I back up everything on google drive, and then I format the old drive and the new one as suggested and then again remounted both as raid…
Maybe I should delete and re-install owncloud from the beginning, using the raid as drive dedicated. What do you think?
I mean, if I remember well when I installed the first time owncloud, it already included some example files. in this way, I should re-start from the beginning.
I don’t use Owncloud. Therefore the question seems stupid. But how did you saved your data on Google Drive. Is there a function on Owncloud?
no there is no function for that. I just copy and paste there the owncloud content to avoid any data loss while creating the raid…
I think the problem is in the way we formatted the raid. Could it be possible?
Simply copying the data to Google Drive seems not the best idea as it did not preserve file permissions aso.
The raid is not the issue. Simply there are no data for Owncloud to work with. I guess you need to start with a fresh install of Owncloud to get it back working. Afterwards you could try to copy your data back in place. But Owncloud will not recognise them as they are not know by the database. Probably you need to run some import task to let Owncloud know, that there new data available on file system level. For Nextcloud I’m aware in such feature. For Owncloud I’m not sure. Probably they have. Maybe you will find in their docs.
ok, as I supposed I have to start again from the beginning.
Do you have any suggestions to delete the installation and all the files to avoid any future installation issues?
Simply uninstall Owncloud… usually this should create a database dump. Copy the dump into a different place afterwards. Once done install Owncloud again.
OK I’ll do it. I think anyway that I don’t need any DB dump since actually it is empty. How can I delete it? Or, if I have to move it how can I do?
Again good morning,
I uninstalled Owncloud and then again, tried to follow this tutorial https://dietpi.com/docs/software/cloud/#owncloud to re-install it.
After some obvious “DB already exists”, I arrived at the end without any other difficulties.
Now if I give this command sudo ls /mnt/ownclouddrive the output is:
crash-2022-03-01.log lost+found
dietpi-owncloud-database-backup.sql owncloud
dietpi-owncloud-installation-backup owncloud.log
I assume there are some files in the Owncloud directory… but still trying to reach it through the browser it gives me an HTTP ERROR 599.
Where am I going wrong?
I was wondering if at this point it’s recommended to restart from the beginning, re-installing the Operating System at all.
So, I maybe will be able to configure everything in the best way.
What do you think?
http 599 is some kind of network /connection/ time out. Could be all or nothing.
Did you had a look into crash-2022-03-01.log?
How can I have a look at that?
I’ve tried with pi-hole but didn’t find anything.
Is there a specific command?
did you tried using ip address to connect to Owncloud. I don’t think there is a need to have a look to PiHole.
On your owncloud drive, you have a file called crash-2022-03-01.log. Simply have a look inside. Maybe it contains useful information.
To get a clean install. Remove Owncloud again. Once done move all files/directories from inside /mnt/ownclouddrive somewhere else. Just to have a clean empty directory. Afterwards you should be able to install an empty/clean Owncloud (hopefully).
Sorry but maybe I’ve not explained well my situation:
I can’t reach the owncloud drive at all. when I try to type the IP address in the browser (192.168.1.15/owncloud) it returns me the error: The page is not working. If the problem persists, get in touch with the site owner. HTTP ERROR 599
This is the reason why I’m not able to find the crash-2022-03-01.log file…
Since I formatted both drive before creating the raid, I’m quite sure I can’t find any content in /mnt/ownclouddrive. isn’t it?
But in https://dietpi.com/forum/t/how-to-create-a-raid-on-owncloud-already-working/6341/48 the output shows there is crash-2022-03-01.log , so just have a look inside this file.
cat /mnt/ownclouddrive/crash-2022-03-01.log
Correct, you showed the output of the directory. Just go inside the folder and have a look. Just do it on CLI level and not in Owncloud.
OK, how can I have a look at that file on CLI?
Which is the right command?
as stated by Jappe above
I’ve tried with this command and it shows me tons of incomprehensible (for me at least
) rows.
Should I look for something particular in those rows?
you could try to download the log from your SBC and attach it to this post.
