Which is the difference between Dietpi-Vpn and NordVPN official script to connect my DietPi server to NordVPN?
NordVPN official: Installing NordVPN on Linux distributions | NordVPN support
My DietPi server is already a vpn server with Wireguard (installed through PiVPN) where my cllents connect to.
My goal is to create a mixed “double vpn” :
client —> Tunnel wg0 —> My DietPi server —> Tunnel Wireguard/OpenVPN —> NordVPN server ----> Internet
Thanks.
Basically we use similar method to connect to PiVPN using OpenVPN protocol.
But it might be a challenge to have clients connected because as soon as PiVPN is active, whole traffic will be moved to that VPN interface. Means, you would need to exclude Wireguard local service from that tunnel. Otherwise Wireguard will not be reachable. Some manual work would be needed. Our tooling is not supporting such setup ootb as of now.
Any link to suggest? Thanks.
I’n not a network export. Maybe @trendy could give a comment.
We have discussed it here in the past.
Thought it might be easier to create a new topic, instead of using an old guide: this one .
Basic information
DietPi version:
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=5
G_DIETPI_VERSION_RC=1
Distro version:
bullseye 0
Kernel version:
Linux DietPi 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
SBC model:
RPi 3 Model B (aarch64)
Power supply used: 5V 2A
SD card used: Samsung FIT 32GB
Additional Infor…
I want to setup a dietpi which is accessible via wifi, gets its internet connection via eth0 (hotspot mode) BUT also can connect to a VPN.
Second requirement: It should ONLY then provide internet access when VPN is connected.
I just made a fresh dietpi installation on RPI 4.
I installed dietpis hotspot mode and it works just fine.
I also installed (apt-get) vpnc to connect to another network (remote fritz box offering VPN service). This also works from the dietpi itself, but not from wi…
Let us know if you need some additional help.
