Changing password using web interface
just installed diet pi and have the pihole web interface up. the password that was generated is not something I want to use. using the web interface, how do I change my admin password? if this is too confusing its just me wanting to use the web interface to change my password. I see no category or listing to do so.
Maybe the docs help (RTFM): See DNS Servers Options - DietPi.com Docs and look for the tab “Setting the password”.
what an asshole you are. thanks for nothing asshole.
In the dashboard you can use also the terminal to change passwords.
You can simply do the with dietpi-dashboard or/and have a look here https://dietpi.com/docs/dietpi_tools/system_configuration/
If you again insult users in this forum you will get banned.
@StephanStS you can link to the tab directly within our online docs nowadays. I updated your link. Hope it was ok
@Jappe nothing to add from my side. :+1:
@OneOfOne Think about your behaviour if you want people to help you. @StephanStS was giving you the correct answer on how to change admin password on PiHole. Another source would be official PiHole docs How do I set or reset the Web interface Password? - FAQs - Pi-hole Userspace and The pihole command - Pi-hole documentation - Pi-hole documentation
RTFM is helping people? you seem like quite the egomaniac. fortunately there are other sources with actual help from members.
Just because you are too lazy to read the documentation does not give you the right to insult others.
