As you can see, root.
See the return of your commands:
it looks like the backup did no exist. Can you slowly move within the backup tree to see where it stop?
BTW: if you like to share content from your system, use SSH connection and simply copy/post the data. It will be better readable than a screen print ![]()
Don’t know where it stopped, so went again to the backup tool, and then tried to change the location to my NAS, and got this error (didn’t happen the first time):
Btw, understood your tip to share content!
Update:
I did the command again “mount 192.168.31.8:/DietPi /mnt/Backup”.
Then selected my Nas as the Backup target.
I got the same errors, but can’t see all the errors.
Where can i found the backup log file to share it?
the directory on your screen print is different from the directory you specified on the mount command
mount >> /mnt/Backup
screen >> /mnt/discorede
It is true, somehow it changed. But like i told you, i runned the mount line again to the correct one.
Run the backup again, but the same errors. If you tell me where is the backup log file, i can put it here?
once backup failed, you can check it as follow
cat /var/log/dietpi-backup.log
CIFS = Samba does not support UNIX permissions so cannot be used for system backups, so it needs to be a NFS share that, on the server-side file system, supports UNIX permissions. In case of NFS also assure that the server daemon runs as root, so that it can change file owners. I’m not sure how this is handled on those NAS boxes
Ok, it is a long paste!!!
See if you find out what can be wrong, please.
DietPi-Backup Log File. 2020-12-29_17:41:09
2020/12/29 17:41:23 [16468] building file list
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/.” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/bzcmp” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/bzegrep” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/bzfgrep” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/bzless” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/dnsdomainname” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/domainname” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/lsmod” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/nisdomainname” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/pidof” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/ping4” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/ping6” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/rbash” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/rnano” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/sh” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/systemd” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/bin/ypdomainname” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/boot” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/boot/dietpi” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/boot/dietpi/func” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/boot/dietpi/misc” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/boot/overlays” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/localtime” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/mtab” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/os-release” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rmt” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/UPower” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/openbox” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/Xreset.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/Xresources” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/Xsession.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/app-defaults” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/fonts” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/fonts/misc” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/xinit” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/xkb” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/X11/xorg.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.cs.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.de.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.es.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.fi.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.fr.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.gl.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.it.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.ja.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/aptitude.pl.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/awk” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/awk.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/builtins.7.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/cpp” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/editor” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/editor.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/gnome-text-editor” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/gnome-text-editor.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/gnome-www-browser” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/gnome-www-browser.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/idmap-plugin” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/idmap-plugin.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/lightdm-greeter” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/nawk” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/nawk.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/pager” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/pager.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/pico” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/pico.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/pinentry” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/pinentry.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/rmt” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/rmt.8.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/w” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/w.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-cursor-theme” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-session-manager” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-session-manager.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-terminal-emulator” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-terminal-emulator.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-window-manager” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-window-manager.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-www-browser” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/alternatives/x-www-browser.1.gz” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apm” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apm/event.