what you suggest for upgrade bash command, what things to be needed & what not? only operating system & security purpose. not for any other software or application running on it.
The upgrade option only installs new version of the packages that are already installed on the system (and yes, kernel updates belong to them).
However, sometimes the updates change dependencies: for example, a new version of a package will no longer depend on a library that you have installed, or will require installation of additional libraries. The upgrade option will never remove installed packages that you no longer actually need.
However, the dist-upgrade option can “intelligently” handle changes in the dependencies system. This includes removing packages that are no longer necessary or resolve conflicts between packages that arose because of changes in the dependencies.
You should decide between both. From my point of view, it doesn’t make sense to run them together.
upgrade
upgrade is used to install the newest versions of all packages
currently installed on the system from the sources enumerated in
/etc/apt/sources.list. Packages currently installed with new
versions available are retrieved and upgraded; under no
circumstances are currently installed packages removed, or packages
not already installed retrieved and installed. New versions of
currently installed packages that cannot be upgraded without
changing the install status of another package will be left at
their current version. An update must be performed first so that
apt-get knows that new versions of packages are available.
dist-upgrade
dist-upgrade in addition to performing the function of upgrade,
also intelligently handles changing dependencies with new versions
of packages; apt-get has a "smart" conflict resolution system, and
it will attempt to upgrade the most important packages at the
expense of less important ones if necessary. So, dist-upgrade
command may remove some packages. The /etc/apt/sources.list file
contains a list of locations from which to retrieve desired package
files. See also apt_preferences(5) for a mechanism for overriding
the general settings for individual packages.
thanks after your recommendation i remove my wiregurd & reinstall it again, even then it was not working. then i carefully check it showing me wireguard-tools are out of dated on my machine & new one on upstream wireguard repository. then i remove the wiregurad-tools & reinstall them again . after that wiregurad start working fine. so the trouble was from wireguard-tools
yes, however on DietPi WireGuard is being installed from Bullseye repository, which was not updated until now. So don’t be confused if you will have a different version on your DietPi device.
For future reference if I am using wireguard, I have to take care of these packages. if anything new come from up I have to install it on my machine by removing the old one & install new individually.
Is I have to create new keys and generate client again or system can reuse old keys/clients. this time i regenerate keys & clients. but if these updates are frequent then personally i want to reuse them
honestly I don’t understand why you like to remove/install WireGuard once a new version is out. This should not be needed. Usually apt-get update and apt-get upgrade will update your installation if needed.
OK, i will wait for next update will come then i will checked what happen. if found some trouble i will come back here. but for now everything is working for me. thanks for all your help. dietpi is fantastic software. i want to thanks the administrator of this dietpi software/operating system. with there hardwork & knowledge our machines are working 24/7 happily, thanks
More generally, if you haven’t already I would suggest looking into both fail2ban and unattended-upgrades as packages that might be useful to you (although the latter takes a little configuring to get running properly).
The former can be installed within DietPi, the latter would be via apt or apt-get.
is there any reason to switch to bullseye? In the meantime there is the second update for WireGuard and not even the older update is available on bullseye, in software development these are light years.
The latest updates that are released by Wireguard 3 days ago are not yet available on Bullseye. Even on sid, this packages are available since today only. I checked WireGuard website on weekend and packages where marked outdated but changed today. So I expect Bullseye repro will be updated in next days.
