First I want to say what a fantastic job you’ve done with dietpi. A lot of features for a small footprint.
I have in the past setup PI3 as Wifi Hotspots. There are numerous post on setting them up. So you can see it was a bit confusing. One even had me install some ‘bridge’ software.
I installed your version and it works out of the box. Very impressed. I can change the SSID and password and channel. Are there plans for future changes of the static ip , ip range it gives out, lease time etc?
If not, can I change these myself without having to worry an update will overwrite them? And are they in the typical /ETC/ and other files usually mentioned in past Hotspot setups?
Thanks for the great job. I plan to use this setup on many Pi’s especially the Rpi Webcam on my Pi Zero W projects as the standard debian installation is so slow and the videos choppy at times.