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apparmor.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apparmor.d/abstractions” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apt” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apt/apt.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apt/auth.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apt/preferences.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apt/sources.list.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/apt/trusted.gpg.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/bashrc.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/bashrc.d/dietpi-bash_completion.sh” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/binfmt.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/ca-certificates” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/ca-certificates/update.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cifs-utils” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cifs-utils/idmap-plugin” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/console-setup” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cron.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cron.daily” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cron.hourly” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cron.minutely” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cron.monthly” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/cron.weekly” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dbus-1” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dbus-1/session.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dbus-1/system.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/default” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dhcp” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dhcp/dhclient-enter-hooks.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dhcp/dhclient-enter-hooks.d/debug” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dhcp/dhclient-exit-hooks.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dhcp/dhclient-exit-hooks.d/debug” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dpkg” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dpkg/dpkg.cfg.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dpkg/origins” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dpkg/origins/default” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dropbear” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dropbear/log” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/dropbear/log/main” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/exports.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/firefox-esr” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/firewalld” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/firewalld/services” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.avail” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/10-hinting-slight.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/10-scale-bitmap-fonts.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/11-lcdfilter-default.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-dejavu-lgc-sans-mono.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-dejavu-lgc-sans.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-dejavu-lgc-serif.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-dejavu-sans-mono.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-dejavu-sans.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-dejavu-serif.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/20-unhint-small-vera.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/30-metric-aliases.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/40-nonlatin.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/45-generic.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/45-latin.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/49-sansserif.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/50-user.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/51-local.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/57-dejavu-sans-mono.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/57-dejavu-sans.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/57-dejavu-serif.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/58-dejavu-lgc-sans-mono.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/58-dejavu-lgc-sans.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/58-dejavu-lgc-serif.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/60-generic.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/60-latin.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/65-fonts-persian.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/65-nonlatin.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/69-unifont.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/70-no-bitmaps.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/80-delicious.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/fonts/conf.d/90-synthetic.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/glvnd” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/glvnd/egl_vendor.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/gss” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/gss/mech.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/gtk-2.0” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/gtk-3.0” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/init.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/init” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/insserv.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/iproute2” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/iproute2/rt_protos.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/iproute2/rt_tables.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/kernel” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/kernel/install.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/kernel/postinst.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/ld.so.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/ldap” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/lightdm” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/logcheck” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/logcheck/ignore.d.server” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/logcheck/violations.ignore.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/logrotate.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/menu-methods” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/modprobe.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/modules-load.