Webmin Mysql module not installing
  • DietPi version | 9.8
  • Distro version | bookworm
  • Kernel version | Linux DietPi 6.1.0-26-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.112-1 (2024-09-30) x86_64 GNU/Linux
  • Architecture | amd64
  • SBC model | native PC (hp elitedesk)
  • SD card used | No SD card, SSD disk
  • Software title | Webmin
  • Freshly installed
  • Can this issue be replicated on a fresh installation of DietPi? Yes, it is a fresh install. I could reproduce it on a Odroid C2.
  1. Install LAMP stack +webmin, go to modules or to Mysql
  2. Try to install Mysql module
  • Mysql module installs
  • It hangs.
  • I tried without success to install manually the module…
Hi guys, I use webmin for mysql backup, and somehow the necessary module doesn’t install on my new thin client whereas it’s installed on my rock64. I could reproduce the behavior on a Odroid C2. Do you have any idea on how to debug this? A workaround would be great, I search the insternet but I cannot figure it out. Maybe I’m not using the right keywords.
What happens when you try to install it?
Can you give a specific command?
Do you get any error messages?
Or does it just hang, if yes: How long have you waited?
I don’t use command but go with webmin interface. There’s no error. It just hangs (the interface is still responsive but nothing installa). I waited for 3 jours yesterday. I had to restart the server because it was getting pretty warm (>60°), webmin was using a lot of cpu.
I lnow that without logs it’s a bit tricky, but I don’t know where to find those specific webmin logs.
Does installing this module work on your install?
You can turn on logging for webmin like described here:
https://dietpi.com/docs/software/system_stats/#webmin-system-logging
I tested it now with MariaDB and tried to install the cooresponding module, I have also 100% usage on one core from update.cgi which tries to download that module.
I killed that process, downloaded the module manually from https://download.webmin.com/download/modules/ and installed it manually via
Webmin → Webmin Configuration → Webmin Modules.
Looks like something that would need to be reported to Webmin developer
I’m so sorry, I wasn’t clear and mixed up modules and perl modules. Mariadb module is installed, what’s missing and cannot install is the db perl module:
So your workaround doesn’t work… I’ll turn the logs on and try again, son I can have a bone to chew on.
I’ll update the topic as soon as possible.
Yes, but they don’t really respond. I’ll ask anyway you’re right.
Oh. I foud my issue. I juste had to apt install liIbdbd-mysql-perl.
That’s it. Thanks for your time guys !
