Wifi hotspot doesn’t work any more get error on install
Failed to start hostapd.service: Unit hostapd.service is masked.
cocoflan
No idea what masked it, but simply unmask via: systemctl unmask hostapd.service
Then retry.
Did what you say and my hotspot is back online but no internet connection is posible, even after reinstall on my raspberry pi i did have to do that commandline procedure to activate my hotspot but still no connection for internet. tested raspap on other system on raspberry pi and that worked so u guess that it have to do with some kind of update.
I did install an old image 6.17 on my raspberry pi and get the same error, when i use your command it fixed it, so now i have a connection and internet again, so it must be something in the updates i guess. Hope it stays good for now.
identical trouble afther upgrading from v6.22.3 to v6.24.0 with hostapd, i restored to 6.22.3 again.
cocoflan
Could you try it with the hostapt package from the repo:
apt install --reinstall hostapd
i did apt purge hostapd and then reinstall with apt install, and it stayed the same. so for now am again on v6.22.3 with a backup restore.
Or makes it a difference to use apt install --reinstall hostapd?
I first upgraded to v6.24.1 (maby nothing to do with it i guess).
And then “apt install --reinstall hostapd” did the trick, thx !!!
Again same problem with hostapd, even when i reinstall with the beta version a get the same errors !
cocoflan
Did this actually work any time before with the same WiFi adapter?
Yes, but only after a backup restore, this problem keeps showing up again and again!
cocoflan
Which RPi model do you use?
And which WiFi adapter (if not an internal one): lsusb
In case it is an external USB WiFi dongle, please try the following:
cd /tmp
wget https://dietpi.com/downloads/binaries/all/hostapd_2.5_all.zip
unzip hostapd_2.5_all.zip
rm hostapd_2.5_all.zip
the next depends on RPi and WiFi adapter model
It is a RPI 3 B+ that i use.
So the internal WiFi I bet… hmm then I have no idea why it fails currently, the steps I started are then not applicable.
A debug start then:
systemctl status hostapd
systemctl stop hostapd
hostapd /etc/hostapd/hostapd.conf
● hostapd.service
Loaded: masked (/dev/null; bad)
Active: inactive (dead)
RPI 3 B+
solution ???
i have left my device off yesterday, and tested the steps again today, it is working again.
So don’t know what is the real problem, thx for the info. ![]()