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/modules-load.d/modules.conf” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/network” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/network/if-down.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/network/if-post-down.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/network/if-pre-up.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/network/if-up.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/network/interfaces.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/opt” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/pam.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/perl” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/perl/CPAN” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/perl/Net” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority/10-vendor.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority/20-org.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority/30-site.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority/50-local.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/localauthority/90-mandatory.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/polkit-1/nullbackend.conf.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/profile.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/python” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/python2.7” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/python3.7” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/python3” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01alsa-utils” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01dropbear” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01lightdm” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01nfs-common” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01nfs-kernel-server” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01rng-tools” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01rpcbind” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01rpimonitor” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01udev” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc0.d/K01urbackupsrv” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01alsa-utils” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01dropbear” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01lightdm” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01nfs-common” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01nfs-kernel-server” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01rng-tools” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01rpcbind” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01rpimonitor” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc1.d/K01urbackupsrv” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/K01cron” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/K01nfs-kernel-server” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/K01rpimonitor” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/K01urbackupsrv” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/S01dbus” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/S01dropbear” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/S01lightdm” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/S01rng-tools” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] rsync: chown “/mnt/Backup/dietpi-backup/data/etc/rc2.d/S01rsync” failed: Operation not permitted (1)
2020/12/29 17:41:23 [16468] .d…og… ./
2020/12/29 17:41:23 [16468] .d…pog… bin/
2020/12/29 17:41:23 [16468] >f…tpog… bin/bash
2020/12/29 17:41:23 [16468] >f…tpog… bin/bunzip2
2020/12/29 17:41:23 [16468] >f…tpog… bin/bzdiff
2020/12/29 17:41:23 [16468] >f…tpog… bin/bzexe
2020/12/29 17:41:23 [16468] >f…tpog… bin/bzgrep
2020/12/29 17:41:23 [16468] >f…tpog… bin/bzip2recover
2020/12/29 17:41:23 [16468] >f…tpog… bin/bzmore
2020/12/29 17:41:23 [16468] >f…tpog… bin/cat
2020/12/29 17:41:23 [16468] >f…tpog… bin/chgrp
2020/12/29 17:41:23 [16468] >f…tpog… bin/chmod
2020/12/29 17:41:24 [16468] >f…tpog… bin/chown
2020/12/29 17:41:24 [16468] >f…tpog… bin/chvt
2020/12/29 17:41:24 [16468] >f…tpog… bin/cp
2020/12/29 17:41:24 [16468] >f…tpog… bin/dash
2020/12/29 17:41:24 [16468] >f…tpog… bin/date
2020/12/29 17:41:24 [16468] >f…tpog… bin/dd
2020/12/29 17:41:24 [16468] >f…tpog… bin/df
2020/12/29 17:41:24 [16468] >f…tpog… bin/dir
2020/12/29 17:41:24 [16468] >f…tpog… bin/dmesg
2020/12/29 17:41:24 [16468] >f…tpog… bin/dumpkeys
2020/12/29 17:41:24 [16468] >f…tpog… bin/echo
2020/12/29 17:41:24 [16468] >f…tpog… bin/egrep
2020/12/29 17:41:24 [16468] >f…tpog… bin/false
2020/12/29 17:41:24 [16468] >f…tpog… bin/fgconsole
2020/12/29 17:41:24 [16468] >f…tpog… bin/fgrep
2020/12/29 17:41:24 [16468] >f…tpog… bin/findmnt
2020/12/29 17:41:24 [16468] >f…tpog… bin/fuser
2020/12/29 17:41:24 [16468] >f…tpog… bin/grep
2020/12/29 17:41:24 [16468] >f…tpog… bin/gunzip
2020/12/29 17:41:24 [16468] >f…tpog… bin/gzexe
2020/12/29 17:41:24 [16468] >f…tpog… bin/gzip
2020/12/29 17:41:24 [16468] >f…tpog… bin/hostname
2020/12/29 17:41:24 [16468] >f…tpog… bin/ip
2020/12/29 17:41:24 [16468] >f…tpog… bin/journalctl
2020/12/29 17:41:24 [16468] >f…tpog… bin/kbd_mode
2020/12/29 17:41:24 [16468] >f…tpog… bin/keyctl
2020/12/29 17:41:24 [16468] >f…tpog… bin/kill
2020/12/29 17:41:24 [16468] >f…tpog… bin/kmod
2020/12/29 17:41:24 [16468] >f…tpog… bin/ln
2020/12/29 17:41:24 [16468] >f…tpog… bin/loadkeys
2020/12/29 17:41:24 [16468] >f…tpog… bin/login
2020/12/29 17:41:24 [16468] >f…tpog… bin/loginctl
2020/12/29 17:41:24 [16468] >f…tpog… bin/ls
2020/12/29 17:41:24 [16468] >f…tpog… bin/lsblk
2020/12/29 17:41:24 [16468] >f…tpog… bin/mkdir
2020/12/29 17:41:24 [16468] >f…tpog… bin/mknod
2020/12/29 17:41:24 [16468] >f…tpog… bin/mktemp
2020/12/29 17:41:24 [16468] >f…tpog… bin/more
2020/12/29 17:41:24 [16468] >f…tpog… bin/mount
2020/12/29 17:41:24 [16468] >f…tpog… bin/mountpoint
2020/12/29 17:41:24 [16468] >f…tpog… bin/mv
2020/12/29 17:41:24 [16468] >f…tpog… bin/nano
2020/12/29 17:41:24 [16468] >f…tpog… bin/networkctl
2020/12/29 17:41:24 [16468] >f…tpog… bin/openvt
2020/12/29 17:41:24 [16468] >f…tpog… bin/ping
2020/12/29 17:41:24 [16468] >f…tpog… bin/ps
2020/12/29 17:41:24 [16468] >f…tpog… bin/pwd
2020/12/29 17:41:24 [16468] >f…tpog… bin/readlink
2020/12/29 17:41:24 [16468] >f…tpog… bin/rm
2020/12/29 17:41:24 [16468] >f…tpog… bin/rmdir
2020/12/29 17:41:24 [16468] >f…tpog… bin/run-parts
2020/12/29 17:41:24 [16468] >f…tpog… bin/sed
2020/12/29 17:41:24 [16468] >f…tpog… bin/setfont
2020/12/29 17:41:24 [16468] >f…tpog… bin/setupcon
2020/12/29 17:41:24 [16468] >f…tpog… bin/sleep
2020/12/29 17:41:24 [16468] >f…tpog… bin/ss
2020/12/29 17:41:24 [16468] >f…tpog… bin/stty
