Hi I cant seem to find anything on this only , the raspberry Pi but how can I monitor fan speed via Dietpi. I installed lm-sensors but it doesnt show up.
Did you ran sensors-detect
Which motherboard/ sensor do you use? Probably it is not supported ootb by the Linux kernel
Yes I ran that but doesnt show up. Its a cheap Geekom minipc so likely its not using a supported sensor.
from DietPi side we don’t have such a feature. However plain Debian methods should work, at least if supported the device.
