172343366,com.wireguard.android.activity.SettingsActivity,performPause]
03-17 16:38:48.134 5161 5161 I wm_on_restart_called: [240327579,com.wireguard.android.activity.MainActivity,performRestartActivity]
03-17 16:38:48.134 5161 5161 I wm_on_start_called: [240327579,com.wireguard.android.activity.MainActivity,handleStartActivity]
03-17 16:38:48.134 5161 5161 I wm_on_resume_called: [240327579,com.wireguard.android.activity.MainActivity,RESUME_ACTIVITY]
03-17 16:38:48.134 5161 5161 I wm_on_top_resumed_gained_called: [240327579,com.wireguard.android.activity.MainActivity,topWhenResuming]
03-17 16:38:48.383 5161 5161 I wm_on_stop_called: [172343366,com.wireguard.android.activity.SettingsActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:38:48.387 5161 5161 I wm_on_destroy_called: [172343366,com.wireguard.android.activity.SettingsActivity,performDestroy]
03-17 16:38:54.878 5161 5161 I wm_on_top_resumed_lost_called: [240327579,com.wireguard.android.activity.MainActivity,topStateChangedWhenResumed]
03-17 16:38:54.900 5161 5161 I wm_on_paused_called: [240327579,com.wireguard.android.activity.MainActivity,performPause]
03-17 16:38:54.939 5161 5161 I wm_on_stop_called: [240327579,com.wireguard.android.activity.MainActivity,STOP_ACTIVITY_ITEM]
03-17 16:40:41.081 5161 5161 I wm_on_create_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,performCreate]
03-17 16:40:41.086 5161 5161 I wm_on_start_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,handleStartActivity]
03-17 16:40:41.093 5161 5161 I wm_on_resume_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,RESUME_ACTIVITY]
03-17 16:40:41.110 5161 5161 I wm_on_top_resumed_gained_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,topStateChangedWhenResumed]
03-17 16:40:41.111 5161 5161 I wm_on_restart_called: [240327579,com.wireguard.android.activity.MainActivity,performRestartActivity]
03-17 16:40:41.111 5161 5161 I wm_on_start_called: [240327579,com.wireguard.android.activity.MainActivity,handleStartActivity]
--------- beginning of system
03-17 16:40:41.111 5161 5161 I Quality : Skipped: false 4
03-17 16:40:41.135 5161 5161 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 3168 getDecorView.162251974
03-17 16:40:41.145 5161 5161 I Quality : Skipped: false 3
03-17 16:40:41.188 5161 5161 I Quality : Skipped: true 3
03-17 16:40:41.308 5161 5161 I Quality : Skipped: false 8
03-17 16:40:41.310 5161 5161 I wm_on_top_resumed_lost_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,topStateChangedWhenResumed]
03-17 16:40:41.310 5161 5161 I wm_on_paused_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,performPause]
03-17 16:40:41.334 5161 5161 I wm_on_resume_called: [240327579,com.wireguard.android.activity.MainActivity,LIFECYCLER_RESUME_ACTIVITY]
03-17 16:40:41.335 5161 5161 I wm_on_paused_called: [240327579,com.wireguard.android.activity.MainActivity,performPause]
03-17 16:40:41.335 5161 5161 I wm_on_stop_called: [240327579,com.wireguard.android.activity.MainActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:40:41.337 5161 5161 I wm_on_destroy_called: [240327579,com.wireguard.android.activity.MainActivity,performDestroy]
03-17 16:40:41.338 5161 5161 V OplusZoomWindowDecorViewHelper: removeZoomView
03-17 16:40:41.343 5161 5161 I Quality : Skipped: true 3
03-17 16:40:41.375 5161 5161 I wm_on_stop_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,LIFECYCLER_STOP_ACTIVITY]
03-17 16:40:41.375 5161 5161 I wm_on_destroy_called: [171013878,com.wireguard.android.activity.TunnelToggleActivity,performDestroy]
03-17 16:40:41.375 5161 5161 V OplusZoomWindowDecorViewHelper: removeZoomView
03-17 16:41:14.714 5161 5161 I Quality : Skipped: true 7
--------- beginning of main
03-17 16:43:01.583 5161 5161 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusDynamicVsyncFeature
