Hello, the usb 3 port no longer works after running the apt upgrade command. It seems to me that the armbian firmware package has been updated. The usb 2 ports still work but the transfer speed is slower…
Is it possible to go back to the old version where usb 3 was working?
root: uname -a
Linux DietPi 5.15.25-rockchip64 #22.02.1 SMP PREEMPT Sun Feb 27 09:05:47 UTC 2022 aarch64 GNU/Linux
I had the same problem but with the network card, so I cannot longer SSH to it, or run armbian-config. I traced the problem to the last linux-image-current-rockchip64 update. I restored a backup I had and started to test. What broke it was this:
javi@rock64:~$ sudo apt list -a linux-image-current-rockchip64
[sudo] password for javi:
Listing... Done
linux-image-current-rockchip64/bionic 22.02.1 arm64 [upgradable from: 21.08.2]
linux-image-current-rockchip64/bionic,now 21.08.2 arm64 [installed,upgradable to: 22.02.1]
linux-image-current-rockchip64/bionic 21.08.1 arm64
linux-image-current-rockchip64/bionic 21.05.9 arm64
linux-image-current-rockchip64/bionic 21.05.4 arm64
linux-image-current-rockchip64/bionic 21.05.1 arm64
linux-image-current-rockchip64/bionic 21.02.3 arm64
linux-image-current-rockchip64/bionic 21.02.2 arm64
javi@rock64:~$ sudo apt install linux-image-current-rockchip64=22.02.1
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 51.2 MB of archives.
After this operation, 123 MB disk space will be freed.
Get:1 https://stpete-mirror.armbian.com/apt bionic/main arm64 linux-image-current-rockchip64 arm64 22.02.1 [51.2 MB]
Fetched 51.2 MB in 10s (5,066 kB/s)
(Reading database ... 109695 files and directories currently installed.)
Preparing to unpack .../linux-image-current-rockchip64_22.02.1_arm64.deb ...
update-initramfs: Deleting /boot/initrd.img-5.10.63-rockchip64
Removing obsolete file uInitrd-5.10.63-rockchip64
Unpacking linux-image-current-rockchip64 (22.02.1) over (21.08.2) ...
Setting up linux-image-current-rockchip64 (22.02.1) ...
update-initramfs: Generating /boot/initrd.img-5.15.25-rockchip64
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/drivers/cdrom/cdrom.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/isofs/isofs.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/jfs/jfs.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/reiserfs/reiserfs.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/udf/udf.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/xfs/xfs.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/netfs/netfs.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/fscache/fscache.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/net/sunrpc/sunrpc.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nfs_common/grace.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/lockd/lockd.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nfs/nfs.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nfs/nfsv2.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nfs_common/nfs_acl.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nfs/nfsv3.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nfs/nfsv4.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/fs/nls/nls_iso8859-1.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/lib/842/842_decompress.ko.xz not found.
modinfo: ERROR: Module /lib/modules/5.15.25-rockchip64/kernel/drivers/md/dm-mod.ko.xz not found.
update-initramfs: Converting to u-boot format
The version 21.08.2 was working fine but when I went to update to 22.02.1, it showed all of those errors and that’s it, no network card and probably no quite a lot of other things.
I’ll restore the backup and hold back that package until it’s fixed.
Create an image of the sdcard now and then!
There is a device tree overlay available named “usb4”. Not sure whether this was there before. Please try to add “usb4” to the “overlays” line in /boot/armbianEnv.txt.
Another thing: Do not upgrade linux-image-current-rockchip64 without upgrading linux-dtb-current-rockchip64 as well. Kernel and device tree must always match.
The error messages during initramfs generation are actually interesting. Also since the contain NFS, known to be broken with latest kernel. I wonder whether some internal references are wrong, regarding compressed (with *.xz ending) vs uncompressed kernel modules. Probably the following solves it as well:
depmod -a
update-initramfs -u
And yet another thing that caught my eyes: Why your kernel packages have a “bionic” suffix? Is the Armbian repo correct?
Thank you for the reply! I’ll get another SD card and try to update linux-dtb-current-rockchip64 at the same time than the linux-image-current-rockchip64. I updated the dtb first to see which one was the one that created the problems.
I’ll try as well the depmod and intrafms update and see if that fixes something.
Regarding the “bionic” suffix in the repo, I have no idea. I installed armbian and I didn’t add any other ubuntu or debian repo, so who knows. Fun fact: in the welcome screen when you log it with ssh now it says “Ubuntu 18.04” instead of armbian. It changed when I updated all the packages (around 280) of my backup image from Dec 2020 I had around. So yes, there is something fishy there… Maybe it didn’t like to update very old packages, who knows… But as far as I know, except the last version of the linux-image-current-rockchip64 package, everything else works fine.
Thank you!
Edit: I forgot to post the contents of /etc/apt/sources.list.d/armbian.list
What do you mean by “installed armbian”? You mean you installed DietPi on an Armbian image? If this was an Armbian Ubuntu image, it shouldn’t be possible to install DietPi on it, as the PREP script checks for the distro and errors out if it is not Debian. Otherwise, did you manually edit that file, or where did you get the image from?
