There is a dedicated field for the port, so don’t appens it to the URL and put it in the field below. Maybe this is the problem
The login data should be correct, works also on my phone with the login credentials I use on the Navidrome web panel.
thanks, but where could be my issue . even through the option of WebDavi cannot add my music folder.
i trield login through winsscp app on my windows pc ,then also i cannot login used default username dietpi and passsword. Is there any cchecking to be done on my Dietpi settings to connect through webdav .
Is that the cause of the problem
debug log created by symfonium while trying to add navidrome:
2024-06-27 06:54:01.149 Verbose/FirebaseManager: Result: T999
2024-06-27 06:54:01.159 Verbose/QueryBuilder: Query: SELECT sync_medias._id,sync_medias.date,sync_medias.from_device,sync_medias.provider_id,sync_medias.media_id,sync_medias.external_id,sync_medias.media_type,sync_medias.play_count,sync_medias.resume_point,sync_medias.title,sync_medias.file,sync_medias.last_played,sync_medias.is_favourite,sync_medias.user_rating FROM sync_medias WHERE (sync_medias.from_device=?) ('1') [0 in 0.24ms]
2024-06-27 06:54:01.162 Verbose/MediaUpdateManager: Updating play count queued media
2024-06-27 06:54:01.162 Verbose/MediaUpdateManager: Nothing to update
2024-06-27 06:54:01.163 Verbose/QueryBuilder: Query: SELECT sync_medias._id,sync_medias.date,sync_medias.from_device,sync_medias.provider_id,sync_medias.media_id,sync_medias.external_id,sync_medias.media_type,sync_medias.play_count,sync_medias.resume_point,sync_medias.title,sync_medias.file,sync_medias.last_played,sync_medias.is_favourite,sync_medias.user_rating FROM sync_medias WHERE (sync_medias.from_device=?) ('2') [0 in 0.23ms]
2024-06-27 06:54:01.163 Verbose/MediaUpdateManager: Updating favourite queued media
2024-06-27 06:54:01.163 Verbose/MediaUpdateManager: Nothing to update
2024-06-27 06:54:01.163 Verbose/Logger: Information: OnePlus7TPro/OnePlus7TPro/31/12/HD1911/OnePlus/0/true/92/126/19
2024-06-27 06:54:01.164 Verbose/QueryBuilder: Query: SELECT sync_medias._id,sync_medias.date,sync_medias.from_device,sync_medias.provider_id,sync_medias.media_id,sync_medias.external_id,sync_medias.media_type,sync_medias.play_count,sync_medias.resume_point,sync_medias.title,sync_medias.file,sync_medias.last_played,sync_medias.is_favourite,sync_medias.user_rating FROM sync_medias WHERE (sync_medias.from_device=?) ('3') [0 in 0.17ms]
2024-06-27 06:54:01.164 Verbose/MediaUpdateManager: Updating user rating queued media
2024-06-27 06:54:01.164 Verbose/MediaUpdateManager: Nothing to update
2024-06-27 06:54:01.164 Verbose/SyncManager: Pre sync (Local device)
2024-06-27 06:54:01.164 Verbose/SyncManager: Skip auto sync as too recent (Local device)
2024-06-27 06:54:01.165 Verbose/Logger: Information: 10.1.5b (12684[arm64-v8a,armeabi-v7a,armeabi]) - DisplayMetrics{density=3.0, width=1080, height=2292, scaledDensity=3.0, xdpi=386.366, ydpi=385.948} - BAT:false - FS:1.0 - AS:1.0 - (en_IN) ad86afb17d5a4b78 0AD944189897016665CBDE0953AABF54
2024-06-27 06:54:01.166 Verbose/Logger: Previous exit reason: 13/400 - [2024-06-26 23:18:06.417]
2024-06-27 06:54:07.138 Verbose/TestURL: --> [848] GET https://192.68.1.9:4533/rest/ping.view?u=REDACTED&p=REDACTED&v=1.13.1&c=Symfonium
2024-06-27 06:54:07.145 Verbose/TestURL: --> [848] connection: close
2024-06-27 06:54:07.148 Verbose/TestURL: --> [848] Authorization: BasicREDACTED
2024-06-27 06:54:12.152 Verbose/TestURL: <-- [848] HTTP FAILED: java.net.SocketTimeoutException: failed to connect to /192.68.1.9 (port 4533) from /192.168.1.16 (port 43630) after 5000ms
2024-06-27 06:54:12.154 Error/SubsonicAdd: IOException
at libcore.io.IoBridge.connectErrno(IoBridge.java:235)
at libcore.io.IoBridge.connect(IoBridge.java:179)
at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:142)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:390)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:230)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:212)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
at java.net.Socket.connect(Socket.java:646)
at j00.n.e(Unknown Source:0)
at d00.d.i(Unknown Source:68)
at d00.d.f(Unknown Source:16)
at d00.j.a(Unknown Source:2)
at c00.d.a(Unknown Source:15)
at a2.x.run(Unknown Source:912)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
at java.lang.Thread.run(Thread.java:1012)
2024-06-27 06:54:12.161 Verbose/TestURL: --> [577] GET http://192.68.1.9:4533/rest/ping.view?u=REDACTED&p=REDACTED&v=1.13.1&c=Symfonium
2024-06-27 06:54:12.162 Verbose/TestURL: --> [577] connection: close
2024-06-27 06:54:12.163 Verbose/TestURL: --> [577] Authorization: BasicREDACTED
2024-06-27 06:54:17.185 Verbose/TestURL: <-- [577] HTTP FAILED: java.net.SocketTimeoutException: failed to connect to /192.68.1.9 (port 4533) from /192.168.1.16 (port 43632) after 5000ms
2024-06-27 06:54:17.187 Error/SubsonicAdd: IOException
2024-06-27 06:54:17.197 Verbose/TestURL: --> [717] GET https://192.68.1.9:4533/rest/ping.view?u=REDACTED&p=REDACTED&v=1.13.1&c=Symfonium
2024-06-27 06:54:17.198 Verbose/TestURL: --> [717] connection: close
2024-06-27 06:54:17.199 Verbose/TestURL: --> [717] Authorization: BasicREDACTED
2024-06-27 06:54:22.198 Verbose/TestURL: <-- [717] HTTP FAILED: java.net.SocketTimeoutException: failed to connect to /192.68.1.9 (port 4533) from /192.168.1.16 (port 43634) after 5000ms
2024-06-27 06:54:22.203 Error/SubsonicAdd: IOException
You typed the IP wrong, look at your screenshot.
Same here, you used 192.68.1.9
but I bet right IP should be 192.168.1.9
Thanks now working fine.
Only issue pending is now the full albums/folders in my selected folder in navidrome is not loaded yet.
The scan icon is continuously spinning . But folders not adding.
The initial scan can take a while, if it’s still spinning it’s not finished yet.
If it hangs you can check
journalctl -u navidrome.service
PFA the file. please not e the spinning is happening for more than 24 hours
journal.txt (386.0 KB)
Any solution for the Navidrome library update issue.Scanning still spinning
Sry, I have no idea what went wrong.
How many songs do you have in your library?
Maybe you can create an issue on Github and ask the devs.
Arround 14000 songs
DietPi gmediarender[495]: unable to create directory ‘/nonexiste nt/.cache/dconf’: Permission denied. dconf will not work properly.
Please advise how to correct this
Please open anew topic for a new problem and provide more context.
