If you have 0 bytes rx, you don’t have a connection. Check that the keys are installed correctly.
hmm yes indeed connection doesn’t seems to be established correctly. Did you already tried to create a new connection for your mobile phone for testing purposes? Did you checked vpn port correctly forward to your VPN server?
I deleted my phone from clients and readded and now it seems to work correctly. Later I’ll try for other devices too… ![]()
Thank you for support… ![]()
at least we are one step ahead, even if we don’t know why config got invalid. ![]()
Exact! ![]()
Same thing with other clients… ![]()
Same thing with other clients… >
They are working with a new config as well?
Yes!
hmm probably keys on server side changed. You could check them manually.