2020/12/29 17:41:24 [16468] >f…tpog… bin/su
2020/12/29 17:41:24 [16468] >f…tpog… bin/sync
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemctl
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-ask-password
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-escape
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-hwdb
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-inhibit
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-machine-id-setup
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-notify
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-sysusers
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-tmpfiles
2020/12/29 17:41:24 [16468] >f…tpog… bin/systemd-tty-ask-password-agent
2020/12/29 17:41:24 [16468] >f…tpog… bin/tar
2020/12/29 17:41:24 [16468] >f…tpog… bin/tempfile
2020/12/29 17:41:24 [16468] >f…tpog… bin/touch
2020/12/29 17:41:24 [16468] >f…tpog… bin/true
2020/12/29 17:41:24 [16468] >f…tpog… bin/udevadm
2020/12/29 17:41:24 [16468] >f…tpog… bin/umount
2020/12/29 17:41:24 [16468] >f…tpog… bin/uname
2020/12/29 17:41:24 [16468] >f…tpog… bin/unicode_start
2020/12/29 17:41:24 [16468] >f…tpog… bin/vdir
2020/12/29 17:41:24 [16468] >f…tpog… bin/wdctl
2020/12/29 17:41:24 [16468] >f…tpog… bin/which
2020/12/29 17:41:24 [16468] >f…tpog… bin/zcat
2020/12/29 17:41:24 [16468] >f…tpog… bin/zcmp
2020/12/29 17:41:24 [16468] >f…tpog… bin/zdiff
2020/12/29 17:41:24 [16468] >f…tpog… bin/zegrep
2020/12/29 17:41:24 [16468] >f…tpog… bin/zfgrep
2020/12/29 17:41:24 [16468] >f…tpog… bin/zforce
2020/12/29 17:41:24 [16468] >f…tpog… bin/zgrep
2020/12/29 17:41:24 [16468] >f…tpog… bin/zless
2020/12/29 17:41:24 [16468] >f…tpog… bin/zmore
2020/12/29 17:41:24 [16468] >f…tpog… bin/znew
2020/12/29 17:41:24 [16468] .d…pog… boot/
2020/12/29 17:41:24 [16468] >f…tpog… boot/COPYING.linux
2020/12/29 17:41:24 [16468] >f+++++++++ boot/FSCK0000.REC
2020/12/29 17:41:24 [16468] >f…tpog… boot/LICENCE.broadcom
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2708-rpi-b-plus.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2708-rpi-b-rev1.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2708-rpi-b.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2708-rpi-cm.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2708-rpi-zero-w.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2708-rpi-zero.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2709-rpi-2-b.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2710-rpi-2-b.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2710-rpi-3-b-plus.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2710-rpi-3-b.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2710-rpi-cm3.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2711-rpi-4-b.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2711-rpi-400.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bcm2711-rpi-cm4.dtb
2020/12/29 17:41:24 [16468] >f…tpog… boot/bootcode.bin
2020/12/29 17:41:24 [16468] >f…tpog… boot/cmdline.txt
2020/12/29 17:41:24 [16468] >f…tpog… boot/config.txt
2020/12/29 17:41:24 [16468] >f…tpog… boot/dietpi-CHANGELOG.txt
2020/12/29 17:41:24 [16468] >f…tpog… boot/dietpi-LICENSE.txt
2020/12/29 17:41:24 [16468] >f…tpog… boot/dietpi-README.md
2020/12/29 17:41:24 [16468] >f…tpog… boot/dietpi.txt
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup4.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup4cd.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup4db.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup4x.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup_cd.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup_db.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/fixup_x.dat
2020/12/29 17:41:24 [16468] >f…tpog… boot/issue.txt
2020/12/29 17:41:25 [16468] >f…tpog… boot/kernel.img
2020/12/29 17:41:25 [16468] >f…tpog… boot/kernel7.img
2020/12/29 17:41:26 [16468] >f…tpog… boot/kernel7l.img
2020/12/29 17:41:26 [16468] >f…tpog… boot/kernel8.img
2020/12/29 17:41:28 [16468] >f…tpog… boot/start.elf
2020/12/29 17:41:28 [16468] >f…tpog… boot/start4.elf
2020/12/29 17:41:28 [16468] >f…tpog… boot/start4cd.elf
2020/12/29 17:41:28 [16468] >f…tpog… boot/start4db.elf
2020/12/29 17:41:29 [16468] >f…tpog… boot/start4x.elf
2020/12/29 17:41:29 [16468] >f…tpog… boot/start_cd.elf
2020/12/29 17:41:29 [16468] >f…tpog… boot/start_db.elf
2020/12/29 17:41:29 [16468] >f…tpog… boot/start_x.elf
2020/12/29 17:41:29 [16468] .d…pog… boot/dietpi/
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-autostart_index
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-backup_inc_exc
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-cleaner
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-cleaner_custom_files
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-services_include_exclude
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-sync_inc_exc
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.dietpi-sync_settings
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.hw_model
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.install_stage
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.installed
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.prep_info
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/.version
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/boot
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/dietpi-autostart
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/dietpi-backup
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/dietpi-bugreport
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/dietpi-cleaner
2020/12/29 17:41:29 [16468] >f…tpog… boot/dietpi/dietpi-cloudshell
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-config
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-cpuinfo
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-cron
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-drive_manager
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-explorer
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-launcher
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-led_control
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-letsencrypt
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-login
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-morsecode
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-services
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-software
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-survey
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-sync
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/dietpi-update
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/postboot
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/preboot
