- DietPi version | 8.8
- Distro version | bullseye
- Kernel version | Linux nas 5.10.0-18-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64 GNU/Linux
- SBC model | PC (x64 CPU)
- Software title | TigerVNC, xrdp, MATE
- TigerVNC fresh, xrdp used in the past (always creating new desktop sessions)
Enable auto-login to desktop for user “dietpi” (using the MATE desktop here)
/boot/dietpi.txt
SOFTWARE_VNCSERVER_DISPLAY_INDEX=0
SOFTWARE_VNCSERVER_SHARE_DESKTOP=1
/etc/systemd/system/vncserver.service
User=dietpi
Environment=HOME=/home/dietpi
sudo -u dietpi /usr/local/bin/vncserver start
- I am able to login to the running desktop session of user dietpi with a remote desktop client (e.g. Windows Remotedesktop, TigerVNC/UltraVNC/TightVNC)
- I am able to use all keys (running a German setup and keyboard here)
- Copy & paste does work
- I am not able to log-in immediately. Instead, I have to ssh (via putty) to the machine and do a “systemctl restart vncserver.service”.
- For being able to use all keys, I have to call a “setxkbmap de” on every desktop session start
- Copy & paste does not work
I followed How to change vncserver session from root to user? - #17 by Joulinar which gave me some hints, but the problems above (also the non-working Copy & Paste) still persist - or I misunderstood something regarding the configuration…
Regarding the first problem, “systemctl status vncserver.service” apparently says that it cannot connect on boot, maybe because the desktop session is not running yet when the service is about to be started? How can I delay the start of the service or do a repeated restart of the service until it is has been started successfully?
Where do I put the “setxkbmap de” best? The issue with non-working keys has also been discussed at Some keys not working · Issue #1227 · TigerVNC/tigervnc · GitHub, but it has been (auto-)closed due to missing additional feedback.
However, if there is another solution (e.g. without using TigerVNC) that allows me connecting to the existing desktop session from Windows or Android, this is also fine. I just want to control the system via remote à la TeamViewer, Windows-VNC etc. e.g. to start UI tools, check their states etc. in a single-user environment.
Thanks a lot in advance!
