Slow unstable and plagued with frequent errors - dietpi is not that ready like raspberry pi os
have been a pi user closer to a decade now but recently decided to test out dietpi. always been with rpi os since many versions but recently they are becoming more and more bloated with each new release. so why not check out diet pi you say? well, I did and wasted whole two days doing a simple set up of getting pi hole and unbound to work on pi zero w but sadly it is painfully slow to install to these two.
diet pi itself has many decent options and pretty good at that too but if we encounter multiple errors, very high load and boot times, and too many errors, so many reboots and installs and still it just hung up at different steps.
be it simple as dns set up or configring static IPs, it will work for a while and than will get stuck in limbo!
my fingers got worn out after my whole weekend spent towards this mess and I still appreciate the base of dietpi but anything other than that is more like an experiment. just being lightweight not gonna help here. you have to overcome many issues to become more trusted for day to day use…
Maybe you can give some examples on the issue you are had. Pihole and unbound are one of the most popular apps on DietPi and can be installed with a single command line without the need to do further configuration.
So would be interesting to get more details on your case.
That’s not my experience. Pi-Hole setup worked out of the box for me, many years ago. So do several other packages, i.e. Nextcloud, LetsEncrypt, MariaDB, Redis, Samba, Forgejo, Git, and more.
Your post title is … surprising. If you wish to give it another go, I suggest starting from scratch and following the installation notes: DNS Servers Options - DietPi.com Docs
But hey, if Raspbian works better for you, don’t switch.
-jcw