I’m not sure now distro and version it is at all, can you paste the output of:
Ah, I’m so sorry. I looked for problems similar to mine and I landed on this forum not realising that DietPi was a specific distro. I just flashed my SD with Armbian for the Rock64 on 2019 probably, and I’ve been updating it since then. So yes, it’s not a DietPi distro. I’m sorry for the confusion and the wasted time. Although I guess it’s good to know the problem with the kernel happens with other distros as well.
Just in case it’s useful, this is the output of your commands:
javi@rock64:~$ cat /etc/apt/sources.list
deb http://ports.ubuntu.com/ bionic main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ bionic main restricted universe multiverse
deb http://ports.ubuntu.com/ bionic-security main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ bionic-security main restricted universe multiverse
deb http://ports.ubuntu.com/ bionic-updates main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ bionic-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ bionic-backports main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ bionic-backports main restricted universe multiverse
This output is definitely wrong for some reason. It changed Armbian for Ubuntu:
And of course, almost all the packages probably are from the ubuntu repos:
javi@rock64:~$ dpkg -l | grep ubuntu
ii accountsservice 0.6.45-1ubuntu1.3 arm64 query and manipulate user account information
ii adduser 3.116ubuntu1 all add and remove users and groups
ii adwaita-icon-theme 3.28.0-1ubuntu1 all default icon theme of GNOME (small subset)
ii alsa-utils 1.1.3-1ubuntu1 arm64 Utilities for configuring and using ALSA
ii apport 2.20.9-0ubuntu7.27 all automatically generate crash reports for debugging
ii aptdaemon 1.1.1+bzr982-0ubuntu19.5 all transaction based package management service
ii aptdaemon-data 1.1.1+bzr982-0ubuntu19.5 all data files for clients
ii aptitude 0.8.10-6ubuntu1 arm64 terminal-based package manager
ii aptitude-common 0.8.10-6ubuntu1 all architecture independent files for the aptitude package manager
ii aspell 0.60.7~20110707-4ubuntu0.2 arm64 GNU Aspell spell-checker
ii atril 1.20.1-2ubuntu2 arm64 MATE document viewer
ii atril-common 1.20.1-2ubuntu2 all MATE document viewer (common files)
ii automake 1:1.15.1-3ubuntu2 all Tool for generating GNU Standards-compliant Makefiles
ii avahi-autoipd 0.7-3.1ubuntu1.3 arm64 Avahi IPv4LL network address configuration daemon
ii avahi-daemon 0.7-3.1ubuntu1.3 arm64 Avahi mDNS/DNS-SD daemon
ii avahi-utils 0.7-3.1ubuntu1.3 arm64 Avahi browsing, publishing and discovery utilities
ii base-files 10.1ubuntu2.11 arm64 Debian base system miscellaneous files
ii bash 4.4.18-2ubuntu1.2 arm64 GNU Bourne Again SHell
ii bash-completion 1:2.8-1ubuntu1 all programmable completion for the bash shell
ii bind9-host 1:9.11.3+dfsg-1ubuntu1.17 arm64 DNS lookup utility (deprecated)
ii binutils 2.30-21ubuntu1~18.04.7 arm64 GNU assembler, linker and binary utilities
ii binutils-aarch64-linux-gnu 2.30-21ubuntu1~18.04.7 arm64 GNU binary utilities, for aarch64-linux-gnu target
ii binutils-common:arm64 2.30-21ubuntu1~18.04.7 arm64 Common files for the GNU assembler, linker and binary utilities
ii blueman 2.0.5-1ubuntu1.1 arm64 Graphical bluetooth manager
ii bluez 5.48-0ubuntu3.8 arm64 Bluetooth tools and daemons
ii bluez-obexd 5.48-0ubuntu3.8 arm64 bluez obex daemon
ii bridge-utils 1.5-15ubuntu1 arm64 Utilities for configuring the Linux Ethernet bridge
ii bsdmainutils 11.1.2ubuntu1 arm64 collection of more utilities from FreeBSD
ii bsdutils 1:2.31.1-0.4ubuntu3.7 arm64 basic utilities from 4.4BSD-Lite
ii build-essential 12.4ubuntu1 arm64 Informational list of build-essential packages
ii busybox-initramfs 1:1.27.2-2ubuntu3.4 arm64 Standalone shell setup for initramfs
ii bzip2 1.0.6-8.1ubuntu0.2 arm64 high-quality block-sorting file compressor - utilities
ii chromium-browser 99.0.4844.51-0ubuntu0.18.04.1 arm64 Chromium web browser, open-source version of Chrome
ii chromium-browser-l10n 99.0.4844.51-0ubuntu0.18.04.1 all chromium-browser language packages
ii chromium-codecs-ffmpeg-extra 99.0.4844.51-0ubuntu0.18.04.1 arm64 Extra ffmpeg codecs for the Chromium Browser
ii cmake 3.10.2-1ubuntu2.18.04.2 arm64 cross-platform, open-source make system
ii cmake-data 3.10.2-1ubuntu2.18.04.2 all CMake data files (modules, templates and documentation)
ii console-setup 1.178ubuntu2.9 all console font and keymap setup program
ii console-setup-linux 1.178ubuntu2.9 all Linux specific part of console-setup
ii coreutils 8.28-1ubuntu1 arm64 GNU core utilities
ii cpio 2.12+dfsg-6ubuntu0.18.04.4 arm64 GNU cpio -- a program to manage archives of files
ii cpp 4:7.4.0-1ubuntu2.3 arm64 GNU C preprocessor (cpp)
ii cpp-7 7.5.0-3ubuntu1~18.04 arm64 GNU C preprocessor
