I have searched the existing open and closed issues | yes
- DietPi version |
G_DIETPI_VERSION_CORE=8 G_DIETPI_VERSION_SUB=24 G_DIETPI_VERSION_RC=1 G_GITBRANCH='master' G_GITOWNER='MichaIng'
- Distro version |
bookworm 0
- Kernel version |
- Architecture |
arm64
- SBC model |
RPi 4 Model B (aarch64)
- SD card used |
SanDisk ultra
- Software title |
Wordpress (+Apache)
- Was the software title installed freshly or updated/migrated? |
Fresh
- Can this issue be replicated on a fresh installation of DietPi? |
Not sure
- Wordpress installation via dietpi-software
- Check the status `of the mysql service
- attempt to install the Wordpress
= Can install the software by providing all default data
Iβm trying to install wordpress (+Apache). Iβm able to connect using my IP address, and I see the installation wizard.
However, on STEP 2, even though Iβm typing / filling manually all fields (Iβm aware that they seem to be pre-filled when they are not), I always receive Error establishing a database connection
Iβm sure that Iβm typing everything correctly. As for the password, I tried dietpi or the password for my root account.
However I already have the mysql database that was created and is used by other software.
Status of mariadb.service
AFTER the WordPress install (before installation no errors were reported on that service)
Dec 17 09:39:08 DietPi /etc/mysql/debian-start[311805]: Upgrading MySQL tables if necessary.
Dec 17 09:39:08 DietPi mariadbd[311782]: 2023-12-17 9:39:08 3 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
Dec 17 09:39:08 DietPi /etc/mysql/debian-start[311809]: Reading datadir from the MariaDB server failed. Got the following error when executing the 'mysql' command line client
Dec 17 09:39:08 DietPi /etc/mysql/debian-start[311809]: ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Dec 17 09:39:08 DietPi /etc/mysql/debian-start[311809]: FATAL ERROR: Upgrade failed
Dec 17 09:39:08 DietPi /etc/mysql/debian-start[311825]: Checking for insecure root accounts.
Dec 17 09:39:08 DietPi mariadbd[311782]: 2023-12-17 9:39:08 4 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
Dec 17 09:39:08 DietPi debian-start[311828]: ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Dec 17 09:39:10 DietPi mariadbd[311782]: 2023-12-17 9:39:10 0 [Note] InnoDB: Buffer pool(s) load completed at 231217 9:39:10
Dec 17 09:41:42 DietPi mariadbd[311782]: 2023-12-17 9:41:42 14 [Warning] Access denied for user 'wordpress'@'localhost' (using password: YES)
Iβm able to login into mysql root account via
mysql -u root -p
The same root password Iβm using for wordpress installation (is the same as my dietpi root pass)
output of sudo journalctl -u mariadb
Dec 17 09:39:08 DietPi mariadbd[311782]: 2023-12-17 9:39:08 0 [Note] Server socket created on IP: '127.0.0.1'.
Dec 17 09:39:08 DietPi mariadbd[311782]: 2023-12-17 9:39:08 0 [Note] /usr/sbin/mariadbd: ready for connections.
Dec 17 09:39:08 DietPi mariadbd[311782]: Version: '10.11.4-MariaDB-1~deb12u1' socket: '/run/mysqld/mysqld.sock' port: 3306 Debian 12
Dec 17 09:39:08 DietPi systemd[1]: Started mariadb.service - MariaDB 10.11.4 database server.
Dec 17 09:42:21 DietPi mariadbd[311782]: 2023-12-17 9:42:21 15 [Warning] Access denied for user 'wordpress'@'localhost' (using password: YES)
