DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=10
G_DIETPI_VERSION_RC=2
G_GITOWNER=‘MichaIng’ -
Distro version |
bullseye 1 -
Kernel version |
uname -a
SBC model |
echo $G_HW_MODEL_NAME
or (EG: RPi3) -
Linux DietPi 5.15.61-v7+ #1579 SMP Fri Aug 26 11:10:59 BST 2022 armv7l GNU/Linux
Installed Hotspot in Browse Software - Can this issue be replicated on a fresh installation of DietPi?
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID |
echo $G_HW_UUID
Hotspot stops working 0 to 10 times daily. Connected clients are disconnected
Restart hostapd fails to restart
I can only resolve it by a reboot of the Pi
- …Hotspot stops working 0 to 10 times daily. Connected clients are disconnected
root@DietPi:~# sudo systemctl stop isc-dhcp-server
root@DietPi:~# sudo systemctl start isc-dhcp-server
root@DietPi:~# sudo systemctl start hostapd
Job for hostapd.service failed because a timeout was exceeded.
See "systemctl status hostapd.service" and "journalctl -xe" for details.
root@DietPi:~# systemctl status hostapd.service
● hostapd.service - Access point and authentication server for Wi-Fi and Ethernet
Loaded: loaded (/lib/systemd/system/hostapd.service; disabled; vendor preset: enabled)
Active: activating (start) since Fri 2022-11-11 11:19:44 PST; 12s ago
Docs: man:hostapd(8)
Cntrl PID: 23587 (hostapd)
Tasks: 1 (limit: 1596)
CPU: 25ms
CGroup: /system.slice/hostapd.service
└─23587 /usr/sbin/hostapd -B -P /run/hostapd.pid -B /etc/hostapd/hostapd.conf