ii cron 3.0pl1-128.1ubuntu1 arm64 process scheduling daemon
ii cups 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - PPD/driver support, web interface
ii cups-browsed 1.20.2-0ubuntu3.1 arm64 OpenPrinting CUPS Filters - cups-browsed
ii cups-client 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - client programs (SysV)
ii cups-common 2.2.7-1ubuntu2.8 all Common UNIX Printing System(tm) - common files
ii cups-core-drivers 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - driverless printing
ii cups-daemon 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - daemon
ii cups-filters 1.20.2-0ubuntu3.1 arm64 OpenPrinting CUPS Filters - Main Package
ii cups-filters-core-drivers 1.20.2-0ubuntu3.1 arm64 OpenPrinting CUPS Filters - Driverless printing
ii cups-ipp-utils 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - IPP developer/admin utilities
ii cups-pk-helper 0.2.6-1ubuntu1.2 arm64 PolicyKit helper to configure cups with fine-grained privileges
ii cups-ppdc 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - PPD manipulation utilities
ii cups-server-common 2.2.7-1ubuntu2.8 all Common UNIX Printing System(tm) - server common files
ii curl 7.58.0-2ubuntu3.16 arm64 command line tool for transferring data with URL syntax
ii dbus 1.12.2-1ubuntu1.2 arm64 simple interprocess messaging system (daemon and utilities)
ii dbus-user-session 1.12.2-1ubuntu1.2 arm64 simple interprocess messaging system (systemd --user integration)
ii dbus-x11 1.12.2-1ubuntu1.2 arm64 simple interprocess messaging system (X11 deps)
ii dconf-gsettings-backend:arm64 0.26.0-2ubuntu3 arm64 simple configuration storage system - GSettings back-end
ii dconf-service 0.26.0-2ubuntu3 arm64 simple configuration storage system - D-Bus service
ii ddclient 3.8.3-1.1ubuntu1 all address updating utility for dynamic DNS services
ii debconf 1.5.66ubuntu1 all Debian configuration management system
ii debconf-i18n 1.5.66ubuntu1 all full internationalization support for debconf
ii debconf-utils 1.5.66ubuntu1 all debconf utilities
ii desktop-base 8.0.2ubuntu1 all common files for the Debian Desktop
ii desktop-file-utils 0.23-1ubuntu3.18.04.2 arm64 Utilities for .desktop filesii dh-python 3.20180325ubuntu2 all Debian helper tools for packaging Python libraries and applications
ii dirmngr 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - network certificate management service
ii distro-info 0.18ubuntu0.18.04.1 arm64 provides information about the distributions' releases
ii distro-info-data 0.37ubuntu0.13 all information about the distributions' releases (data files)
ii dmsetup 2:1.02.145-4.1ubuntu3.18.04.3 arm64 Linux Kernel Device Mapper userspace library
ii dnsutils 1:9.11.3+dfsg-1ubuntu1.17 arm64 Clients provided with BIND
ii dpkg 1.19.0.5ubuntu2.3 arm64 Debian package management system
ii dpkg-dev 1.19.0.5ubuntu2.3 all Debian package development tools
ii e2fsprogs 1.44.1-1ubuntu1.3 arm64 ext2/ext3/ext4 file system utilities
ii ethtool 1:4.15-0ubuntu1 arm64 display or change Ethernet device settings
ii exo-utils 0.12.2-0ubuntu0.18.04.1 arm64 Utility files for libexo
ii fbi 2.10-2ubuntu1 arm64 Linux frame buffer image viewer
ii fdisk 2.31.1-0.4ubuntu3.7 arm64 collection of partitioning utilities
ii ffmpeg 7:3.4.8-0ubuntu0.2 arm64 Tools for transcoding, streaming and playing of multimedia files
ii file 1:5.32-2ubuntu0.4 arm64 Recognize the type of data in a file using "magic" numbers
ii fontconfig 2.12.6-0ubuntu2 arm64 generic font configuration library - support binaries
ii fontconfig-config 2.12.6-0ubuntu2 all generic font configuration library - configuration
ii fuse 2.9.7-1ubuntu1 arm64 Filesystem in Userspace
ii g++ 4:7.4.0-1ubuntu2.3 arm64 GNU C++ compiler
ii g++-7 7.5.0-3ubuntu1~18.04 arm64 GNU C++ compiler
ii gcc 4:7.4.0-1ubuntu2.3 arm64 GNU C compiler
ii gcc-7 7.5.0-3ubuntu1~18.04 arm64 GNU C compiler
ii gcc-7-base:arm64 7.5.0-3ubuntu1~18.04 arm64 GCC, the GNU Compiler Collection (base package)
ii gcc-8-base:arm64 8.4.0-1ubuntu1~18.04 arm64 GCC, the GNU Compiler Collection (base package)
ii gconf-service 3.2.6-4ubuntu1 arm64 GNOME configuration database system (D-Bus service)
ii gconf-service-backend 3.2.6-4ubuntu1 arm64 GNOME configuration database system (D-Bus service)
ii gconf2 3.2.6-4ubuntu1 arm64 GNOME configuration database system (support tools)
ii gconf2-common 3.2.6-4ubuntu1 all GNOME configuration database system (common files)
ii geoclue-2.0 2.4.7-1ubuntu1 arm64 geoinformation service
ii gettext 0.19.8.1-6ubuntu0.3 arm64 GNU Internationalization utilities
ii gettext-base 0.19.8.1-6ubuntu0.3 arm64 GNU Internationalization utilities for the base system
ii ghostscript 9.26~dfsg+0-0ubuntu0.18.04.15 arm64 interpreter for the PostScript language and for PDF
ii gir1.2-appindicator3-0.1 12.10.1+18.04.20200408.1-0ubuntu1 arm64 Typelib files for libappindicator3-1.
