wytos
9 October 2022 16:18
1
DietPi version | 8.9.2
Distro version | bullseye
Kernel version | Linux DietPi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
SBC model | RPi 4 Model B (aarch64)
Software title | qBittorrent v4.2.5
installed using dietpi-software
just install qbittorrent and reboot, the service is launched but the web interface doesn’t start
I expect that the web interface of qbittorrent goes up as the service starts, but instead I have to
manually execute qbittorrent-nox to run the web interface
the service is loaded and executed at boot but without web interface
Jappe
9 October 2022 18:04
3
I can not recreate this.
After a reboot, what gives you systemctl status qbittorrent.service?
as well pls show following to check LISTEN ports.
ss -tulpn | grep LISTEN
wytos
9 October 2022 19:43
5
dietpi@DietPi:~$ sudo systemctl status qbittorrent.service
● qbittorrent.service - qBittorrent (DietPi)
Loaded: loaded (/etc/systemd/system/qbittorrent.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2022-10-09 20:35:04 BST; 38s ago
Docs: man:qbittorrent-nox(1)
Main PID: 1126 (qbittorrent-nox)
Tasks: 9 (limit: 4164)
CPU: 204ms
CGroup: /system.slice/qbittorrent.service
└─1126 /usr/bin/qbittorrent-nox
Oct 09 20:35:04 DietPi systemd[1]: Started qBittorrent (DietPi).
dietpi@DietPi:~$ sudo ss -tulpn | grep qbittorrent | grep LISTEN
tcp LISTEN 0 30 10.5.0.2%nordlynx:6881 0.0.0.0:* users:(("qbittorrent-nox",pid=1126,fd=21))
tcp LISTEN 0 30 192.168.1.176%br0:6881 0.0.0.0:* users:(("qbittorrent-nox",pid=1126,fd=19))
tcp LISTEN 0 30 127.0.0.1%lo:6881 0.0.0.0:* users:(("qbittorrent-nox",pid=1126,fd=15))
tcp LISTEN 0 50 *:1340 *:* users:(("qbittorrent-nox",pid=1126,fd=36))
And here is the systemd unit file
dietpi@DietPi:~$ cat /etc/systemd/system/qbittorrent.service
[Unit]
Description=qBittorrent (DietPi)
Documentation=man:qbittorrent-nox(1)
Wants=network-online.target
After=network-online.target
[Service]
User=qbittorrent
UMask=002
LogsDirectory=qbittorrent
ExecStart=/usr/bin/qbittorrent-nox
[Install]
WantedBy=multi-user.target
After i run qbittorrent-nox & I get
tcp LISTEN 0 30 10.5.0.2%nordlynx:9047 0.0.0.0:* users:(("qbittorrent-nox",pid=2517,fd=20))
tcp LISTEN 0 30 192.168.1.176%br0:9047 0.0.0.0:* users:(("qbittorrent-nox",pid=2517,fd=17))
tcp LISTEN 0 30 127.0.0.1%lo:9047 0.0.0.0:* users:(("qbittorrent-nox",pid=2517,fd=16))
tcp LISTEN 0 50 *:8080 *:* users:(("qbittorrent-nox",pid=2517,fd=35))
Thank you for your help.
wytos
9 October 2022 19:47
6
Okay, I was looking at the wrong port, 8080, instead of 1340.
I’m so sorry!
Thank you!