03-17 16:43:01.588 5161 5161 I wm_on_create_called: [77025930,com.wireguard.android.activity.MainActivity,performCreate]
03-17 16:43:01.590 5161 5161 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusDynamicVsyncFeature
03-17 16:43:01.596 5161 5161 I wm_on_start_called: [77025930,com.wireguard.android.activity.MainActivity,handleStartActivity]
03-17 16:43:01.597 5161 5161 I wm_on_resume_called: [77025930,com.wireguard.android.activity.MainActivity,RESUME_ACTIVITY]
03-17 16:43:01.606 5161 5161 I wm_on_top_resumed_gained_called: [77025930,com.wireguard.android.activity.MainActivity,topStateChangedWhenResumed]
03-17 16:43:01.607 5161 5161 I Quality : Skipped: false 1
03-17 16:43:01.619 5161 5161 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 3168 getDecorView.92431286
03-17 16:43:01.648 5161 5161 I Quality : Skipped: false 4
03-17 16:43:01.650 5161 5188 D SurfaceComposerClient: VRR [FRTC] client handle [bufferId:18446744073709551615 framenumber:0] [ffffffff, ffffffff]
03-17 16:43:02.758 5161 5234 I WireGuard/GoBackend: Bringing tunnel trmon UP
03-17 16:43:02.761 5161 5234 D WireGuard/GoBackend: Requesting to start VpnService
03-17 16:43:02.832 5161 5234 D WireGuard/GoBackend: Go backend eb6302c
03-17 16:43:02.832 5161 5234 D WireGuard/GoBackend/trmon: Attaching to interface tun0
03-17 16:43:02.832 5161 5234 D WireGuard/GoBackend/trmon: UAPI: Updating private key
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: decryption worker 2 - started
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: encryption worker 1 - started
03-17 16:43:02.833 5161 5257 D WireGuard/GoBackend/trmon: Routine: handshake worker 3 - started
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: decryption worker 1 - started
03-17 16:43:02.833 5161 5257 D WireGuard/GoBackend/trmon: Routine: handshake worker 2 - started
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: handshake worker 1 - started
03-17 16:43:02.833 5161 5257 D WireGuard/GoBackend/trmon: Routine: encryption worker 3 - started
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: encryption worker 2 - started
03-17 16:43:02.833 5161 5257 D WireGuard/GoBackend/trmon: Routine: decryption worker 3 - started
03-17 16:43:02.833 5161 5257 D WireGuard/GoBackend/trmon: Routine: encryption worker 4 - started
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: decryption worker 4 - started
03-17 16:43:02.833 5161 5253 D WireGuard/GoBackend/trmon: Routine: handshake worker 4 - started
03-17 16:43:02.833 5161 5234 D WireGuard/GoBackend/trmon: UAPI: Removing all peers
03-17 16:43:02.833 5161 5364 D WireGuard/GoBackend/trmon: Routine: event worker - started
03-17 16:43:02.833 5161 5257 D WireGuard/GoBackend/trmon: Routine: TUN reader - started
03-17 16:43:02.834 5161 5234 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - UAPI: Created
03-17 16:43:02.834 5161 5234 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - UAPI: Adding allowedip
03-17 16:43:02.834 5161 5234 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - UAPI: Updating endpoint
03-17 16:43:02.834 5161 5234 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - UAPI: Updating preshared key
03-17 16:43:02.835 5161 5234 D WireGuard/GoBackend/trmon: UDP bind has been updated
03-17 16:43:02.836 5161 5234 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - Starting
03-17 16:43:02.836 5161 5234 D WireGuard/GoBackend/trmon: Interface state was Down, requested Up, now Up
03-17 16:43:02.836 5161 5234 D WireGuard/GoBackend/trmon: Device started
03-17 16:43:02.836 5161 5364 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - Routine: sequential sender - started
03-17 16:43:02.836 5161 5364 D WireGuard/GoBackend/trmon: Routine: receive incoming v4 - started