ii gir1.2-gtk-3.0:arm64 3.22.30-1ubuntu4 arm64 GTK+ graphical user interface library -- gir bindings
ii gir1.2-harfbuzz-0.0:arm64 1.7.2-1ubuntu1 arm64 OpenType text shaping engine (GObject introspection data)
ii gir1.2-packagekitglib-1.0 1.1.9-1ubuntu2.18.04.6 arm64 GObject introspection data for the PackageKit GLib library
ii gir1.2-pango-1.0:arm64 1.40.14-1ubuntu0.1 arm64 Layout and rendering of internationalized text - gir bindings
ii gir1.2-polkit-1.0 0.105-20ubuntu0.18.04.6 arm64 GObject introspection data for PolicyKit
ii gir1.2-vte-2.91:arm64 0.52.2-1ubuntu1~18.04.2 arm64 GObject introspection data for the VTE library
ii git 1:2.17.1-1ubuntu0.9 arm64 fast, scalable, distributed revision control system
ii git-man 1:2.17.1-1ubuntu0.9 all fast, scalable, distributed revision control system (manual pages)
ii glib-networking:arm64 2.56.0-1ubuntu0.1 arm64 network-related giomodules for GLib
ii glib-networking-common 2.56.0-1ubuntu0.1 all network-related giomodules for GLib - data files
ii glib-networking-services 2.56.0-1ubuntu0.1 arm64 network-related giomodules for GLib - D-Bus services
ii gnome-keyring 3.28.0.2-1ubuntu1.18.04.1 arm64 GNOME keyring services (daemon and tools)
ii gnome-keyring-pkcs11:arm64 3.28.0.2-1ubuntu1.18.04.1 arm64 GNOME keyring module for the PKCS#11 module loading library
ii gnome-orca 3.28.0-3ubuntu1 all Scriptable screen reader - transitional package
ii gnome-system-monitor 3.28.2-0ubuntu1 arm64 Process viewer and system resource monitor for GNOME
ii gnome-terminal 3.28.2-1ubuntu1~18.04.1 arm64 GNOME terminal emulator application
ii gnome-terminal-data 3.28.2-1ubuntu1~18.04.1 all Data files for the GNOME terminal emulator
ii gnupg 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - a free PGP replacement
ii gnupg-l10n 2.2.4-1ubuntu1.4 all GNU privacy guard - localization files
ii gnupg-utils 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - utility programs
ii gnupg2 2.2.4-1ubuntu1.4 all GNU privacy guard - a free PGP replacement (dummy transitional package)
ii gpg 2.2.4-1ubuntu1.4 arm64 GNU Privacy Guard -- minimalist public key operations
ii gpg-agent 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - cryptographic agent
ii gpg-wks-client 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - Web Key Service client
ii gpg-wks-server 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - Web Key Service server
ii gpgconf 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - core configuration utilities
ii gpgsm 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - S/MIME version
ii gpgv 2.2.4-1ubuntu1.4 arm64 GNU privacy guard - signature verification tool
ii gsettings-desktop-schemas 3.28.0-1ubuntu1 all GSettings desktop-wide schemas
ii gstreamer1.0-gl:arm64 1.14.5-0ubuntu1~18.04.3 arm64 GStreamer plugins for GL
ii gstreamer1.0-plugins-base:arm64 1.14.5-0ubuntu1~18.04.3 arm64 GStreamer plugins from the "base" set
ii gstreamer1.0-plugins-good:arm64 1.14.5-0ubuntu1~18.04.2 arm64 GStreamer plugins from the "good" set
ii gstreamer1.0-pulseaudio:arm64 1.14.5-0ubuntu1~18.04.2 arm64 GStreamer plugin for PulseAudio
ii gstreamer1.0-x:arm64 1.14.5-0ubuntu1~18.04.3 arm64 GStreamer plugins for X11 and Pango
ii gtk-update-icon-cache 3.22.30-1ubuntu4 arm64 icon theme caching utility
ii gtk2-engines-murrine:arm64 0.98.2-2ubuntu1 arm64 cairo-based gtk+-2.0 theme engine
ii gtk2-engines-pixbuf:arm64 2.24.32-1ubuntu1 arm64 pixbuf-based theme for GTK+ 2.x
ii gvfs:arm64 1.36.1-0ubuntu1.3.3 arm64 userspace virtual filesystem - GIO module
ii gvfs-backends 1.36.1-0ubuntu1.3.3 arm64 userspace virtual filesystem - backends
ii gvfs-common 1.36.1-0ubuntu1.3.3 all userspace virtual filesystem - common data files
ii gvfs-daemons 1.36.1-0ubuntu1.3.3 arm64 userspace virtual filesystem - servers
ii gvfs-fuse 1.36.1-0ubuntu1.3.3 arm64 userspace virtual filesystem - fuse server
