Hi guys, I have an unusual use case and I would like to know if what I want is even possible.
I am on a college rocket team. Our rocket has a Raspberry Pi in its lander. Per rocket contest requirements, the rocket is supposed to have a magnetic breakaway connector which I can use to tell the rocket’s data collection systems to start recording.
I implemented this by using a magnetic breakaway USB charging cable that supports data, and plugging that into a USB to ethernet adapter, which in turn connects to the Pi. I would have used USB to serial, but I needed to be able to copy pictures or even video off it.
I want to make the USB connection and control process as easy to use as practical, so I would like to give its local network the following features:
- Configures IP addresses automatically
- Does not interfere with laptop’s ability to use internet connection from another source (primarily for my own convenience while setting up the IT end of things)
- Makes a captive portal that automatically directs the user to a web interface hosted on the Pi upon being plugged in
Here’s what I’ve accomplished so far:
- Gave the Pi a static IP address
- Set up a DHCP server on the Pi that issues an IP address to my Windows laptop successfully
- Before I gave the Pi a static IP, I used Windows internet connection sharing to give the Pi internet access through my laptop’s Wi-Fi. I turned that off now, but I can re-enable it if necessary.
Here’s what I’m stuck on:
- Make the Pi tell the laptop to keep using its existing default gateway
- Implement a captive portal
Is what I want even possible? If so, how?
