Hi. Had really good experience with Diet-Pi on the RPi, but with the current lack of stock, decided on the Rock Pi S. I have the POE hat and the plan is to have this as part of my LMS solution with the squeezelite client. However, it appears that the i2s audio is not supported out of the box.
So, my question, is this easy enough to enable, and if so, how?
That said, just updated to 9.7.1 and it has broken the audio out on the POE hat (which was working great previously). Been using this as a POE powered squeezelite client.
