Hi team,
I am facing a weird issue. I have connected an external Crucial 240 GB SSD to USB 3.0 port. This drive randomly gets I/O error. I got it replaced but new one also gives same errors if I check the kernel logs using command “dmesg -l err,crit,alert,emerg”. This pi 4 has immich installed through Docker.
I am using DietPi v9.1.1.
I get below output on dmesg command:
[ 0.565646] bcm2708_fb soc:fb: Unable to determine number of FBs. Disabling driver.
[ 856.029264] xhci_hcd 0000:01:00.0: xHCI host controller not responding, assume dead
[ 856.029354] xhci_hcd 0000:01:00.0: HC died; cleaning up
[ 856.030280] I/O error, dev sda, sector 2160 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030299] Buffer I/O error on dev sda1, logical block 14, lost async page write
[ 856.030418] I/O error, dev sda, sector 2176 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030429] Buffer I/O error on dev sda1, logical block 16, lost async page write
[ 856.030490] I/O error, dev sda, sector 2208 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030502] Buffer I/O error on dev sda1, logical block 20, lost async page write
[ 856.030545] I/O error, dev sda, sector 16975712 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030559] Buffer I/O error on dev sda1, logical block 2121708, lost async page write
[ 856.030599] I/O error, dev sda, sector 16975728 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030612] Buffer I/O error on dev sda1, logical block 2121710, lost async page write
[ 856.030652] I/O error, dev sda, sector 25429920 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030665] Buffer I/O error on dev sda1, logical block 3178484, lost async page write
[ 856.030703] I/O error, dev sda, sector 25708400 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030715] Buffer I/O error on dev sda1, logical block 3213294, lost async page write
[ 856.030757] I/O error, dev sda, sector 26314152 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030769] Buffer I/O error on dev sda1, logical block 3289013, lost async page write
[ 856.030807] I/O error, dev sda, sector 26707408 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030819] Buffer I/O error on dev sda1, logical block 3338170, lost async page write
[ 856.030856] I/O error, dev sda, sector 26839032 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 2
[ 856.030869] Buffer I/O error on dev sda1, logical block 3354623, lost async page write
[ 856.081220] EXT4-fs error (device sda1): ext4_check_bdev_write_error:218: comm kworker/u8:4: Error while async write back metadata
[ 856.081290] Aborting journal on device sda1-8.
[ 856.081307] EXT4-fs error (device sda1) in ext4_reserve_inode_write:5839: Journal has aborted
[ 856.081324] EXT4-fs error (device sda1): __ext4_ext_dirty:202: inode #3556560: comm kworker/u8:4: mark_inode_dirty error
[ 856.081347] EXT4-fs error (device sda1): ext4_check_bdev_write_error:218: comm kworker/u8:4: Error while async write back metadata
[ 856.081349] JBD2: I/O error when updating journal superblock for sda1-8.
[ 856.081366] EXT4-fs error (device sda1) in ext4_mb_clear_bb:6077: Journal has aborted
[ 856.081381] EXT4-fs (sda1): Delayed block allocation failed for inode 3556560 at logical offset 0 with max blocks 83 with error 30
[ 856.081395] EXT4-fs (sda1): This should not happen!! Data will be lost
[ 856.081422] EXT4-fs error (device sda1) in ext4_writepages:2854: Journal has aborted
[ 856.082069] EXT4-fs error (device sda1): ext4_journal_check_start:83: comm kworker/u8:4: Detected aborted journal
[ 856.082177] EXT4-fs (sda1): previous I/O error to superblock detected
[ 856.082220] EXT4-fs (sda1): I/O error while writing superblock
[ 856.082251] EXT4-fs (sda1): Remounting filesystem read-only
[ 856.082262] EXT4-fs (sda1): ext4_writepages: jbd2_start: 9223372036854775807 pages, ino 3556561; err -30
[ 8972.824150] EXT4-fs error (device sda1): __ext4_find_entry:1664: inode #3538945: comm immich_server: reading directory lblock 0
[ 8973.075529] EXT4-fs error (device sda1): __ext4_find_entry:1664: inode #3540444: comm immich_server: reading directory lblock 0
[ 8973.102745] EXT4-fs error (device sda1): __ext4_find_entry:1664: inode #3540444: comm immich_server: reading directory lblock 0
[ 8973.723127] EXT4-fs error (device sda1): __ext4_find_entry:1664: inode #3538945: comm immich_server: reading directory lblock 0
[ 8973.823943] EXT4-fs error (device sda1): __ext4_find_entry:1664: inode #3538945: comm immich_server: reading directory lblock 0
[ 8973.871829] EXT4-fs error (device sda1): __ext4_find_entry:1664: inode #3538945: comm immich_server: reading directory lblock 0
Thank you.