03-17 16:43:02.836 5161 5253 D WireGuard/GoBackend/trmon: Routine: receive incoming v6 - started
03-17 16:43:02.836 5161 5364 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - Routine: sequential receiver - started
03-17 16:43:02.868 5161 5365 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - Sending handshake initiation
03-17 16:43:02.880 5161 5365 D WireGuard/GoBackend/trmon: peer(ECx0…v/lc) - Received handshake response
03-17 16:43:03.802 5161 5161 I menu_item_selected: [0,Impostazioni]
03-17 16:43:03.816 5161 5161 I wm_on_top_resumed_lost_called: [77025930,com.wireguard.android.activity.MainActivity,topStateChangedWhenResumed]
03-17 16:43:03.817 5161 5161 I wm_on_paused_called: [77025930,com.wireguard.android.activity.MainActivity,performPause]
03-17 16:43:03.828 5161 5161 I wm_on_create_called: [234839051,com.wireguard.android.activity.SettingsActivity,performCreate]
03-17 16:43:03.831 5161 5161 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusDynamicVsyncFeature
03-17 16:43:03.838 5161 5161 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusDynamicVsyncFeature
03-17 16:43:03.839 5161 5161 I wm_on_start_called: [234839051,com.wireguard.android.activity.SettingsActivity,handleStartActivity]
03-17 16:43:03.839 5161 5161 I wm_on_resume_called: [234839051,com.wireguard.android.activity.SettingsActivity,RESUME_ACTIVITY]
03-17 16:43:03.844 5161 5161 I wm_on_top_resumed_gained_called: [234839051,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:43:03.845 5161 5161 I Quality : Skipped: false 1
03-17 16:43:03.852 5161 5161 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 3168 getDecorView.29442754
03-17 16:43:03.878 5161 5188 D SurfaceComposerClient: VRR [FRTC] client handle [bufferId:18446744073709551615 framenumber:0] [ffffffff, ffffffff]
03-17 16:43:04.162 5161 5296 D OpenGLRenderer: endAllActiveAnimators on 0xb400007a030d5200 (RippleDrawable) with handle 0xb400007ab0825d40
03-17 16:43:04.166 5161 5161 I wm_on_stop_called: [77025930,com.wireguard.android.activity.MainActivity,STOP_ACTIVITY_ITEM]
03-17 16:43:06.989 5161 5161 I wm_on_top_resumed_lost_called: [234839051,com.wireguard.android.activity.SettingsActivity,topStateChangedWhenResumed]
03-17 16:43:06.990 5161 5161 I wm_on_paused_called: [234839051,com.wireguard.android.activity.SettingsActivity,performPause]
03-17 16:43:06.999 5161 5161 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusDynamicVsyncFeature
03-17 16:43:07.003 5161 5161 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusDynamicVsyncFeature
03-17 16:43:07.005 5161 5161 I wm_on_create_called: [258466013,com.wireguard.android.activity.LogViewerActivity,performCreate]
03-17 16:43:07.006 5161 5161 I wm_on_start_called: [258466013,com.wireguard.android.activity.LogViewerActivity,handleStartActivity]
03-17 16:43:07.006 5161 5161 I wm_on_resume_called: [258466013,com.wireguard.android.activity.LogViewerActivity,RESUME_ACTIVITY]
03-17 16:43:07.010 5161 5161 I wm_on_top_resumed_gained_called: [258466013,com.wireguard.android.activity.LogViewerActivity,topStateChangedWhenResumed]
03-17 16:43:07.010 5161 5161 I Quality : Skipped: false 1
03-17 16:43:07.015 5161 5161 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 3168 getDecorView.245055308
03-17 16:43:07.027 5161 5188 D SurfaceComposerClient: VRR [FRTC] client handle [bufferId:18446744073709551615 framenumber:0] [ffffffff, ffffffff]
03-17 16:43:07.300 5161 5296 D OpenGLRenderer: endAllActiveAnimators on 0xb400007aaf190400 (RippleDrawable) with handle 0xb400007ab0825d40
03-17 16:43:07.323 5161 5161 I wm_on_stop_called: [234839051,com.wireguard.android.activity.SettingsActivity,STOP_ACTIVITY_ITEM]
03-17 16:43:08.962 5161 5161 I menu_item_selected: [0,Esporta file di log]
Seems that there are mutual handshakes so the connection is established.