2020/12/29 17:41:30 [16468] .d…pog… boot/dietpi/func/
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/change_hostname
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/create_mysql_db
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-banner
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-benchmark
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-globals
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-logclear
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-obtain_hw_model
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-optimal_mtu
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-ramlog
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-set_cpu
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-set_hardware
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-set_software
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-set_swapfile
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-set_userdata
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/dietpi-wifidb
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/obtain_network_details
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/func/run_ntpd
2020/12/29 17:41:30 [16468] .d…pog… boot/dietpi/misc/
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/misc/dietpi-arr_to_RAM
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/misc/dietpi-justboom
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/misc/dietpi-nordvpn
2020/12/29 17:41:30 [16468] >f…tpog… boot/dietpi/misc/start_kodi
2020/12/29 17:41:30 [16468] .d…pog… boot/overlays/
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/README
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/act-led.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/adafruit18.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/adau1977-adc.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/adau7002-simple.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/ads1015.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/ads1115.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/ads7846.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/adv7282m.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/adv728x-m.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/akkordion-iqdacplus.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/allo-boss-dac-pcm512x-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/allo-boss2-dac-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/allo-digione.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/allo-katana-dac-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/allo-piano-dac-pcm512x-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/anyspi.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/apds9960.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/applepi-dac.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/at86rf233.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/audioinjector-addons.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/audioinjector-isolated-soundcard.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/audioinjector-ultra.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/audioinjector-wm8731-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/audiosense-pi.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/audremap.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/balena-fin.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/cma.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dht11.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dionaudio-loco-v2.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dionaudio-loco.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/disable-bt.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/disable-wifi.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dpi18.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dpi24.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/draws.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dwc-otg.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/dwc2.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/enc28j60-spi2.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/enc28j60.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/exc3000.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/fe-pi-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/fsm-demo.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/ghost-amp.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/goodix.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/googlevoicehat-soundcard.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-fan.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-ir-tx.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-ir.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-key.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-no-bank0-irq.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-no-irq.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-poweroff.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/gpio-shutdown.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hd44780-lcd.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hdmi-backlight-hwhack-gpio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-amp.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-dac.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-dacplus.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-dacplusadc.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-dacplusadcpro.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-dacplusdsp.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-dacplushd.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-digi-pro.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hifiberry-digi.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/highperi.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hy28a.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hy28b-2017.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/hy28b.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i-sabre-q2m.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-bcm2708.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-gpio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-mux.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-pwm-pca9685a.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-rtc-gpio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-rtc.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c-sensor.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c0.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c1.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c3.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c4.