root@DietPi:~# ls -l /boot /lib/modules
/boot:
total 49139
-rwxr-xr-x 1 root root 18693 May 21 09:46 COPYING.linux
-rwxr-xr-x 1 root root 512 Jan 1 1980 FSCK0000.REC
-rwxr-xr-x 1 root root 512 Jan 1 1980 FSCK0001.REC
-rwxr-xr-x 1 root root 512 Jan 1 1980 FSCK0002.REC
-rwxr-xr-x 1 root root 512 Jan 1 1980 FSCK0003.REC
-rwxr-xr-x 1 root root 6144 Jan 1 1980 FSCK0004.REC
-rwxr-xr-x 1 root root 10752 Jan 1 1980 FSCK0005.REC
-rwxr-xr-x 1 root root 68096 Jan 1 1980 FSCK0006.REC
-rwxr-xr-x 1 root root 629248 Jan 1 1980 FSCK0007.REC
-rwxr-xr-x 1 root root 10240 Jan 1 1980 FSCK0008.REC
-rwxr-xr-x 1 root root 20480 Jan 1 1980 FSCK0009.REC
-rwxr-xr-x 1 root root 10752 Jan 1 1980 FSCK0010.REC
-rwxr-xr-x 1 root root 1594 May 21 09:58 LICENCE.broadcom
drwxr-xr-x 2 root root 512 Sep 9 2020 'System Volume Information'
-rwxr-xr-x 1 root root 25870 May 21 09:46 bcm2708-rpi-b-plus.dtb
-rwxr-xr-x 1 root root 25218 May 21 09:46 bcm2708-rpi-b-rev1.dtb
-rwxr-xr-x 1 root root 25607 May 21 09:46 bcm2708-rpi-b.dtb
-rwxr-xr-x 1 root root 25529 May 21 09:46 bcm2708-rpi-cm.dtb
-rwxr-xr-x 1 root root 26545 May 21 09:46 bcm2708-rpi-zero-w.dtb
-rwxr-xr-x 1 root root 25352 May 21 09:46 bcm2708-rpi-zero.dtb
-rwxr-xr-x 1 root root 26745 May 21 09:46 bcm2709-rpi-2-b.dtb
-rwxr-xr-x 1 root root 26894 May 21 09:46 bcm2710-rpi-2-b.dtb
-rwxr-xr-x 1 root root 29011 May 21 09:46 bcm2710-rpi-3-b-plus.dtb
-rwxr-xr-x 1 root root 28392 May 21 09:46 bcm2710-rpi-3-b.dtb
-rwxr-xr-x 1 root root 26890 May 21 09:46 bcm2710-rpi-cm3.dtb
-rwxr-xr-x 1 root root 49090 May 21 09:46 bcm2711-rpi-4-b.dtb
-rwxr-xr-x 1 root root 48810 May 21 09:46 bcm2711-rpi-400.dtb
-rwxr-xr-x 1 root root 49202 May 21 09:46 bcm2711-rpi-cm4.dtb
-rwxr-xr-x 1 root root 52456 May 21 09:58 bootcode.bin
-rwxr-xr-x 1 root root 119 May 14 13:09 cmdline.txt
-rwxr-xr-x 1 root root 2852 May 16 11:44 config.txt
drwxr-xr-x 4 root root 3072 May 16 11:51 dietpi
-rwxr-xr-x 1 root root 205026 May 10 2020 dietpi-CHANGELOG.txt
-rwxr-xr-x 1 root root 10130 May 10 2020 dietpi-README.md
-rwxr-xr-x 1 root root 12552 May 16 11:43 dietpi.txt
-rwxr-xr-x 1 root root 7314 May 21 09:58 fixup.dat
-rwxr-xr-x 1 root root 5446 May 21 09:58 fixup4.dat
-rwxr-xr-x 1 root root 3191 May 21 09:58 fixup4cd.dat
-rwxr-xr-x 1 root root 8454 May 21 09:58 fixup4db.dat
-rwxr-xr-x 1 root root 8452 May 21 09:58 fixup4x.dat
-rwxr-xr-x 1 root root 3191 May 21 09:58 fixup_cd.dat
-rwxr-xr-x 1 root root 10298 May 21 09:58 fixup_db.dat
-rwxr-xr-x 1 root root 10298 May 21 09:58 fixup_x.dat
-rwxr-xr-x 1 root root 145 May 27 2020 issue.txt
-rwxr-xr-x 1 root root 5981944 May 21 09:46 kernel.img
-rwxr-xr-x 1 root root 6320888 May 21 09:46 kernel7.img
-rwxr-xr-x 1 root root 6694528 May 21 09:46 kernel7l.img
-rwxr-xr-x 1 root root 7758283 May 21 09:46 kernel8.img
drwxr-xr-x 2 root root 19456 May 21 09:46 overlays
-rwxr-xr-x 1 root root 2952928 May 21 09:58 start.elf
-rwxr-xr-x 1 root root 2228768 May 21 09:58 start4.elf
-rwxr-xr-x 1 root root 793084 May 21 09:58 start4cd.elf
-rwxr-xr-x 1 root root 3722504 May 21 09:58 start4db.elf
-rwxr-xr-x 1 root root 2981160 May 21 09:58 start4x.elf
-rwxr-xr-x 1 root root 793084 May 21 09:58 start_cd.elf
-rwxr-xr-x 1 root root 4794472 May 21 09:58 start_db.elf
-rwxr-xr-x 1 root root 3704712 May 21 09:58 start_x.elf
/lib/modules:
total 32
drwxr-xr-x 3 root root 4096 May 24 17:36 5.10.17+
drwxr-xr-x 3 root root 4096 May 24 17:36 5.10.17-v7+
drwxr-xr-x 3 root root 4096 May 24 17:37 5.10.17-v7l+
drwxr-xr-x 3 root root 4096 May 21 09:46 5.10.17-v8+
drwxr-xr-x 3 root root 4096 May 19 23:03 5.10.36+
drwxr-xr-x 3 root root 4096 May 19 23:03 5.10.36-v7+
drwxr-xr-x 3 root root 4096 May 19 23:03 5.10.36-v7l+
drwxr-xr-x 3 root root 4096 May 19 23:03 5.10.36-v8+