I can also share it here:
"file": "\/var\/www\/owncloud\/lib\/private\/Server.php",
"line": 256,
"function": "getDatabaseConnection",
"class": "OC\\Server"
"file": "\/var\/www\/owncloud\/lib\/composer\/pimple\/pimple\/src\/Pimple\/Container.php",
"line": 118,
"function": "OC\\{closure}",
"file": "\/var\/www\/owncloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php",
"line": 108,
"function": "offsetGet",
"class": "Pimple\\Container"
"file": "\/var\/www\/owncloud\/lib\/private\/ServerContainer.php",
"line": 86,
"function": "query",
"class": "OC\\AppFramework\\Utility\\SimpleContainer"
"line": 1105,
"class": "OC\\ServerContainer"
"line": 262,
"function": "getAccountMapper",
"line": 118,
"line": 108,
"line": 86,
"line": 1098,
"line": 322,
"function": "getUserManager",
"line": 118,
"line": 108,
"line": 86,
"line": 1122,
"line": 1129,
"function": "getUserSession",
"line": 819,
"function": "getSession",
"line": 118,
"line": 108,
"line": 86,
"line": 1613,
"line": 728,
"function": "getCsrfTokenManager",
"line": 118,
"line": 108,
"line": 86,
"line": 987,
"file": "\/var\/www\/owncloud\/lib\/private\/legacy\/response.php",
"line": 77,
"function": "getRequest",
"file": "\/var\/www\/owncloud\/status.php",
"line": 53,
"function": "setStatus",
"class": "OC_Response"
"date": "2022-03-01T07:29:45+00:00",
"parentId": null,
"id": "06d7593f3b9a849e5b93a6f0392a46c5621dcb69197681.38271638",
"class": "Doctrine\\DBAL\\DBALException",
"message": "Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [1698] Access denied for user 'oc_admin'@'localhost'",
"stacktrace": [
"file": "\/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php",
"line": 461,
"function": "connect",
"class": "OC\\DB\\Connection"
"line": 423,
"function": "getDatabasePlatformVersion",
"class": "Doctrine\\DBAL\\Connection"
"line": 365,
"function": "detectDatabasePlatform",
"line": 830,
"function": "getDatabasePlatform",
"file": "\/var\/www\/owncloud\/lib\/private\/DB\/Connection.php",
"line": 148,
"function": "setTransactionIsolation",
"file": "\/var\/www\/owncloud\/lib\/composer\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DriverManager.php",
"line": 270,
"function": "__construct",
"file": "\/var\/www\/owncloud\/lib\/private\/DB\/ConnectionFactory.php",
"line": 139,
"function": "getConnection",
"class": "Doctrine\\DBAL\\DriverManager"
"line": 552,
"class": "OC\\DB\\ConnectionFactory"
"line": 118,
"line": 108,
"line": 86,
"line": 1259,
"line": 424,
"line": 118,
"line": 108,
"line": 86,
"line": 1189,
"line": 607,
"function": "getAppConfig",
"line": 118,
"line": 108,
"line": 86,
"line": 1457,
"file": "\/var\/www\/owncloud\/lib\/private\/legacy\/app.php",
"line": 344,
"function": "getAppManager",
"line": 108,
"function": "getEnabledApps",
"class": "OC_App"
"file": "\/var\/www\/owncloud\/lib\/base.php",
"line": 590,
"function": "loadApps",
"class": "OC_App"
"line": 1070,
"function": "init",
"class": "OC"
"line": 34,
"function": "require_once"
"parentId": null,
"id": "06d7593f3b9a849e5b93a6f0392a46c5621dcb691a5b92.62550237",
"stacktrace": [
"line": 461,
"line": 423,
"line": 365,
"line": 830,
"line": 148,
"line": 270,
"line": 139,
"line": 552,
"line": 118,
"line": 108,
"line": 86,
"line": 1259,
"line": 256,
"line": 118,
"line": 108,
"line": 86,
"line": 1105,
"line": 262,
"line": 118,
"line": 108,
"line": 86,
"line": 1098,
"line": 322,
"line": 118,
"line": 108,
"line": 86,
"line": 1122,
"line": 1129,
"line": 819,
"line": 118,
"line": 108,
"line": 86,
"line": 1613,
"line": 728,
"line": 118,
"line": 108,
"line": 86,
"line": 987,
"line": 77,
"line": 53,
"date": "2022-03-01T07:30:20+00:00",
"parentId": null,
"id": "286b9d3e3179808b1297c7cc16492f8f621dcb8cd451e3.85487127",
"stacktrace": [
"line": 461,
"line": 423,
"line": 365,
"line": 830,
"line": 148,
"line": 270,
"line": 139,
"line": 552,
"line": 118,
"line": 108,
"line": 86,
"line": 1259,
"line": 424,
"line": 118,
"line": 108,
"line": 86,
"line": 1189,
"line": 607,
"line": 118,
"line": 108,
"line": 86,
"line": 1457,
"line": 344,
"line": 108,
"class": "OC_App"
"line": 590,
"class": "OC_App"
"line": 1070,
"function": "init",
"class": "OC"
"line": 34,
"parentId": null,
"id": "286b9d3e3179808b1297c7cc16492f8f621dcb8cdbe7b1.29874203",
"stacktrace": [
"line": 461,
"line": 423,
"line": 365,
"line": 830,
"line": 148,
"line": 270,
"line": 139,
"line": 552,
"line": 118,
"line": 108,
"line": 86,
"line": 1259,
"line": 256,
"line": 118,
"line": 108,
"line": 86,
"line": 1105,
"line": 262,
"line": 118,
"line": 108,
"line": 86,
"line": 1098,
"line": 322,
"line": 118,
"line": 108,
"line": 86,
"line": 1122,
"line": 1129,
"line": 819,
"line": 118,
"line": 108,
"line": 86,
"line": 1613,
"line": 728,
"line": 118,
"line": 108,
"line": 86,
"line": 987,
"line": 77,
"line": 53,