ii gvfs-libs:arm64 1.36.1-0ubuntu1.3.3 arm64 userspace virtual filesystem - private libraries
ii gzip 1.6-5ubuntu1.1 arm64 GNU compression utilities
ii hexchat 2.14.1-2ubuntu0.18.04.1 arm64 IRC client for X based on X-Chat 2
ii hexchat-common 2.14.1-2ubuntu0.18.04.1 all Common files for HexChat
ii hexchat-perl:arm64 2.14.1-2ubuntu0.18.04.1 arm64 Perl plugin for HexChat
ii hexchat-plugins:arm64 2.14.1-2ubuntu0.18.04.1 arm64 Common plugins for HexChat
ii hexchat-python3:arm64 2.14.1-2ubuntu0.18.04.1 arm64 Python 3 plugin for HexChat
ii hwdata 0.290-1ubuntu0.18.04.1 all hardware identification / configuration data
ii icu-devtools 60.2-3ubuntu3.2 arm64 Development utilities for International Components for Unicode
ii ifenslave 2.9ubuntu1 all configure network interfaces for parallel routing (bonding)
ii ifupdown 0.8.17ubuntu1.1 arm64 high level tools to configure network interfaces
ii im-config 0.34-1ubuntu1.3 all Input method configuration framework
ii imagemagick 8:6.9.7.4+dfsg-16ubuntu6.12 arm64 image manipulation programs -- binaries
ii imagemagick-6-common 8:6.9.7.4+dfsg-16ubuntu6.12 all image manipulation programs -- infrastructure
ii imagemagick-6.q16 8:6.9.7.4+dfsg-16ubuntu6.12 arm64 image manipulation programs -- quantum depth Q16
ii initramfs-tools 0.130ubuntu3.13 all generic modular initramfs generator (automation)
ii initramfs-tools-bin 0.130ubuntu3.13 arm64 binaries used by initramfs-tools
ii initramfs-tools-core 0.130ubuntu3.13 all generic modular initramfs generator (core tools)
ii iproute2 4.15.0-2ubuntu1.3 arm64 networking and traffic control tools
ii iptables 1.6.1-2ubuntu2 arm64 administration tools for packet filtering and NAT
ii iptables-persistent 1.0.4+nmu2ubuntu1.1 all boot-time loader for netfilter rules, iptables plugin
ii iputils-arping 3:20161105-1ubuntu3 arm64 Tool to send ICMP echo requests to an ARP address
ii iputils-ping 3:20161105-1ubuntu3 arm64 Tools to test the reachability of network hosts
ii isc-dhcp-client 4.3.5-3ubuntu7.3 arm64 DHCP client for automatically obtaining an IP address
ii isc-dhcp-common 4.3.5-3ubuntu7.3 arm64 common manpages relevant to all of the isc-dhcp packages
ii kbd 2.0.4-2ubuntu1 arm64 Linux console font and keytable utilities
ii keyboard-configuration 1.178ubuntu2.9 all system-wide keyboard preferences
ii klibc-utils 2.0.4-9ubuntu2 arm64 small utilities built with klibc for early boot
ii kmod 24-1ubuntu3.5 arm64 tools for managing Linux kernel modules
ii libaccountsservice0:arm64 0.6.45-1ubuntu1.3 arm64 query and manipulate user account information - shared libraries
ii libaio1:arm64 0.3.110-5ubuntu0.1 arm64 Linux kernel AIO access library - shared library
ii libao-common 1.2.2+20180113-1ubuntu1 all Cross Platform Audio Output Library (Common files)
ii libao4:arm64 1.2.2+20180113-1ubuntu1 arm64 Cross Platform Audio Output Library
ii libapparmor1:arm64 2.12-4ubuntu5.1 arm64 changehat AppArmor library
ii libappindicator3-1 12.10.1+18.04.20200408.1-0ubuntu1 arm64 Application Indicators
ii libappstream4:arm64 0.12.0-3ubuntu1 arm64 Library to access AppStream services
ii libarchive-zip-perl 1.60-1ubuntu0.1 all Perl module for manipulation of ZIP archives
ii libarchive13:arm64 3.2.2-3.1ubuntu0.7 arm64 Multi-format archive and compression library (shared library)
ii libasan4:arm64 7.5.0-3ubuntu1~18.04 arm64 AddressSanitizer -- a fast memory error detector
ii libasound2:arm64 1.1.3-5ubuntu0.6 arm64 shared library for ALSA applications
ii libasound2-data 1.1.3-5ubuntu0.6 all Configuration files and profiles for ALSA drivers
ii libasound2-plugins:arm64 1.1.1-1ubuntu1 arm64 ALSA library additional plugins
ii libaspell15:arm64 0.60.7~20110707-4ubuntu0.2 arm64 GNU Aspell spell-checker runtime library
ii libatomic1:arm64 8.4.0-1ubuntu1~18.04 arm64 support library providing __atomic built-in functions
ii libatrildocument3 1.20.1-2ubuntu2 arm64 MATE document rendering library
