I connect first with ethernet,
do dietpi-config and enable wifi,
so wifi is connected at this point,
but when i restart i have no wifi, and no ethernet !
what am i doing wrong ?
to have ethernet again, i need to unplug the wifi dongle, even with wifi off.
My setup :
Odroid C1+
dietpi 5.15.93
wifi dongle with MT7610U
Also…first thing to do always on ethernet (or a connected wifi) is to do an (as root or sudoer) # apt update && apt upgrade -y
To ensure all drivers and kernel’s are updated to latest
and i made the wifi working at first boot with dietpi-config
here is the result :
sudo dmesg | grep mt
[ 24.541584] mt76x0u 1-1.4:1.0: ASIC revision: 76100002 MAC revision: 76502000
[ 24.557180] mt76x0u 1-1.4:1.0: mediatek/mt7610e.bin not found, switching to mediatek/mt7610u.bin
[ 25.625781] mt76x0u 1-1.4:1.0: EEPROM ver:02 fae:01
[ 25.681390] usbcore: registered new interface driver mt76x0u
lsusb
Bus 001 Device 004: ID 0b05:17d1 ASUSTek Computer, Inc. AC51 802.11a/b/g/n/ac Wireless Adapter [Mediatek MT7610U]
Bus 001 Device 003: ID 262a:12c0 SAVITECH Corp. Audiophonics U-SABRE(A)
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
BUT when i reboot, there is no wifi and no ethernet,
i need to unplug the wifi dongle and reboot to have the ethernet back
