NanoPi Zero2 missing CPU temp/freq (again)
Hi!
Just received a new NanoPi Zero 2 with 64 G emmc and installed Dietpi latest image for this (today) Moved the system to emmc following instructions at Moving a running DietPi system to a USB stick/disk or an onboard eMMC
And most seems ok (although dietpi_drive-manager take a while to start).
I have found similar problem described in NanoPi Zero2 missing CPU temp/freq (no temp reading) :
cpu
DietPi CPU Info
Use dietpi-config to change CPU / performance options
Architecture | aarch64
Temperature | N/A
Governor | schedutil
             Current Freq    Min Freq   Max Freq
CPU0 | 1608 MHz 1200 MHz 2016 MHz
CPU1 | 1800 MHz 1200 MHz 2016 MHz
CPU2 | 1800 MHz 1200 MHz 2016 MHz
CPU3 | 1800 MHz 1200 MHz 2016 MHz
[ INFO ] DietPi-CPU_info | The current CPU frequency may be affected by processing this script itself.
Installed lm-sensors and sensors-detect reports no sensors were detected
Kernel is
uname -a
Linux NET 6.18.64-current-rockchip64 #1 SMP PREEMPT Tue Nov 17 10:11:40 UTC 2026 aarch64 GNU/Linux
It seems not to be “image-vendor” kernel, so I’ve tried the steps from @MichaIng but falling in
[FAILED] APT install linux-image-vendor-rk35xx linux-u-boot-radxa-zero3-vendor
  • Command: apt-get -y install linux-image-vendor-rk35xx linux-u-boot-radxa-zero3-vendor
    [FAILED] Unable to continue, command will now terminate.
Any advice?
Do not install the vendor kernel anymore. Just install the test kernel I built yesterday as we internally found and fixed that issue already. Use this command to install it:
G_DEV_TEST_FIRMWARE