ii libatrilview3 1.20.1-2ubuntu2 arm64 MATE document viewing library
ii libaudit-common 1:2.8.2-1ubuntu1.1 all Dynamic library for security auditing - common files
ii libaudit1:arm64 1:2.8.2-1ubuntu1.1 arm64 Dynamic library for security auditing
ii libavahi-client3:arm64 0.7-3.1ubuntu1.3 arm64 Avahi client library
ii libavahi-common-data:arm64 0.7-3.1ubuntu1.3 arm64 Avahi common data files
ii libavahi-common3:arm64 0.7-3.1ubuntu1.3 arm64 Avahi common library
ii libavahi-core7:arm64 0.7-3.1ubuntu1.3 arm64 Avahi's embeddable mDNS/DNS-SD library
ii libavahi-glib1:arm64 0.7-3.1ubuntu1.3 arm64 Avahi GLib integration library
ii libavcodec57:arm64 7:3.4.8-0ubuntu0.2 arm64 FFmpeg library with de/encoders for audio/video codecs - runtime files
ii libavdevice57:arm64 7:3.4.8-0ubuntu0.2 arm64 FFmpeg library for handling input and output devices - runtime files
ii libavfilter6:arm64 7:3.4.8-0ubuntu0.2 arm64 FFmpeg library containing media filters - runtime files
ii libavformat57:arm64 7:3.4.8-0ubuntu0.2 arm64 FFmpeg library with (de)muxers for multimedia containers - runtime files
ii libavresample3:arm64 7:3.4.8-0ubuntu0.2 arm64 FFmpeg compatibility library for resampling - runtime files
ii libavutil55:arm64 7:3.4.8-0ubuntu0.2 arm64 FFmpeg library with functions for simplifying programming - runtime files
ii libbind9-160:arm64 1:9.11.3+dfsg-1ubuntu1.17 arm64 BIND9 Shared Library used by BIND
ii libbinutils:arm64 2.30-21ubuntu1~18.04.7 arm64 GNU binary utilities (private shared library)
ii libblkid1:arm64 2.31.1-0.4ubuntu3.7 arm64 block device ID library
ii libbluetooth3:arm64 5.48-0ubuntu3.8 arm64 Library to use the BlueZ Linux Bluetooth stack
ii libboost-filesystem1.65.1:arm64 1.65.1+dfsg-0ubuntu5 arm64 filesystem operations (portable paths, iteration over directories, etc) in C++
ii libboost-iostreams1.65.1:arm64 1.65.1+dfsg-0ubuntu5 arm64 Boost.Iostreams Library
ii libboost-python1.65.1 1.65.1+dfsg-0ubuntu5 arm64 Boost.Python Library
ii libboost-system1.65.1:arm64 1.65.1+dfsg-0ubuntu5 arm64 Operating system (e.g. diagnostics support) library
ii libbrlapi0.6:arm64 5.5-4ubuntu2.0.1 arm64 braille display access via BRLTTY - shared library
ii libbrotli1:arm64 1.0.3-1ubuntu1.3 arm64 library implementing brotli encoder and decoder (shared libraries)
ii libbsd0:arm64 0.8.7-1ubuntu0.1 arm64 utility functions from BSD systems - shared library
ii libbz2-1.0:arm64 1.0.6-8.1ubuntu0.2 arm64 high-quality block-sorting file compressor library - runtime
ii libc-bin 2.27-3ubuntu1.5 arm64 GNU C Library: Binaries
ii libc-dev-bin 2.27-3ubuntu1.5 arm64 GNU C Library: Development binaries
ii libc6:arm64 2.27-3ubuntu1.5 arm64 GNU C Library: Shared libraries
ii libc6-dev:arm64 2.27-3ubuntu1.5 arm64 GNU C Library: Development Libraries and Header Files
ii libcaca0:arm64 0.99.beta19-2ubuntu0.18.04.3 arm64 colour ASCII art library
ii libcairo-gobject2:arm64 1.15.10-2ubuntu0.1 arm64 Cairo 2D vector graphics library (GObject library)
ii libcairo2:arm64 1.15.10-2ubuntu0.1 arm64 Cairo 2D vector graphics library
ii libcaja-extension1:arm64 1.20.2-4ubuntu1 arm64 libraries for Caja components
ii libcanberra-gtk3-0:arm64 0.30-5ubuntu1 arm64 GTK+ 3.0 helper for playing widget event sounds with libcanberra
ii libcanberra-gtk3-module:arm64 0.30-5ubuntu1 arm64 translates GTK3 widgets signals to event sounds
ii libcanberra0:arm64 0.30-5ubuntu1 arm64 simple abstract interface for playing event sounds
ii libcc1-0:arm64 8.4.0-1ubuntu1~18.04 arm64 GCC cc1 plugin for GDB
ii libcdio17:arm64 1.0.0-2ubuntu2 arm64 library to read and control CD-ROM
ii libcom-err2:arm64 1.44.1-1ubuntu1.3 arm64 common error description library
ii libcomerr2:arm64 1.44.1-1ubuntu1.3 arm64 transitional package
ii libcryptsetup12:arm64 2:2.0.2-1ubuntu1.2 arm64 disk encryption support - shared library
ii libcups2:arm64 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - Core library
