looks like there is no such file or directory… I mean with this command cat /var/www/owncloud/config/config.php | grep dbpassword
this is the answer:
cat: /var/www/owncloud/config/config.php: No such file or directory/code]
I'm really in confusion now.
I'm seriously thinking to format everything and start again from the beginning...
Now I’ve re-installed everything trying to connect through ssh it gives me this error:
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the xxxxxxx key sent by the remote host is
SHA256:'a big string with a lot of letters and numbers'.
Please contact your system administrator.
Add correct host key in /Users/mymacuser/.ssh/known_hosts to get rid of this message.
Offending xxxxxx key in /Users/mymacuser/.ssh/known_hosts:4
Host key for 192.168.1.15 has changed and you have requested strict checking.
Host key verification failed.
