Some more information since I managed to get Firefox running on that Visionfive2.
dmesg:
[  9.517951] **********************************************************
[    9.532054] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    9.546127] **                                                      **
[    9.560133] ** trace_printk() being used. Allocating extra memory.  **
[    9.574134] **                                                      **
[    9.588038] ** This means that this is a DEBUG kernel and it is     **
[    9.601960] ** unsafe for production use.                           **
[    9.615837] **                                                      **
[    9.629629] ** If you see this message and you are not debugging    **
[    9.643424] ** the kernel, report this immediately to your vendor!  **
[    9.657159] **                                                      **
[    9.670850] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
[    9.684525] **********************************************************
[    9.744709] AICWFDBG(LOGINFO)	rwnx v6.4.3.0 - 1a4b0054d2M (master)
[    9.744724] AICWFDBG(LOGINFO)	RELEASE DATE:2023_0707_1001
[    9.744902] usbcore: registered new interface driver aic8800_fdrv
lsusb:
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID a69c:5721 aicsemi Aic MSC
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lsmod:
Module                  Size  Used by
ov4689_mipi            28672  0
starfivecamss         212992  1 ov4689_mipi
videobuf2_dma_contig    20480  1 starfivecamss
videobuf2_memops       16384  1 videobuf2_dma_contig
videobuf2_v4l2         32768  1 starfivecamss
videobuf2_common       73728  4 videobuf2_dma_contig,videobuf2_v4l2,starfivecamss,videobuf2_memops
imx708                 28672  0
imx219_mipi            24576  0
v4l2_fwnode            24576  4 ov4689_mipi,imx219_mipi,imx708,starfivecamss
v4l2_async             24576  5 ov4689_mipi,v4l2_fwnode,imx219_mipi,imx708,starfivecamss
videodev              331776  7 v4l2_async,ov4689_mipi,imx219_mipi,imx708,videobuf2_v4l2,videobuf2_common,starfivecamss
mc                     57344  8 v4l2_async,ov4689_mipi,videodev,imx219_mipi,imx708,videobuf2_v4l2,videobuf2_common,starfivecamss
starfive_mailbox       16384  0
goodix_ts              36864  0
aic8800_fdrv          581632  0
cfg80211             1007616  1 aic8800_fdrv
aic_load_fw            73728  1 aic8800_fdrv
ifup wlan0
wpa_supplicant: /usr/sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
ifup: failed to bring up wlan0
I added the necessary Wifi info to wpasupplicant config files.
iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
eth1      no wireless extensions.
sit0      no wireless extensions.
uname -a
Linux DietPi 6.1.97 #1 SMP Fri Jul  5 23:02:10 UTC 2024 riscv64 GNU/Linux
DietPi 9.11.2, updated on 07.03.2025 9:00h MEZ
Update I just found out that the USB dongle stays in mass storage mode, obviously. Do you have a solution to switch in RISC V / Visionfive 2 as well? For example, here is some documentation:
