Any idea why this is happening? Last couple of kernel upgrades have been fine.
root@Odroid:~# apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... The following package was automatically installed and is no longer required:
linux-image-4.9.60+
Use 'apt-get autoremove' to remove it.
Done
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up linux-image-4.9.61+ (4.9.61-20171118-XU3) ...
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.9.61+ /boot/vmlinuz-4.9.61+
run-parts: executing /etc/kernel/postinst.d/copy_dtb 4.9.61+ /boot/vmlinuz-4.9.61+
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.9.61+ /boot/vmlinuz-4.9.61+
update-initramfs: Generating /boot/initrd.img-4.9.61+
Image Name: uInitrd
Created: Sun Nov 19 18:25:07 2017
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 6492418 Bytes = 6340.25 kB = 6.19 MB
Load Address: 00000000
Entry Point: 00000000
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-4.9.61+ with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.9.61+.postinst line 391.
dpkg: error processing package linux-image-4.9.61+ (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-4.9-armhf-odroid-xu3:
linux-image-4.9-armhf-odroid-xu3 depends on linux-image-4.9.61+; however:
Package linux-image-4.9.61+ is not configured yet.
dpkg: error processing package linux-image-4.9-armhf-odroid-xu3 (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
linux-image-4.9.61+
E: Sub-process /usr/bin/dpkg returned an error code (1)
I note the gzip error but I have plenty of room on the system unless it is referring to the ramdisk?
John