ii libcupscgi1:arm64 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - CGI library
ii libcupsfilters1:arm64 1.20.2-0ubuntu3.1 arm64 OpenPrinting CUPS Filters - Shared library
ii libcupsimage2:arm64 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - Raster image library
ii libcupsmime1:arm64 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - MIME library
ii libcupsppdc1:arm64 2.2.7-1ubuntu2.8 arm64 Common UNIX Printing System(tm) - PPD manipulation library
ii libcurl3-gnutls:arm64 7.58.0-2ubuntu3.16 arm64 easy-to-use client-side URL transfer library (GnuTLS flavour)
ii libcurl4:arm64 7.58.0-2ubuntu3.16 arm64 easy-to-use client-side URL transfer library (OpenSSL flavour)
ii libcurl4-openssl-dev:arm64 7.58.0-2ubuntu3.16 arm64 development files and documentation for libcurl (OpenSSL flavour)
ii libdb5.3:arm64 5.3.28-13.1ubuntu1.1 arm64 Berkeley v5.3 Database Libraries [runtime]
ii libdbus-1-3:arm64 1.12.2-1ubuntu1.2 arm64 simple interprocess messaging system (library)
ii libdbusmenu-glib4:arm64 16.04.1+18.04.20171206-0ubuntu2 arm64 library for passing menus over DBus
ii libdbusmenu-gtk3-4:arm64 16.04.1+18.04.20171206-0ubuntu2 arm64 library for passing menus over DBus - GTK+ version
ii libdconf1:arm64 0.26.0-2ubuntu3 arm64 simple configuration storage system - runtime library
ii libdebconfclient0:arm64 0.213ubuntu1 arm64 Debian Configuration Management System (C-implementation library)
ii libdevmapper1.02.1:arm64 2:1.02.145-4.1ubuntu3.18.04.3 arm64 Linux Kernel Device Mapper userspace library
ii libdjvulibre-text 3.5.27.1-8ubuntu0.4 all Linguistic support files for libdjvulibre
ii libdjvulibre21:arm64 3.5.27.1-8ubuntu0.4 arm64 Runtime support for the DjVu image format
ii libdns-export1100 1:9.11.3+dfsg-1ubuntu1.17 arm64 Exported DNS Shared Library
ii libdns1100:arm64 1:9.11.3+dfsg-1ubuntu1.17 arm64 DNS Shared Library used by BIND
ii libdouble-conversion1:arm64 2.0.1-4ubuntu1 arm64 routines to convert IEEE floats to and from strings
ii libdpkg-perl 1.19.0.5ubuntu2.3 all Dpkg perl modules
ii libegl-mesa0:arm64 20.0.8-0ubuntu1~18.04.1 arm64 free implementation of the EGL API -- Mesa vendor library
ii libegl1:arm64 1.0.0-2ubuntu2.3 arm64 Vendor neutral GL dispatch library -- EGL support
ii libegl1-mesa:arm64 20.0.8-0ubuntu1~18.04.1 arm64 transitional dummy package
ii libelf1:arm64 0.170-0.4ubuntu0.1 arm64 library to read and write ELF files
ii libevdev2:arm64 1.5.8+dfsg-1ubuntu0.1 arm64 wrapper library for evdev devices
ii libexif12:arm64 0.6.21-4ubuntu0.6 arm64 library to parse EXIF files
ii libexiv2-14:arm64 0.25-3.1ubuntu0.18.04.11 arm64 EXIF/IPTC/XMP metadata manipulation library
ii libexo-1-0:arm64 0.12.2-0ubuntu0.18.04.1 arm64 Library with extensions for Xfce (GTK-2 version)
ii libexo-2-0:arm64 0.12.2-0ubuntu0.18.04.1 arm64 Library with extensions for Xfce (GTK-3 version)
ii libexo-common 0.12.2-0ubuntu0.18.04.1 all libexo common files
ii libexo-helpers 0.12.2-0ubuntu0.18.04.1 all helpers for the exo library
ii libexpat1:arm64 2.2.5-3ubuntu0.7 arm64 XML parsing C library - runtime library
ii libexpat1-dev:arm64 2.2.5-3ubuntu0.7 arm64 XML parsing C library - development kit
ii libext2fs2:arm64 1.44.1-1ubuntu1.3 arm64 ext2/ext3/ext4 file system libraries
ii libfdisk1:arm64 2.31.1-0.4ubuntu3.7 arm64 fdisk partitioning library
ii libfontconfig1:arm64 2.12.6-0ubuntu2 arm64 generic font configuration library - runtime
ii libfontembed1:arm64 1.20.2-0ubuntu3.1 arm64 OpenPrinting CUPS Filters - Font Embed Shared library
ii libfreetype6:arm64 2.8.1-2ubuntu2.1 arm64 FreeType 2 font engine, shared library files
ii libfuse2:arm64 2.9.7-1ubuntu1 arm64 Filesystem in Userspace (library)
ii libgail-common:arm64 2.24.32-1ubuntu1 arm64 GNOME Accessibility Implementation Library -- common modules
There are more packages but they don’t fit in the message…
Thank you for the support and I’m sorry again.