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c5.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2c6.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/i2s-gpio28-31.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/ilitek251x.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/imx219.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/imx290.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/imx477.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/iqaudio-codec.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/iqaudio-dac.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/iqaudio-dacplus.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/iqaudio-digi-wm8804-audio.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/irs1125.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/jedec-spi-nor.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/justboom-both.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/justboom-dac.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/justboom-digi.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/ltc294x.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/max98357a.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/maxtherm.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/mbed-dac.dtbo
2020/12/29 17:41:30 [16468] >f…tpog… boot/overlays/mcp23017.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp23s17.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp2515-can0.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp2515-can1.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp251xfd.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp3008.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp3202.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mcp342x.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/media-center.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/merus-amp.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/midi-uart0.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/midi-uart1.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/miniuart-bt.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mmc.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mpu6050.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/mz61581.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/ov5647.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/ov7251.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/ov9281.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/overlay_map.dtb
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/papirus.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pca953x.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pibell.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pifacedigital.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pifi-40.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/piglow.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/piscreen.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/piscreen2r.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pisound.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pitft22.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pitft28-capacitive.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pitft28-resistive.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pitft35-resistive.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pps-gpio.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pwm-2chan.dtbo
2020/12/29 17:41:31 [16468] >f…tpog… boot/overlays/pwm-ir-tx.dtbo
Didn’t let me paste all at once!
I guess it will take 4 ou 5 times!
Should i do it?
Do i have any option to get the file from the Dietpi and attach it here?
simply attach the log as real file if needed
Ok, here it is!
Had to compress it, otherwise it will exceed the 5MB limit
dietpi-backup.log.7z (106 Bytes)
Just watched the file and it was sizing 0bytes, so i runned the backup again and it hangs.
Really don’t know what else i can do…
I guess i have to buy a simply pen drive to do the backups!
unfortunately the log is empty. There is just an empty file in your 7z
But what I have seen so far from the other post are permission issues. You are not able to change permission on the NFS server.
Just came here to say I use dietpi-backup to a QNAP NAS over NFS just as OP is asking for and it does work fine. The high level steps I followed were:
- Created a new Share on the QNAP
- Modified the ‘NFS Host access’ in the QNAP GUI to only allow the IP of the host you want to back up using dietpi-backup and grant RW mount access
- Mount the NFS file system using DietPi-DriveManager
- Run DietPi-Backup
Any problems I encountered along the way were all Storage side permissions issues.
Hope that helps.
Reds
thx for sharing and good to know that it is working on QNAP. I did a test on Synology, which is working as well.
Probably you like to share the challenges you faced on QNAP side an what solution you found.
I went trhough all the posts and replies (very happy dietpi user, but also confronted with NFS issues with new Synology nas), and found that even though rsync is an elegant way, it will always give issues. I got it to work, on two deitpi’s, and somehow, at some point it failed me again.
I can only suggest to users who face these issues: think about using a simple dd script to back up the system to img file on NAS. No rights issues, yes it takes some time, but for a weekly cron job in the middle of the night, targeting a larger spaced NAS, it’s no problem.
Just remeber to stop the running services… and start them after.
thanks dietpi creators/moderators, it’s one heck of a distro, use it now on all my pi’s
The dietpi-backup works with underlying rsync and contains some more nice bells & whistles.
See the documentation about it: DietPi tools - DietPi.com Docs.
Additionally, there is a blog post about this hot of the press: DietPi-Backup in an multi-device environment - DietPi blog.
Question from another user, what does backup actually backup?
Only the ‘OS’ DietPi or also the ‘user data’ ?
Is it possible to only backup the ‘OS’ ?
On a default setup, the whole system will be backup. User data is not included if it is located on an external drive. You could create custom include/exclude list using dietpi-backup interface.
Thx StephanStS! Will read. In the meantime I created an alternative that works for me. Based on the backup script of dietpi, use the rsync protocol to the NAS where I enabled the rsync service. Some tweaking the options, but works fine. It’s quicker and smaller than dd, and yes, uses some of the bells and whistles. Most importantly, it solves the permissions issue for me between un-synced NAS/Pi user lists.
