Move existing system from mmc to sd?
Device info in the linked topic
After strange issues of my running system out of nothíng
see
I decided to flash a new sd card and try to restore a backup to it after 1st boot (as I don’t have a second mmc at hand).
I got warnings that uuid doesn’t match and that I have to modify them in boot and fstab.
On the other side i read in an issue, that the script should change this after restore.
In my case the system won’t boot (reboot after restore). I actually lits steady green-blue and that’s it.
Can someone clarify the steps I have to make it running again? Are there further steps to do when moving from mmc to sd (as a fresh sd ?card is booting I should work without)?
I’ve just seen that the mmc device has 2 partitions (boot and /) but the freshly installed sd card has only one (and boot is a subdirectory of /).
Is this the reason for the boot problem? How can I modify the configuration for a working (restored) system?
Have a look at Merging disks to a large logical volume in DietPi – DietPi Blog
It should cover your case as well
Best to user dd command to migrate whole system
Amazing article! Raises the bar on how to write articles. Thanks again for sharing.
Thx to @StephanStS who is taking care on our blogs
I did an image backup with usbit and wrote it to an sdcard.
Everything is ok afterwards, so the cause seems to be a damaged emmc…
