How to solve Transmission or Delugeaccess denied access to external HD?
Similar to what has been stated above
chown -R dietpi:dietpi /mnt/HDD/
chmod -R 775 /mnt/HDD/
/mnt:
total 24
drwxr-xr-x  6 root   root   4096 Apr 21 14:49 .
drwxr-xr-x 18 root   root   4096 Apr 14 20:32 ..
drwxrwxr-x  3 dietpi dietpi 4096 Apr 21 14:25 HDD
drwxrwxr-x  6 dietpi dietpi 4096 Apr 21 14:22 dietpi_userdata
drwxrwxr-x  2 dietpi dietpi 4096 Mar 17 23:05 ftp_client
drwxrwxr-x  2 dietpi dietpi 4096 Mar 17 23:06 nfs_client
/mnt/HDD:
total 24
drwxrwxr-x 3 dietpi dietpi  4096 Apr 21 14:25 .
drwxr-xr-x 6 root   root    4096 Apr 21 14:49 ..
drwxrwxr-x 2 dietpi dietpi 16384 Apr 21 14:25 lost+found
Does it feel right that way?
how do i put the mnt/hdd folder as share?
Share for what?
the mnt/HDD folder I can’t share via samba, the mnt/dietpi_userdata folder is visible, how can I share this folder via samba, do I have to change any settings? Sorry, I’m kind of lost.
Probably you should have had a look to our online docs…File Servers Options - DietPi.com Docs
There it is explained how to change the destination directory.
I have to insert the folders or just copy the lines?
 sed -i '/path = /c\path = /Path/To/Directory' /etc/samba/smb.conf
systemctl restart nmbd smbd
you would need to replace the placeholder with your own path.