Ah okay that makes all sense then. Not sure whether Armbian ships an own/etc/os-release file, so probably it was interned, while it’s probably not smart given that the underlying base OS indeed is Ubuntu which should be represented by this file.
Since we use the same kernel for ROCK64 (from the Debian suite of the Armbian repo, but basically it’s the same) it makes sense that DietPi suffers from the same issue.
You may want to report it here, at least I do not see that it was retorted yet: https://forum.armbian.com/forum/21-rockchip-3288-3328/
Although, one problem is that the ROCK64 is not officially supported anymore, i.e. there is no Armbian maintainer for this SBC anymore, which may explain why this issue hasn’t been detected or fixed yet .
Thank you very much! I’ll report it to the Armbian forum and in the meantime I’ll tinker with other distros to see if there is one that works with the latest kernel. I flashed the other day the Armbian_21.08.1_Rock64_bullseye_current_5.10.60.img.xz image, updated everything and it worked but I didn’t test it properly and I didn’t check if it updated to the 5.15 kernel (we know 5.10 works). But in any case, the thought of having to configure everything again is putting me off
Another update that it could be interesting. I just flashed the image Armbian_21.08.1_Rock64_bullseye_current_5.10.60.img.xz, updated everything and the rock64 looks like it’s running fine!
javi@rock64:~$ uname -a
Linux rock64 5.15.25-rockchip64 #22.02.1 SMP PREEMPT Sun Feb 27 09:05:47 UTC 2022 aarch64 GNU/Linux
I’ve mounted an external USB3 HDD and done some quick testing:
Interesting. Probably something changed in the boot.cmd/scr/armbianEnv.txt which became required now. I’ll compare those. Ah and maybe a U-Boot upgrade was required, i.e. we didn’t test on the old image:
I’ve tried to run those two commands before updating linux-image-current-rockchip64 and linux-dbt-current-rockchip64 from 21.08.2 to 22.02.1 but the result was the same errors on the update and no network after reboot. I run them without sudo. They just didn’t print anything so I assumed they worked. Should I try with sudo? Typically if it’s needed you’re told that you don’t have permissions or it throws some kind of error.
Another update. I’ve tried running the two commands with sudo and removing the usb3 quirks but again, the result is the same. I’m not sure how to remove the quirks properly though because if you reboot, they appear again…
javi@rock64:~$ apt list --upgradable
Listing... Done
linux-dtb-current-rockchip64/bionic 22.02.1 arm64 [upgradable from: 21.08.2]
javi@rock64:~$ sudo su -
root@rock64:~# . /usr/lib/u-boot/platform_install.sh
root@rock64:~# write_uboot_platform "$DIR" "$(lsblk -npo PKNAME "$(findmnt -Ufnro SOURCE -M /)")"
root@rock64:~# reboot
javi@rock64:~$ sudo vim /boot/armbianEnv.txt
javi@rock64:~$ cat /boot/armbianEnv.txt
verbosity=1
overlay_prefix=rockchip
rootdev=UUID=1639309a-8d38-46b5-b9bc-ac91ff373f78
rootfstype=ext4
javi@rock64:~$ sudo apt upgrade
Calculating upgrade... Done
linux-dtb-current-rockchip64 linux-image-current-rockchip64
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 51.6 MB of archives.
After this operation, 122 MB disk space will be freed.
Do you want to continue? [Y/n]
Get:1 http://es.armbian.mirrors.bret.dk/apt bionic/main arm64 linux-dtb-current-rockchip64 arm64 22.02.1 [365 kB]
Get:2 http://mirrors.fossho.st/armbian/apt bionic/main arm64 linux-image-current-rockchip64 arm64 22.02.1 [51.2 MB]
Fetched 51.6 MB in 5s (11.2 MB/s)
(Reading database ... 109681 files and directories currently installed.)
Preparing to unpack .../linux-dtb-current-rockchip64_22.02.1_arm64.deb ...
Unpacking linux-dtb-current-rockchip64 (22.02.1) over (21.08.2) ...
Setting up linux-dtb-current-rockchip64 (22.02.1) ...
sudo sed -i '/usbstoragequirks/d' /boot/armbianEnv.txt
reboot
They are again/still there after reboot?
Btw, before upgrading U-Boot, assure that the U-Boot package is up-to-date as well:
apt install linux-u-boot-rock64-current
The U-Boot flashing itself indeed needs to be run as root. Failures are redirected to /dev/null along with other output, which isn’t so clever indeed. The following should work:
The write_uboot_platform alone cannot be executed with sudo, since it is a function created by sourcing the platform_install.sh. But sudo clears the environment, hence the function does not exist within the sudo environment. So both needs to be done in one sudo call.