I believe there should be wg show or something like that showing the last handshake. Apart from that, wireguard is very quiet and won’t maintain any unnecessary communication, unless it is for nat traversing.
pivpn -c should show all connected clients.
This is the pivpn -c output:
root@trmon:~# pivpn -c
::: Connected Clients List :::
Name Remote IP Virtual IP Bytes Received Bytes Sent Last Seen
Find-X2-Pro-di-Ivan 93.xx.40.xx:38xxx 10.6.0.2 455KiB 5,4MiB mar 17 2022 - 16:43:02
MBA-di-Ivan (none) 10.6.0.3 0B 0B (not yet)
iMac-di-Ivan (none) 10.6.0.4 0B 0B (not yet)
xps-9570 (none) 10.6.0.6 0B 0B (not yet)
black-bite (none) 10.6.0.5 0B 0B (not yet)
::: Disabled clients :::
for sake of testing, I connected my Android smartphone (Find-X2-Pro-di-Ivan) to VPN while it was connected to 5G… While connected to VPN it can’t navigate the web nor ping or connect to other devices in LAN.
- make sure the phone tunnels everything to the Pi.
- on the pi check for masquerade on eth interface, that ip_forwarding is enabled, and that nothing is blocking on the firewall.
- I’ve same problem on every device, not just for phone…
- How can I check all these things, please?
- Still, you need to verify that.
- iptables-save -c; cat /proc/sys/net/ipv4/ip_forward
Usually it should be possible to access the DietPi device running PiVPN via IP address 10.6.0.1. Even if IP forwarding is not correctly set.
Output:
# Generated by iptables-save v1.8.7 on Fri Mar 18 13:18:19 2022
*nat
:PREROUTING ACCEPT [208609:25395795]
:INPUT ACCEPT [208384:25361075]
:OUTPUT ACCEPT [100762:8289690]
:POSTROUTING ACCEPT [100762:8289690]
[112:31104] -A POSTROUTING -s 10.6.0.0/24 -o wlan0 -m comment --comment wireguard-nat-rule -j MASQUERADE
COMMIT
# Completed on Fri Mar 18 13:18:19 2022
1
That is correct and there are hits on the firewall with the packets being NATed. You could run a packet capture to see what can be the issue:
apt update; apt install tcpdump; tcpdump -i wlan0 -evn host 8.8.4.4
Then start a ping from a WG client, or try to access from browser the page http://8.8.4.4
better to test with https://1.1.1.1/ instead of 8.8.4.4.
Anyway try to reach the VPN server (on VPN server IP 10.6.0.1) first, before going to try something on internet.
If I try to ping 10.6.0.1 from inside the LAN, I can reach the VPN server but if I try from outside the LAN the server doesn’t respond to ping.
ok let’s try it the other way around.
- Switch your mobile phone to use mobile network
- Activate WireGuard inside the app on your mobile phone
- go to the PiVPN server
- try to ping your mobile phone 10.6.0.2
is it working this way?
Btw: do you have just PiVPN installed or any other VPN solution in addition?
