Thanks for helping with this.
dmesg retuned about a million lines all similar to
[ 5459.661445] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:18:f1:45:aa:da:88:08:00 SRC=192.168.20.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Do you have the ufw firewall installed?
also;
apt update && apt full-upgrade returned
Reading package lists... Done
E: Release file for https://deb.debian.org/debian/dists/buster-updates/InRelease is not valid yet (invalid for another 7h 2min 23s). Updates for this repository will not be applied.
E: Release file for https://deb.debian.org/debian-security/dists/buster/updates/InRelease is not valid yet (invalid for another 8h 57min 15s). Updates for this repository will not be applied.
E: Release file for https://deb.debian.org/debian/dists/buster-backports/InRelease is not valid yet (invalid for another 7h 2min 22s). Updates for this repository will not be applied.
E: Release file for https://pkgs.tailscale.com/stable/debian/dists/buster/InRelease is not valid yet (invalid for another 6h 26min 39s). Updates for this repository will not be applied.
Please disable it and see if this solves the VPN issues. I don’t see the WireGuard IP involved in this one line but for to forwarding there are quite many adapters involved, hence configuring the firewall correctly is important.
You system clock seems to be in the past. Run /boot/dietpi/func/run_ntpd to update it or check the custom time sync daemon in case you use one.
Will try, server seems to be hung at the moment
Server was all hung up, so I have started over.
Thanks for trying to help me sort it out.
There’ll be more questions to come no doubt
