[Solved] Dietpi on OdroidC4 no HDMI audio output listed
  • DietPi version | v8.9.2
  • Distro version | Dietpi OdroidC4 ARMv8 Bullseye
  • Kernel version | 5.10.147-meson64
  • SBC model | Odroid C4 (in terminal states: Odroid C4/HC4 (aarch64) )
  • Power supply used | DC 12v 2.0A
  • SD card used | SanDisk ultra 64gb
Additional Information
  • All software freshly installed.
    I assume so.
  1. …Download and flash DietPi_OdroidC4-ARMv8-Bullseye.7z (from Dietpi.com)
  2. …Install XDFE desktop on first boot
Dietpi-config /audio settings, should list HDMI output as default.
Dietpi-config /audio settings/Soundcard shows:
Usb-dac: USB Audio DAC (any)
hw: 0,0 : SM10DROIDC4
hw: 0,1 : SM10DROIDC4
hw: 0,2 : SM10DROIDC4
Using Ubuntu 20.04 and 22.04 HDMI audio works fine.
Using Core Elec HMDi audio works fine.
HDMI cable plugged into a TCL smart TV. No problems with display. (1360x768@60Hz)
Tried all listed desktop environments - same problem
Relative newbie with Linux, please help with step by step instructions.
Update:
In terminal: speaker-test -c2. Plays Audio!
Update: installed pulse audio. I have sound now!
Hi, I have the same hardware and latest dietpi version, and I get the same output, no hdmi audio.
When playing speaker test, it gives this error:
dietpi@DietPi:~$ speaker-test -c2
speaker-test 1.2.4
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 4 to 262144
Period size range from 2 to 131072
Using max buffer size 262144
Periods = 4
Unable to set hw params for playback: Invalid argument
Setting of hwparams failed: Invalid argument
Which tests can I run, to see if everything is fine.
Thank you!
P:D: I can open another thread if it is better.
you have installed as well pulse audio like to OP? At least this seems to have fixed it for him.
Sorry for the late answer,
Yes I’ve tried installing pulseaudio, and no sound…
Is there anything I can do to restore audio settings or packages to it’s defaults, and start from zero?
I too tried Ubuntu Mate on Odroid C4, there is no output on HDMI audio.
I even tried manually editing /etc/asound.conf after which sound manager showed device under hardware option but still no audio.
I have both pulseaudio and alsa installed.
Any configuration needs to be done for this.
