ok, I entered the /etc/fstab file but there is no UUID=30c34f48-55f3-4e6e-b18f-2a72424cff6e /mnt/raid0 ext4 noatime,lazytime,rw,nofail,noauto,x-systemd.automount line in it.
Should I add the new one just above the # TMPFS section?
Is this enough?
strange, it was available on the output you shared on this post https://dietpi.com/forum/t/how-to-create-a-raid-on-owncloud-already-working/6341/17
Yes srange… but this is the output:
GNU nano 5.4 /etc/fstab
# NETWORK
192.168.1.112:/ /mnt/nfs_client nfs nofail,noauto,x-systemd.automount
# TMPFS
tmpfs /tmp tmpfs size=1024M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid,mode=1777
# MISC: ecryptfs, vboxsf, glusterfs, bind, Btrfs subvolume mounts
# SWAP SPACE
but you are missing half of the file now. It looks like it got cutted
That’s true… I didn’t scroll down the file
I’ve changed the line s suggested but still, when I try to reach from the browser owncloud this is the result:
Your directory data is not valid.
Verify the data directory contains a ".ocdata" file in its roots.
Your Data directory is not writable by ownCloud
The permissions can be changed <a href="https://doc.owncloud.com/server/10.8/go.php?to=admin-dir_permissions" target="_blank" rel="noreferrer">giving to the web server access to the root folder</a>.
How can I fix this?
can you share again following
df -h
cat /var/www/owncloud/config/config.php | grep datadirectory
ls -la /mnt/ownclouddrive
Here it is
root@DietPi:~# df -h
/dev/root 7.4G 3.6G 3.5G 52% /
devtmpfs 87M 0 87M 0% /dev
tmpfs 215M 2.8M 213M 2% /dev/shm
tmpfs 86M 4.0M 82M 5% /run
tmpfs 1.0G 0 1.0G 0% /tmp
tmpfs 50M 20K 50M 1% /var/log
/dev/mmcblk0p1 127M 52M 75M 42% /boot
tmpfs 43M 8.0K 43M 1% /run/user/998
/dev/md0 916G 32K 870G 1% /mnt/ownclouddrive
root@DietPi:~# cat /var/www/owncloud/config/config.php | grep datadirectory
'datadirectory' => '/mnt/ownclouddrive',
root@DietPi:~# ls -la /mnt/ownclouddrive
total 28
drwxr-xr-x 4 root root 4096 Feb 23 22:16 .
drwxr-xr-x 10 root root 4096 Feb 24 22:21 ..
drwx------ 2 root root 16384 Feb 23 22:06 lost+found
drwxr-xr-x 2 www-data www-data 4096 Feb 23 22:16 owncloud
well your current setup did not match your old one. Before, all your data are located directly within /mnt/ownclouddrive. But now, you have created a sub folder owncloud inside /mnt/ownclouddrive. Therefore Owncloud is not able to find your data. I would recommend to move all data from inside /mnt/ownclouddrive/owncloud 1 level above to be located directly in /mnt/ownclouddrive.
btw Raid0 is not the best choice from my point of view. Advantages and Disadvantages of Raid Levels - Stellar Data Recovery
RAID 0 does not provide redundancy or fault tolerance for handling disk failures, same as with a spanned volume. Thus, failure of one disk > causes complete RAID data loss > and reduces the possibility of RAID data recovery in comparison to a broken spanned volume.
ok, but how can I move data one level above, if I can’t access owndata?
try following
cp -a /mnt/ownclouddrive/owncloud/. /mnt/ownclouddrive/
After this, it can’t reach the owncloud anymore…
what do you mean by this? If I understood correctly Owncloud was not working before ether? Can you share
ls -la /mnt/ownclouddrive/
Before, the owncloud page appeared but the page told me the .ocdata was missing. Now the browser tells me server not found.
Anyway, this is the output:
total 40
drwxrwx--- 4 www-data www-data 4096 Feb 28 07:50 .
-rw-r----- 1 www-data www-data 11991 Feb 28 13:00 owncloud.log
nothing seems to be copied. can you share
ls -la /mnt/ownclouddrive/owncloud/
Your web server is running?
This is the output
total 8
drwxr-xr-x 2 www-data www-data 4096 Feb 23 22:16 .
drwxrwx--- 4 www-data www-data 4096 Feb 28 07:50 ..
I’m not sure the web server is running. How can I check it?
BTW I checked trying to reach the dietpi IP directly in the browser and a Lighttpd server package placeholder page appeared. So I suppose it is working… or not?
/mnt/ownclouddrive/owncloud/ is empty as well. Did you copied back your data already?
This would fit to this view not showing any data as well
No, I’ve not copied any data in the new “owncloud raid version”. I was waiting to configure everything in the right way.
Should I? If yes how without the owncloud GUI?
Ahmm how did you backup your data before? I mean it’s quite logic that Owncloud is not working if you don’t have any data available.
