hy
i use dietpi on the raspberry pi 4 b
i can’t install wine on it.
winehq didn’t work. so i tried
$sudo apt install \
wine \
wine64 \
libwine \
fonts-wine
it works. i can open winecfg
but when i try to run wine with a exe file
i always get the same fail:
it looks like wine32 is missing, you should install it.
when i run:
sudo apt-get install wine32:i386
i get now the same fail like at the beginning:
he following packages have unmet dependencies:
libabsl20220623:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libaom3:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libasyncns0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libavif15:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libblkid1:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libbrotli1:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libbsd0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libbz2-1.0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libcap2:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libcapi20-3:i386 : Depends: libc6:i386 (>= 2.15) but it is not going to be installed
libcom-err2:i386 : Depends: libc6:i386 (>= 2.28) but it is not going to be installed
libcurl4:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
Depends: libssl3:i386 (>= 3.0.0) but it is not going to be installed
libdav1d6:i386 : Depends: libc6:i386 (>= 2.32) but it is not going to be installed
libdb5.3:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libdbus-1-3:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
Depends: libsystemd0:i386
libde265-0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libdeflate0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libdw1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libelf1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libexif12:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libexpat1:i386 : Depends: libc6:i386 (>= 2.25) but it is not going to be installed
libffi8:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libflac12:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libfontconfig1:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libfreetype6:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libgav1-1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libgcc-s1:i386 : Depends: libc6:i386 (>= 2.35) but it is not going to be installed
libgd3:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libglib2.0-0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libgmp10:i386 : Depends: libc6:i386 (>= 2.7) but it is not going to be installed
libgnutls30:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libgphoto2-6:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libgphoto2-port12:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libgssapi-krb5-2:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libgstreamer-plugins-base1.0-0:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libgstreamer1.0-0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libheif1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libhogweed6:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libicu72:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libidn2-0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libjbig0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libjpeg62-turbo:i386 : Depends: libc6:i386 (>= 2.7) but it is not going to be installed
libk5crypto3:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libkeyutils1:i386 : Depends: libc6:i386 (>= 2.7) but it is not going to be installed
libkrb5-3:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libkrb5support0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libldap-2.5-0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
liblerc4:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libltdl7:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
liblzma5:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libmd0:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libmount1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libmp3lame0:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libmpg123-0:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libnettle8:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libnghttp2-14:i386 : Depends: libc6:i386 (>= 2.17) but it is not going to be installed
libnuma1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libogg0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libopus0:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
liborc-0.4-0:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libp11-kit0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libpcap0.8:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libpcre2-8-0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libpng16-16:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libpsl5:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libpulse0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
librav1e0:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
librtmp1:i386 : Depends: libc6:i386 (>= 2.7) but it is not going to be installed
libsasl2-2:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libsasl2-modules-db:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libselinux1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libsndfile1:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libssh2-1:i386 : Depends: libc6:i386 (>= 2.28) but it is not going to be installed
libstdc++6:i386 : Depends: libc6:i386 (>= 2.36) but it is not going to be installed
libtasn1-6:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libtiff6:i386 : Depends: libc6:i386 (>= 2.33) but it is not going to be installed
libudev1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libunistring2:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libunwind8:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libusb-1.0-0:i386 : Depends: libc6:i386 (>= 2.28) but it is not going to be installed
libvorbis0a:i386 : Depends: libc6:i386 (>= 2.29) but it is not going to be installed
libvorbisenc2:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libwebp7:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libwine:i386 : Depends: libc6:i386 (>= 2.35) but it is not going to be installed
Depends: libasound2:i386 (>= 1.0.16) but it is not going to be installed
Depends: ocl-icd-libopencl1:i386 but it is not installable or
libopencl1:i386
Depends: ocl-icd-libopencl1:i386 (>= 1.0) but it is not installable or
libopencl-1.2-1:i386
libx11-6:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libx265-199:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libxau6:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libxcb1:i386 : Depends: libc6:i386 (>= 2.28) but it is not going to be installed
libxdmcp6:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libxext6:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
libxml2:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libxpm4:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
libyuv0:i386 : Depends: libc6:i386 (>= 2.11) but it is not going to be installed
libzstd1:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
wine32:i386 : Depends: libc6:i386 (>= 2.34) but it is not going to be installed
zlib1g:i386 : Depends: libc6:i386 (>= 2.4) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
update and upgrade not work ![]()
