I want to request Dietpi administrators to add zigbee2mqtt in standard dietpi installation software, as it is one of the required
software in home Assistant software for zigbee to MQTT integration.
https://www.zigbee2mqtt.io/
thanks
thanks
Question…does MQTT (and mosquitto) use serial communication to the network?
I have always been blown away by the wifi-serial bridge on the ESP-01 (esp8266)
https://github.com/jeelabs/esp-link
Found this too
https://github.com/mycontroller-org/serial2mqtt
Might be able to build one of those wifi-serial bridge modules to communicate thru the wifi, bridge it to the outputs of the ESP-01, to the serial or IO pins, then use that serial2mqtt to mosquitto on the RPI
+1
Yes please, being able to easily install Zigbee2MQTT would be great!
+1
