[Solved]Help with GPIO not working!
Good morning, everyone.
I am new to DietPi and I have a problem that I cannot solve.
Furthermore, as I do not know English, I am forced to ask for help here, as there is no forum in Italian, using an online translator!
So please excuse me if something is not understandable!!! :(((
I have an old Raspberry Pi 1B+ that I have set up as a print server.
With Raspbian Bullseye Lite, everything works fine, but it is very slow.
So I wanted to try DietPi, which is actually much faster both at start-up/shutdown and when sending documents to print.
However, I am having problems running the script.py that I created to turn on an LED from the GPIO to see when the system is ready. Furthermore, the command to listen to GPIO 3 and invoke poweroff, which works perfectly in Bullseye, does not work either.
When I try to run the script from /Home/DietPi/, I get this error:
File ‘/home/dietpi/led.py’, line 1, in <module>
import RPi.GPIO as GPIO
File ‘/usr/lib/python3/dist-packages/RPi/GPIO/__init__.py’, line 927, in <module>
RPI_INFO = _get_rpi_info()
File ‘/usr/lib/python3/dist-packages/RPi/GPIO/__init__.py’, line 428, in _get_rpi_info
raise NotImplementedError(
NotImplementedError: This module does not understand old-style revision codes
The script I am using is this:
import time
#Disabilita i Warnings
GPIO.setwarnings(False)
# Usa la numerazione BCM (GPIO17, GPIO18, ecc.)
GPIO.setmode(GPIO.BCM)
# Imposta il pin 17 come output
GPIO.setup(17, GPIO.OUT)
#time.sleep(0.5)
# Aspetta 0.5 secondi
# Accendi (HIGH = 3.3V)
GPIO.output(17, GPIO.HIGH)
#time.sleep(1)
# Spegni (LOW = 0V)
#GPIO.output(17, GPIO.LOW)
# Pulisci le configurazioni alla fine
#GPIO.cleanup()
Of course, I’ve searched the web, but I can’t figure out how to solve it!
Even the command:
dtoverlay=gpio-shutdown,active_low=1
that I entered in:
/boot/config.txt
no longer has any effect!
Can you help me?
Thank you all for your help.
That’s absolutely fine and no problem at all. I can recommend DeepL here. It actually does a pretty good job.
I’m no expert when it comes to GPIO, but have you checked dietpi-config? I think you can activate it there.
You may also need to install RPi.GPIO (ID 69) or similar from dietpi-software.
Yes, thank you, I already use Deepl!
In diet-config, ic2 is already enabled, and I can’t remember what else.
So they are enabled.
RPi GPIO installed, it seems that this library does not work starting from Bookworm!
Searching the web, I tried several solutions, but none of them work!
I installed and then modified the script to install gpiozero, and then the errors multiplied because, for example, the LED used to directly manage the output calls RPi.GPIO I don’t know how many times!
If I could find the image of DietPi RP1 ARMv6 Bullseye, I would use that and be fine, but it no longer exists and I don’t know where to find it…
We dropped support for Bullseye beginning of this year DietPi v10.0 - DietPi.com Docs This includes removing of these images from our server.
Maybe @MichaIng has an idea regarding GPIO.
Yes, of course.
But… I’d like it to work!
I’m not interested in updates for what it needs to do, especially if I have to get involved again!
The only real problem, at that point, would be installing the Splix drivers.
But if I’ve understood all the steps correctly, I could download the new Splix directly from GitHub and compile them directly on the Raspberry, thanks to the detailed instructions provided by the Openprint developer ValdikSS , who created a filter and related .ppd for my Samsung ml1860!
And it works great!
We hope Michalng reads my post and helps me sort this out!
This a legacy API not supported anymore by the RPi kernel. There is a replacement package python3-rpi-lgpio which provides the API on top of the modern lgpio. But I remember one case where this did not work, guess it depends on the software and exact function used, probably no perfect drop-in replacement.
gpiozero as well uses lgpio if available, with highest priority. So yeah, that script requires an update to use a modern low-level or high-level library, or at least python3-rpi-lgpio.
Okay, tanks, so what should I install, rpi.lgpio?
But do I have to uninstall rpi.gpio?
Won’t they conflict with each other?
I could use the script I put together for gpiozero, but that caused problems!
It’s true that I tried it on dietpi Trixie…
I’m no Debian wizard, so I think you’ll have to guide me like a child!!!:rofl::rofl::rofl::rofl:
After much research and trial and error, I solved the problems!
I am leaving this description here in case anyone else needs it in the future.
I started again with a clean installation, in which the only software installed was CUPS and python3, leaving i2c and spi disabled.
Before the first start-up, I modified dietpi.txt on the boot partition, unmasking the logind service by setting the option to 1:
AUTO_UNMASK_LOGIND=1
Since I was already there, I also set the host name and static IP.
Once I had completed the initial start-up by setting passwords, region, time and language, I moved on to testing that logind was actually working:
root@DietPi:~# systemctl status systemd-logind
● systemd-logind.service - User Login Management
     Loaded: loaded (/lib/systemd/system/systemd-logind.service; static)
     Active: active (running) since Wed 2023-04-19 16:29:25 BST; 1min 54s ago
       Docs: man:sd-login(3)
             man:systemd-logind.service(8)
             man:logind.conf(5)
             man:org.freedesktop.login1(5)
   Main PID: 422 (systemd-logind)
     Status: "Processing requests..."
      Tasks: 1 (limit: 9203)
     Memory: 1.3M
        CPU: 61ms
     CGroup: /system.slice/systemd-logind.service
             └─422 /lib/systemd/systemd-logind
So I added the following lines to /boot/firmware/config.txt:
#-------poweroff button------
dtoverlay=gpio-shutdown,gpio_pin3,active_low=1,gpio_pull=up
I rebooted and found that finally, by closing gpio3 to GND, the Raspberry shut down.
I then moved on to installing:
sudo apt install python3-gpiozero python3-lgpio
Then I created a led.py file on /home/dietpi/:
import sys
from gpiozero import LED
red = LED(17)
while True:
red.on()
sys.exit()
I launched dietpi-autostart, which creates a bash file
/var/lib/dietpi/dietpi-autostart/custom.sh
and inserted the following line of code:
/usr/bin/python3 /home/dietpi/led.py &
Then I moved on to installing the drivers for the printer, etc.
So I have a print server that I can turn on and off as I please, without compromising the SD card, and which lights up an LED at the end of the start-up process to show that it is operational!
Thanks to everyone who helped me…
See you next time.
Valter :grinning_face: :waving_hand:
